| #7 PRINDLE 16 NEED TO FIND A BETTER WAY TO RAISE MAST #165888 01/23/09 12:01 PM 01/23/09 12:01 PM |
Posts: 9 | I have a prindle 16 #7 off the shelf the early prindle's dont have a hinge setup. it takes 3 people to raise mast from what i have been told i need to replace the bottom of the mast with a 16 or 18 prindle mast (looking for bent mast) that has hinge setup and replace front cross tube that has hinge set-up any one have another ez way to do this? or how did you solve this problem | | | Re: #7 PRINDLE 16 NEED TO FIND A BETTER WAY TO RAISE MAST
[Re: SD-PRINDLE]
#165917 01/23/09 01:50 PM 01/23/09 01:50 PM |
Posts: 1,203 uk | Lay mast on tramp with foot pointing out between bows. Attach shrouds and forestay with forestay bridle OVER mast Stand on tramp and stand mast up on GROUND in front of beam Lift mast straight up and onto socket on front beam.
If mast starts to topple whilst lifting, don't worry, keep on lifting - rigging will tighten.
make sure that shouds are set loose
[Re: SD-PRINDLE]
#165989 01/24/09 03:27 PM 01/24/09 03:27 PM |
Posts: 9 | ok if i buy the spare at at Murrays or where ever... i need to take old mast base and mast step casting off and re-rivet new one on?
base $30 mast step $56 hing $18 =$104 i dont mend spending that if this is what it takes
[Re: Matt Moore]
#166236 01/26/09 07:40 PM 01/26/09 07:40 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Wow Mat, That's an ingenious way of doing it.
I've sailed solo, on 18 and 20 ft cats, rigged them myself, etc. But I always got a passer-by to do the tip of the mast thing while I lifted it, stern to the wind so I could even do the forestay.
But, if you don't have anybody willing, or anybody, then I'm going to remeber your methods, just in case.
F-18 Infusion #626- SOLD it!
2,662
guests, and 437
