| Taming spin sheets #166020 01/25/09 07:03 AM 01/25/09 07:03 AM |
Joined: Sep 2006 Posts: 586 Hobart, Tasmania, Oz. Dazz OP
Posts: 586 Hobart, Tasmania, Oz. | Does anyone have any really good ideas on how to keep the spin sheets out of mischief while sailing to windward.
I'm thinking some sort of clips on the main beam, would be happy just to stop them falling off the main beam and into the water!
Dazz
| | | Re: Taming spin sheets
[Re: Dazz]
#166027 01/25/09 08:35 AM 01/25/09 08:35 AM |
Posts: 2,844 42.904444 N; 88.008586 W | I've seen lots of variations.
One of the best was a pigtail on the clew for the spin sheet, sucked the sheet into the snuffer more. (Or was the the halyard/retrieval line?)
I used to use a turning block on a fairly loose bungee near the rear beam that the spin sheet went thru. It kept things tiddy on the tramp, and the sheet never went off the boat, but had plenty of slack to trim, tack, etc.
I'm sure someone will give you some great ideas about this.
F-18 Infusion #626- SOLD it!
[Re: ncik]
#166099 01/26/09 01:56 AM 01/26/09 01:56 AM |
Posts: 586 Hobart, Tasmania, Oz. | Ok I will give the pigtail a go!
how long is it normally? will a longer halyard be needed?
I seem to remember reading something about it on this forum a long time ago. seriously cant find it.
[Re: Dazz]
#166234 01/26/09 07:36 PM 01/26/09 07:36 PM |
Posts: 503 | Did you use shock cord or rope? Piece of spectra. I think most of the F18s were using it at Tradewinds. | | | Re: Taming spin sheets
[Re: BrianK]
#166998 02/01/09 11:29 PM 02/01/09 11:29 PM |
Posts: 586 Hobart, Tasmania, Oz. | Hey Guys,
Thanks for all the input!
In the end I used 18 inches of dyneema core and spliced onto a 25mm ring. put an eye splice in the other end so i can loop it through the clew of any kite.
needed a little extra halyard, but its a pretty happy trade off.
[Re: TEAMVMG]
#167032 02/02/09 11:49 AM 02/02/09 11:49 AM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac
Posts: 267 Ocean Springs, MS | ok, ok its 2.5cm for an inch but come on, the effort was there!
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | |
1 registered members (FredL),
2,799
guests, and 283
