Mast Hook question? #165813
01/23/09 02:37 AM
01/23/09 02:37 AM
Simon C Offline OP
Simon C  Offline OP
Hi All,
Quick question if anyone is about...
My hook/pulley set up fell to bits last week and I sailed on Sunday with a pretty dodgy fix. I now have my new bits from AHPC which are different to the old bits. and I'm putting it on tonight for the weekends sailing.
Question.... Hook and pully lined up with track?, hook in centre and pulley offset? or pulley in centre and hook offset?
Thanks in advance for any pointers.
Simon
Taipan AUS341
Re: Mast Hook question? [Re: Simon C] #165815
01/23/09 03:45 AM
01/23/09 03:45 AM
First_Try Offline
First_Try  Offline
Simon, A picture is worth more. The link has three pic's of a Goodall setup
Regards
Peter
Peter
First Try
Re: Mast Hook question? [Re: First_Try] #165818
01/23/09 04:04 AM
01/23/09 04:04 AM
Simon C Offline OP
Simon C  Offline OP
Hi Peter.
I've got slightly different bits. The gave me a Taipan hook bent to fit the mozzie section and a pulley on a plate. My mast has a section of track cut away at the top so I couldn't use your set up. The pictures have given me an idea of the offset so I should be fine. I'll centre the hook and offset the pulley a little. I guess I'll find out if it will unhook at the end of business tomorrow. blush
Thanks for taking the time.
Simon
Taipan AUS341
Re: Mast Hook question? [Re: Simon C] #165819
01/23/09 04:16 AM
01/23/09 04:16 AM
First_Try Offline
First_Try  Offline
no problem
Peter
Peter
First Try
Re: Mast Hook question? [Re: First_Try] #165899
01/23/09 12:24 PM
01/23/09 12:24 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
mast hook
we have the same hook/pulley setup as the taipan on the capricorn. you can see there is no offset at all. the "idea" is hoist the sail straight up and hook on, then rotate the mast to unhook.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Mast Hook question? [Re: Dazz] #165963
01/24/09 02:17 AM
01/24/09 02:17 AM
Simon C Offline OP
Simon C  Offline OP
Thanks Dazz and Peter.
All worked well today with one exception. Because of the corrosion I had under the old one the new hook is a little lower than the old.
Having not moved anything at the bottom of the mast (hind-sight is a wonderfull thing) I couldn't get the sail flat enough which turned out to be pretty inconvenient in the 25 knots and 1.5m chop we had today. shocked
Net result, 2 swims, a DNF, a DNC and a broken trap set up. On the upside I guess it's always good to get some righting practice laugh.
Looks like another night in the shed. Ahh... the joys of sailing grin
Simon
Taipan AUS341
0 registered members (), 4,625 guests, and 833 spiders.
