Mixed too much epoxy #165225
01/17/09 05:58 PM
01/17/09 05:58 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
I mixed up about 6 oz too much MAS epoxy and resin, and being the frugal guy that I am I didnt want to throw it out, so I put it outside (10deg)to keep it from hardening. Will it still be usable, or will it freeze and be un-usable?
Any chemists out there that can help?
Re: Mixed too much epoxy [Re: bvining] #165227
01/17/09 06:12 PM
01/17/09 06:12 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Between lams we have a refrigerator in the shop that we put the unused portion in. It just slows down the inevitable. The chemical process has started. And down to 10deg, I don't know. My frige is at like 55deg +or-.
We mostly use that technique for gelcoat. It allows the boat that we're working on to cure a bit between coats so we don't get sags.
Re: Mixed too much epoxy [Re: bvining] #165229
01/17/09 06:38 PM
01/17/09 06:38 PM
UK
Cheshirecatman Offline
UK
Suggest you don't let it freeze. Some pre-pregs store at 40f (4.4C) for up to 6 months but are very susceptible to moisture which effects bonding properties. However, bulk epoxy ?????
Cheshirecatman
Re: Mixed too much epoxy [Re: Cheshirecatman] #165234
01/17/09 08:14 PM
01/17/09 08:14 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
I put several pumps worth of mixed epoxy in my wife's freezer compartment under a tight polyethylene cover. It was excellent for 3 days til used up later for fill etc.. No problems- except with the wife.....
Chemical reactions slow by 50% for each 10 degree C drop in temperature.
signed Dave Carlson PhD Physical-Organic Chemist.
Dacarls:
Re: Mixed too much epoxy [Re: dacarls] #165258
01/18/09 07:48 AM
01/18/09 07:48 AM
So when it it heats up again, the chemical process starts up again? No problem?
Taking it a bit further, if I work in a cold room laminating parts and heat the part later, the process will still kick in at 100% (or as well as if I worked at a constant 20degC)?
Re: Mixed too much epoxy [Re: Rolf_Nilsen] #165260
01/18/09 08:22 AM
01/18/09 08:22 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Rolf, thats quite a good technique for doing epoxy work overhead to stops mess and drips. Put it on cold and then warm it up once its in place to wet it out.
Re: Mixed too much epoxy [Re: Rolf_Nilsen] #165261
01/18/09 09:05 AM
01/18/09 09:05 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
I have used this technique with catalyzed products many times.
Usually with paints such as Imron, Awlgrip, DP40, and misc. epoxies. I found that by putting the unused portions in the refer I could keep them for a week or two and then use them with good results.
However, I am not sure the chemical properties are as good as with a normal cure. I never saw problems but nothing I did was structural in nature.
I wonder if structural expoxies might be compromised somewhat by doing this.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Mixed too much epoxy [Re: Mugrace72] #165266
01/18/09 12:06 PM
01/18/09 12:06 PM
dacarls Offline
dacarls  Offline
Re: Epoxy for CF cloth, glass repair or polyester gel coat repair. When West System or any epoxy is mixed- it does not care how fast it polymerizes. As long as this chemical reaction has correct amounts of each reagent, it should go to completion. Just at different speeds depending on temperature.
Thus if you heat it, for each 10 degrees C ABOVE room temperature its reaction speed will also double. So, I mix well and then immediately separate off the likely excess in a quite shallow dish so it does not cook off.
Keep cool in the fridge, then freeze asap covered, thus DRY: use a Zip-lok polyethylene bag. Newspaper-sleeve thin polyethylene tubes are very useful for a cup of epoxy because they WON'T TIP OVER.
Be sure to emphasize ahead of time to your female crew/wife that this is non-stinky epoxy. It is NOT catalyzed polyester resin and WILL NOT STINK UP HER FRIDGE. Now- does she really trust you?
Note- If you over-mix warm epoxy, mix in fumed silica gel or colored dye, then hold a compact storage cup- it may self destruct in 10 minutes. Quick and cool is best.
Dacarls:
Re: Mixed too much epoxy [Re: Rolf_Nilsen] #165276
01/18/09 03:11 PM
01/18/09 03:11 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Prepreg carbon comes with the epoxy already added and is kept in referigeration until use. this is how some high tech big boats are done so it must be structuraly sound.
Re: Mixed too much epoxy [Re: TEAMVMG] #165278
01/18/09 03:33 PM
01/18/09 03:33 PM
Have you been watching the Vendee lately? eek
Re: Mixed too much epoxy [Re: dacarls] #165306
01/18/09 10:13 PM
01/18/09 10:13 PM
Dave,
I've had a little different experience with mixing epoxy when it was cold in that it wouldn't cure. Once mixed and the reaction started, I've never had a problem with low temperatures. I have, on a couple of occasions, mixed West System (fast hardner) when the resin and hardner were below 40 degrees and I had real problems with it curing. I make sure it's warm now before I start to mix.
Re: Mixed too much epoxy [Re: Jake] #165317
01/19/09 07:14 AM
01/19/09 07:14 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
I went back to my 6oz of mixed epoxy/resin in a plastic container in about 30 mins at about 20deg and it had hardened and melted the plastic cup. It hardened faster than the part that I was making in the warm shop. So, I guess the mass of liquid had already started the chemical reaction and had enough internal heat that it wouldnt slow down.
Interesting.
Re: Mixed too much epoxy [Re: bvining] #165384
01/19/09 07:48 PM
01/19/09 07:48 PM
Interesting.
I bet if you use the slow hardener, the exothermic heat generated wouldn't be extreme enough to overcome the ambient temperature.
Re: Mixed too much epoxy [Re: Jake] #165390
01/19/09 09:45 PM
01/19/09 09:45 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
In other words the pero-fluvial cryobenarium would not exceed the polar molecular matriculum dicrundi.There by not having a gelatinous mound of defecation in the sub 32 degree insulated box.
(If youda used the slow hardenerer your sh!t wouldn't of kicked in da freezer)
Tawd
Isak Dinesen
E. B. White
Re: Mixed too much epoxy [Re: Jake] #165413
01/20/09 09:28 AM
01/20/09 09:28 AM
"So, I mix well and then immediately separate off the likely excess in a quite shallow dish so it does not cook off." D. Carlson.
Fellas, I'd reread the good Doctor on this one. wink
Re: Mixed too much epoxy [Re: fin.] #165423
01/20/09 10:25 AM
01/20/09 10:25 AM
Uhh...yeah - that too! blush
Re: Mixed too much epoxy [Re: Jake] #165466
01/20/09 05:49 PM
01/20/09 05:49 PM
Well.. With the cost of west System ,I would never mix more than I needed, therefore taking off the excess is not an option. Once I know I have excess(usually scraped off of the project), it's too late. I've tried saving it by cooling it and it has never worked for me . Slowed it down, but still gelled within 20 minutes. I would think if there was a way to save extra, some of the boatshops I worked for would have used the technique.
Todd
Isak Dinesen
E. B. White
Re: Mixed too much epoxy [Re: Team_Cat_Fever] #165494
01/20/09 11:04 PM
01/20/09 11:04 PM
dacarls Offline
dacarls  Offline
Whut it is, is them thar boy molecules want to get all jiggy with the girl molecules REAL BAD, and never let go. If'n they's too cold, not much happens, even if they is an equal number of them all mixed up close together. But if y'all lets thesehere boys and girls get too hot, its like the clothes all get flung off and they start to seriously party down. Cooling them off don't help much then- its too dang late, Bubba. Hope this helps.... The ol' Doc.
Dacarls:
Re: Mixed too much epoxy [Re: dacarls] #165496
01/20/09 11:20 PM
01/20/09 11:20 PM
So it's all about proper parenting.
Isak Dinesen
E. B. White
Re: Mixed too much epoxy [Re: Team_Cat_Fever] #165506
01/21/09 06:10 AM
01/21/09 06:10 AM
Since I'll be starting a project for myself soon, I'm thinking of working out of a wide shallow pan rather than a cup.
Whachya'll think?
0 registered members (), 4,275 guests, and 442 spiders.
