| Re: Nacra 6.0 rigging help
[Re: Todd_Sails]
#171564 03/12/09 10:42 PM 03/12/09 10:42 PM |
Posts: 2,490 On the Water | You have the wrong beam straps on the rear beam. Those go on the front beam. More than likely the previous owner ordered/bought straps improperly. The front beam is more recessed into the hull requiring a shorter strap, hence a longer strap for the rear beam, which you don't have.
Philip USA #1006 | | | Re: Nacra 6.0 rigging help
[Re: edgerock sailin]
#171631 03/13/09 11:53 AM 03/13/09 11:53 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Will you be single handing this 6.0?
If you mean tips on the EX step system, others might.
ON my old 6.0 in the avatar, I always used to raise it myself while on the tramp and someone held the top before I started, etc. You know the routine. Years later, someone pointed out that with the weight on this mast and all, that this put a lot of strain on the tramp, tramp tracks and lacing, etc. So the last few years I had someone 'crank it up using a trap line, while I steadied it and helped it initially due to the angle and strain this put on the mast base.
Another friend that cranked his 6.0 mast from nearly the tramp, had his mast base bolt bend big time due to this.
Enjoy
F-18 Infusion #626- SOLD it!
#171681 03/13/09 05:58 PM 03/13/09 05:58 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Someone should be on the boat, so when the captive ball pin is inserted, he/she can raise and steady the mast while it's being cranked up. May be the EZ step system steady's the mast from side to side? Someone should be holding the mast about the hounds, arms over their head, while the pin is being inserted and the mast raised.
whoa there,
Were those pics of your new boat. I didn't notice any bends of significance in the front, or rear beam. Hard to notice in pics though.
The 6.0 mast, in nearly all instances, needs to be raised/lowered with the mast rotated 90 degrees, so that the captive ball mast base won't hit and break things, or get broken itself. Usually, the area that holds the pin in to keep it captive on the ball gets broke if not rotated.
Can you tell us more about the front crossbar bend. Like where on the bar exactly, what might have caused it perhaps. I'm sure we can tell if it's going to be a big problem or not. Tell us more about this please.
#173003 03/26/09 05:35 PM 03/26/09 05:35 PM |
Posts: 1,203 uk | You will probably have a simple halyard that ties to the eye in the wire to hoist the sail, then untie this one and put it somewhere safe for dropping the sail. The wire halyard will attach to a purchase that is mounted on the foil once it is hoisted.
#173166 03/29/09 02:12 PM 03/29/09 02:12 PM |
Posts: 1,383 Kingston SE South Australia | No, i dont plan to ever sail the 6.0 single handed. as for the ez stepper, i have a problem already with the front crossbeam being bent already. if the ez stepper or the winch i have on the trailer will make this worse let me know what the best way to get the mast up is. thank you. An easy way to raise a mast that I've just had shown to me is for one person to be standing on the front beam leaning back holding onto a trap wire in each hand as though they're water skiing. As the person lifting the mast raises it they get the benefit of the other persons weight pulling it up which makes the step onto the tramp easier or the lift from waist to above head. The other thing to consider is making sure your mast is sealed perfectly, when my 5.8 lost its seal and flooded the mast it took 3 of us to right it on the beach. The easiest way I've found to check for mast leaks is to tape a compressor nozzel to a hole in the bottom of the mast then when the compressors on brush soapy water on the mast and look for bubbles, works a treat and you cant over pressure the mast because the excess air just leaks out the tape. regards
580
guests, and 277
