| Sailing count down timer for the iPhone #171388 03/12/09 06:37 AM 03/12/09 06:37 AM | James_Power
| James_Power
Unregistered | Been a cat sailor for years and used many sailing count down timers, the problem with most of them is you have to look at them to know how much time is left. I decided that what I needed was an audible count down timer that would tell me the time instead of me having to look at it. So I developed an application called AudibleTimer that does just that. You'll need an iPhone to use it but I've used it quite a few times. Of course you're wondering how I keep it dry, I bought an H2O Audio Amphibx case & waterproof earphones, which works well. You can find more details here--James | | | Re: Sailing count down timer for the iPhone
[Re: Tony_F18]
#171406 03/12/09 08:26 AM 03/12/09 08:26 AM |
Posts: 5,590 Naples, FL | I had a Timex Ironman that did something similar with it's beeping sequences...
I really liked the countdown/countup feature, so I could track my elapsed time after the start...
[Re: DennisMe]
#171421 03/12/09 09:17 AM 03/12/09 09:17 AM |
Posts: 976 France | Which Casio is that Pepin? I don't know, I leave it in my trailer box as this is the only use I have for a watch. Casio are not selling the same watches on all markets, and they are changing their model often, so I'm fairly sure you will not find the same model anyway. What I did when I bought it was to find out which Casio modules had the feature I was looking for (a countdown timer with beeping, sometimes called "Yacht Timer") and bought the cheapest watch I could find with one of those module in it. Module in CasioSpeak is the innards of the watch. There are a small number of modules, and a lot of watch designs build around each of them. PDF manuals of the various modules are available on the web, so you can double check it will work for you. Don't buy a Casio G-Shock because somebody told you it has the feature: there are countless models of G-Shock watches, and only some of them have the feature. Ask the person to tell you the module reference, it's engraved in the back. I just had a quick google look and modules 2572, 3319 and 3781 definitely have the feature for example (The first one does moon and tide, the last two are dual analog/digital modules, so probably cost a little more than the barebone version).
[Re: pepin]
#171425 03/12/09 09:30 AM 03/12/09 09:30 AM |
Posts: 976 France | I found the receipt from my watch buried in my email. It's this one. I paid £14.95 for it 3 years ago, on ebay, with shipping. | | | Re: Sailing count down timer for the iPhone
[Re: waterbug_wpb]
#171426 03/12/09 09:34 AM 03/12/09 09:34 AM |
Posts: 12,310 South Carolina | I had a Timex Ironman that did something similar with it's beeping sequences...
I really liked the countdown/countup feature, so I could track my elapsed time after the start... The garmin Foretrex does that too and has a countdown timer that you can bump up or down to the next even minute (if you are off a few seconds). It also will count up after the timer is expired. Though it does beep, they're too quiet to hear but you can download your gps track from it at the end of the day!
Jake Kohl | | | Re: Sailing count down timer for the iPhone
[Re: ThunderMuffin]
#171429 03/12/09 10:05 AM 03/12/09 10:05 AM |
Posts: 976 France | Well I guess I win the largest timer contest then: I have one of those. I must admit it is unusable as a count down timer however, as I fix it on the spin pole, way too far to click on the buttons. | | | Re: Sailing count down timer for the iPhone
[Re: pepin]
#171430 03/12/09 10:39 AM 03/12/09 10:39 AM |
Posts: 6,049 Sebring, Florida. | I've always used the Casios. They are cheap and reliable and I've lost plenty of them overboard because their one shortcoming is that wrist band. It will get hung up on stuff and get loose, then plop, it's gone. Now I put rigging tape over the clasp/buckle to keep it from getting snagged and lost. On many of my earlier Casios I would swap out the black plastic wrist band for a $5.95 Velcro band and that worked for quite a while but then the velcro got old and I lost the last one overboard! My latest model has a wrist band that is much harder to un-pin from the watch body so that is why I went with the rigging tape instead of the velcro band. I prefer the velcro band because it's softer on the wrist, but the tape works too. When it comes to adding stuff to my boat, my fist question is, Do I really need that and what's it going to cost to replace when I break it or lose it... I once raced with a collegiate racer who said they -never- use watches. I asked, "How do you know when it's time to start?" He said, "You look at the rest of the fleet and get up there in the front row with them, when they sheet in, you sheet in and go." His reasoning was you can't really tell exactly where the start line is anyway, especailly when surround by other boats and you can't see either end of the line, so get up there and go and -hope- you don't get called over early. Since then I have never paid much attention to my watch in the final 30 seconds, just concentrate on my position relative to the fleet.
Blade F16 #777
[Re: Timbo]
#171439 03/12/09 11:27 AM 03/12/09 11:27 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Matt has it down pat and wired shut. You cannot beat the Ronstan Clear Start. 1. BIG, BIG numbers to easily see. All the standard digital watches may have big numbers to tell time, but when you hit the countdown on them the minutes are big, but the seconds are very small. 2. You can switch to real time or countdown time and the countdown does not shut off and keeps counting down. 3. You can set it for any timing sequence, i.e., It has settings for 1, 3, 5, 10 etc. However, I just set mine to 1 minute and whatever the sequence might be for the day, I just hit the button that many times. If 3 min. seq., I click it three times and there is 3 minutes. Same with 5, 6, ten or whatever. 4. Best feature is when you miss the initial gun, but don't know how far off you are -- 10 seconds, 15, or what. No problem, just hit Sync at the next signal and your are right back on the money. 5.You can set it to count down to the start, and then count up elapsed time. 6. Or you can set it to countdown to the start and begin over. This is good for rolling starts, both for the racer and the RC that is timing it. 7. And it beeps like crazy. Matt forgot one thing about old timers -- can't hear either. I don't have any trouble looking at my watch during a start because I wear it on my right wrist, which normally is my sheeting hand when starting on starboard tack. As I sheet in I can bring my hand up to eye level and see the watch easily, without looking down or around. And yes, we do have them in stock on our store at www.OnLineMarineStore.com. Had to get a plug in here https://store.catsailor.com/pc/viewPrd.asp?idcategory=0&idproduct=13178Rick | | | Re: Sailing count down timer for the iPhone
[Re: RickWhite]
#171442 03/12/09 11:32 AM 03/12/09 11:32 AM |
Posts: 6,049 Sebring, Florida. | Hey, don't forget about Crew! Buy your crew a $29.95 Casio and have your Crew count down for you, then hit you if you don't sheet in at 10 seconds to go! Have crew say something like, WAKE UP and DRIVE!
Blade F16 #777
[Re: Karl_Brogger]
#171454 03/12/09 11:55 AM 03/12/09 11:55 AM | andrewscott
| andrewscott
Unregistered | I'm not sure I'm wild about taking a $500 phone on the water with me, unless its in a plastic bag, which is in a plastic bag, and all of that is placed in a drybag, and stuffed into the hull. Iphone's now cost $200 (300 for the "delux" version). I keep mine on my tramp to use the GPS application, in a $15 drypack without any problem. i do occasionally test the bag out to make sure its still waterproof. | | | Re: Sailing count down timer for the iPhone
[Re: RickWhite]
#171490 03/12/09 01:28 PM 03/12/09 01:28 PM |
Posts: 3,969 | Regardless of the watch, I always throw away the band as soon as I get it and replace it with an Animal strap. They're a one-piece, all velcro strap, and plenty long enough to fit over layers of fleece, drysuits, etc.
Because they're one-piece, if you lose a watch pin, you keep the watch because the strap is still being held on by the second pin. (Guess how I know...)
Only problem is, I don't know if they're made anymore. I bought a few at my Hobie dealer a few years ago, she thought they were out of business.
Mike | | |
527
guests, and 102
