condor 16 #171133
03/10/09 03:56 PM
03/10/09 03:56 PM
jonathan Offline OP
jonathan  Offline OP
hi, i have an old condor 16, the mainsail is shot, i am wondering if anyone can suggest an alternative mainsail that would fit, the boat is just used for blasting, not racing. It would also be good to make contact with amy other conder owners
Re: condor 16 [Re: jonathan] #171215
03/11/09 05:10 AM
03/11/09 05:10 AM
UK
Cheshirecatman Offline
UK
Hi Jonathan,
The problem you have is that the Condor has a low aspect rig and quite a flexible mast. If replacing with a sail off another similar sized boat you should be prepared to visit the sailmaker to reduce luff length/area and match the luff curve to the mast. It will probably be less hassle to replace both mast and main from another cat with a more modern and more powerful rig. If you can't find one easily try contacting insurance companies for spares where boats have had hulls trashed.
Great boat the Condor. Brilliant balance and loads of bow buoyancy. They remain fast and forgiving in ridiculous conditions. A genuine single or double-handed cat decades before the F16.
Good luck
Cheshirecatman
Re: condor 16 [Re: Cheshirecatman] #171280
03/11/09 12:11 PM
03/11/09 12:11 PM
jonathan Offline OP
jonathan  Offline OP
thanks for the response cheshirecatman. where abouts are you, i live in cheshire uk, and sail at bala ?
Re: condor 16 [Re: jonathan] #171290
03/11/09 01:22 PM
03/11/09 01:22 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Have you tried Don Findlay. there used to be loads of old stuff in his garage, if you looked hard enough, you could find anything!
Re: condor 16 [Re: TEAMVMG] #187172
08/06/09 07:29 AM
08/06/09 07:29 AM
Stockers Offline
Stockers  Offline
Hi All,
I've acquired a Condor no.971 - it is indeed tremendous, and I'm fortunate enough to have a main which is in good nick, though I'm replacing a lot of the hardware. I'd be very glad to hear how many Condors (and spares) there are around, where they are and if anyone can remember how to make them go fast.....
Re: condor 16 [Re: Stockers] #187174
08/06/09 07:50 AM
08/06/09 07:50 AM
Originally Posted by Stockers
Hi All,
Talk to Andy Webb in Harwich
Re: condor 16 [Re: Stockers] #187178
08/06/09 08:58 AM
08/06/09 08:58 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Or Grant Piggot at GP sails/Nacra UK if the south coast is closer
Re: condor 16 [Re: TEAMVMG] #187193
08/06/09 10:57 AM
08/06/09 10:57 AM
Good point; Grant sailed them too; I THINK Andy has some old stuff kicking around his workshop. Depends what you are after.
0 registered members (), 684 guests, and 40 spiders.
