minimum crew weight? #170317
03/03/09 05:18 PM
03/03/09 05:18 PM
Miami, FL
John McKnight Offline OP
Miami, FL
Is there a minimum crew weight for the F-18? If so, where is it found. I am scoring a Portsmouth race with a Nacra F-18 in the mix. I do not see a minimum crew weight listed in the Class Weight Table for Multihulls chart. There is a weight of 308 lbs. listed for the Tiger. Do you use this weight for all the F-18s?
Thanks for the info.
John McKnight
305 251-7600
Re: minimum crew weight? [Re: John McKnight] #170323
03/03/09 06:51 PM
03/03/09 06:51 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
John, here is the rules on weight:
3.2.1 There are three categories of crew weight :
(i) of 253 lbs to less than 286 lbs
(ii) 286 lbs to 308 lbs
(iii) above 330 lbs
3.2.2 The crew in the category of 253 lbs to less than 286 lbs shall carry a weight equal to half of the difference between 286 lbs and the actual weight of the crew. The weight shall be fixed to the outside of the forward crossbeam on the port side and shall be removable for
control checking. (small sail plan)
B.3.3. CHANGE OF CATEGORY
The crew in the category of 308 lbs to 330 lbs may use a corrector weight to compete in the upper category. (large sail plan)
The corrector weight, equal to half of the difference between 330 lbs and the actual weight of
the crew shall be fixed to the outside of the forward beam on the port side and shall be
removable for control.
F18 USA 242
http://www.solarwind.solar
Re: minimum crew weight? [Re: John McKnight] #170382
03/04/09 10:51 AM
03/04/09 10:51 AM
Miami, FL
Miami, FL
Hi David,
Thanks for the help.
John
0 registered members (), 444 guests, and 33 spiders.
