Performance Mid-Winters.. #171128
03/10/09 02:28 PM
03/10/09 02:28 PM
Memphis, TN
M
mikeborden Offline OP
M
Memphis, TN
Anyone going to this? CAB?
I'm thinking about going, but I won't know for sure if I can go until the last moment, Wednesday. There's other things that I should be doing, but I would like to make it to this regatta. smile
Is there anywhere close and cheap to stay? Or does anyone mind someone crashing? smile
Viper USA 132
1984 Hobie 18
Re: Performance Mid-Winters.. [Re: mikeborden] #171176
03/10/09 07:40 PM
03/10/09 07:40 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
My previous tripsB to Pensacola Beach, I stayed at at condo 3/2 full kitchen for $125 / night ....
look at www.vrbo.como
Vacation Rentals By Owner.
Works great.
USA 777
Re: Performance Mid-Winters.. [Re: mikeborden] #171392
03/12/09 07:15 AM
03/12/09 07:15 AM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
Hi Mike,
I was going to crew for Andy on his infusion. I think he has found someone else that can crew so I hope to sail my boat. I know Steve is coming over. I think Andy was also considering sailing the viper instead of the infusion. You can stay at my house if you want. I am about 10-15 minutes from the beach.
Chris
Trident F16
Re: Performance Mid-Winters.. [Re: Cab] #171431
03/12/09 10:54 AM
03/12/09 10:54 AM
Memphis, TN
M
M
Memphis, TN
Cool, I'm going to send you a pm with some details.
Viper USA 132
1984 Hobie 18
Re: Performance Mid-Winters.. [Re: mikeborden] #171565
03/12/09 10:43 PM
03/12/09 10:43 PM
smiller Offline
smiller  Offline
Mike Wilson convinced me to go to MW on Friday and set up our boats because of the large turnout. It should be a good learning experience for us - last year the f18s sailed with the open fleet.If the average windspeed is 18knots+ I will probably not race but practice tacks ,jibes,downwind sailing.Mike - consider getting another set of ratchet blocks for the spin. The sheet also hurt my hands even at 8knots but with 2 pair I felt fine this saturday at 12-14knots.Unfortunately,the non ratchet blocks on the front cross bar are riveted. You can drill the rivets out and re-rivet them or save time and destroy the Holt blocks with a hacksaw.
Re: Performance Mid-Winters.. [Re: smiller] #171567
03/12/09 11:05 PM
03/12/09 11:05 PM
Scarecrow
Scarecrow
drill them out and replace with rivnuts, that way you'll be able to easily remove them later.
Re: Performance Mid-Winters.. [Re: ] #171906
03/16/09 01:13 PM
03/16/09 01:13 PM
Memphis, TN
M
M
Memphis, TN
OK guys, It looks like I'm a go!!!
Anyone else up for it?
Viper USA 132
1984 Hobie 18
Re: Performance Mid-Winters.. [Re: ] #171926
03/16/09 03:30 PM
03/16/09 03:30 PM
Memphis, TN
Andy Humphries Offline
Memphis, TN
I have the same issue and I plan to replace my front blocks with ratchet blocks. What is a rivnut? Is that different from a screw?
Re: Performance Mid-Winters.. [Re: Andy Humphries] #172002
03/17/09 09:52 AM
03/17/09 09:52 AM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
A rivinut is a special hybrid rivet with a nut at it's core. It requires a special tool to install. It's tough to find a stainless or monel rivnut so it corrodes in the Alu beams. If possible fishing a nut and washer gooped with anticorode on a stick with a wrench is a better long term solution... all be it a huge pain in the butt to install.
crac.sailregattas.com
Re: Performance Mid-Winters.. [Re: Mark Schneider] #172004
03/17/09 10:48 AM
03/17/09 10:48 AM
Just use blind rivets and drill them out when you need to replace a part or use stainless steel screws (parkers). The latter are surprisingly strong and the little corroding that does happen between the stainless steel screw and the alu beam prevents further corrosion and locks the screw tightly in place.
Have used the screw option on my spi halyard cleat on my mainbeam. I'm pushing 5 seasons now and no troubles with either loads or corrosion.
0 registered members (), 731 guests, and 46 spiders.
