| Frankenhobie ( Put the third rudder here, Igor) #156267 09/30/08 09:27 PM 09/30/08 09:27 PM |
Joined: Jun 2001 Posts: 493 Minnesota Jeff Peterson OP
Posts: 493 Minnesota | (I knew that subject line would get some attention.)
Does anyone have experiences with mutant Hobies, assembled from an odd mixture of parts from the sailboat cemetery?
Hint: I love pictures!
| | | Re: Frankenhobie ( Put the third rudder here, Igor)
[Re: Jeff Peterson]
#156268 10/01/08 10:08 PM 10/01/08 10:08 PM |
Posts: 7 New London, CT | i dont really have frankenhobie pics but ive got pics.got a '77 Hobie 16 and its my first boat. Got it out for the first time last weekend. lovin it. original sails too
~Kyle Gless '77 Hobie 16
[Re: cbushek]
#158089 10/23/08 08:24 PM 10/23/08 08:24 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | I hate you. I've been looking for some early 90's hulls forever.
Ok, I really don't hate you. Just envious.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: FasterDamnit]
#160296 11/12/08 10:34 PM 11/12/08 10:34 PM |
Posts: 19 Mayport, FL | I'm trying to get a trashed Gcat 5.7 going. Any leftover parts from your Gcat?
1982 Hobie 16 modified | | | Re: Frankenhobie ( Put the third rudder here, Igor)
[Re: BLMay]
#160391 11/14/08 11:37 AM 11/14/08 11:37 AM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | I'm trying to get a trashed Gcat 5.7 going. Any leftover parts from your Gcat? A few. Most of it went to the new boat. What do you need? I am sorry we never got to try out the Hooter rig we were working on. You can push the 5.7 pretty hard downwind w/ the tall bows. I think it is definitely faster than it's rating. If I could have found another one cheap, I would have gone that direction as it would have been much easier.
E-Scow 24' ULDB
[Re: FasterDamnit]
#160447 11/14/08 11:11 PM 11/14/08 11:11 PM |
Posts: 19 Mayport, FL | I've already patched one hull where it sat at the edge of a lake for 3 years and wore a hole through by rubbing the sand every time a boat went by. The rear crossbeam has a hairline crack that I might fill in with a weld. The bridle is missing also, but I would guess you are using that on your creation. Both of my tramps are shot also. Jib is gone, and one boomless mainsail is fair, the other is shot. It was a rental alright. The more I assess the thing, the worse it gets, but I've got all winter to fab stuff together and get it going.
So anything you arent using from your Gcat might be usuable to me. Let's make a deal.
[Re: FasterDamnit]
#160642 11/17/08 06:31 PM 11/17/08 06:31 PM |
Posts: 19 Mayport, FL | Thanks. I read through the old threads. What happened to your Gcat? Anyway, shipping shouldn't be too bad from SC to FL if you decide to sell any of it to me.
I looked it over again Saturday and found a few more problems with it, but that's fine. If I get it sailing by springtime, it'll be something to brag about. I also noticed the mainsail says GFORCE, not GCAT, but it's identical to the boomless sails on other Gcats I've seen. The hulls say GFORCE also.
Back to the original subject of this thread, I picked up the Gcat originally to use the one good hull with my old Hobie. It seemed every time we went out, I always had an extra person who wanted on, and we always were a little overweight and slow. My idea was to somehow mount that good Gcat hull between the hulls of the Hobie, and have a "frankenhobie" trimaran. That way, 6 or 7 people could ride with all that bouyancy. But a couple friends repaired the bad hull of the Gcat, so that monstrosity won't see the light of day, I'll just have 2 boats instead.
[Re: FasterDamnit]
#160668 11/17/08 10:59 PM 11/17/08 10:59 PM |
Posts: 19 Mayport, FL | I sure wish I had a 21.
Mine has "5.7" molded into the top of the hulls. If the hulls of yours are wrecked, there's not much chance the tramps or crossmembers can be used on any other boat.
I'm mostly intested in the tramp(s), and other parts of the rigging and fittings that didn't go to your new boat. Large things like the crossbeams aren't that important right now.
Even if I don't need them right now I probably will later, as the grandkids, college, school, and a dozen other things take priority over my sailing hobby, so the Gcat will be my boat for a long long time.
[Re: SurfCityRacing]
#166249 01/27/09 12:02 AM 01/27/09 12:02 AM |
Posts: 19 Mayport, FL | Well, the Gcat won't make a comeback afterall. One hull is too far gone.
However, this thread is "frankenhobie", so I'm taking measurements right now for my own frankenhobie trimaran. No third rudder though. I've needed to address a few issues, the first being my back problems when sitting on the tramp all day. Second problem is always having too many guests for the Hobie. Third is the flex in the old boat. This will address all these issues. This will provide a sitting ****, room for seven without getting bogged down, and a very rigid boat.
I plan on taking the tramp off, installing bench seats along the frame sides and fiberglass panels for floorboards. The Gcat hull goes down the middle. The existing beams from the Gcat fit across the hobie's hulls, 3 beams will make a very rigid setup. The bottom of the Gcat hull sits a foot lower than the hobie when the beams are attached just as they are. I'll see if that's the right height when I try it out the first time.
I'm not changing any of the rigging or anything on the hobie, just removing the tramp. This contraption will be 8 feet wide and 20 feet long. I'm putting this project on the front burner now with the weather holding up fairly well.
[Re: BLMay]
#178454 05/17/09 01:28 PM 05/17/09 01:28 PM |
Posts: 19 Mayport, FL | I'm hogging the thread, but it's done, rigging checked and a quick cleanup, launching next weekend.
[Re: BLMay]
#182567 06/22/09 11:14 AM 06/22/09 11:14 AM |
Posts: 19 Mayport, FL | Put her in the water finally last weekend and it was a success! Not much wind, but a thunderstorm was brewing so we headed back to the boat ramp. We caught the gust front of the storm and had rooster tails coming from all three hulls, maybe 15kts, and it felt very stable and solid, no flex at all. I was trying to make the turn to the ramp and had to give the tiller all I had to turn. The sailing pics should be in soon, I'll post them up.
689
guests, and 78
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
