Is a whistling sail a fast sail? #171630
03/13/09 11:48 AM
03/13/09 11:48 AM
Vancouver, BC
Tornado Offline OP
Tornado  Offline OP
Vancouver, BC
At the MidWinters last month in San Diego, we had a 15+ kt day on the Sunday. We rigged the boat to our moderate wind specs, but I went a bit tighter with the jib slot opening and kept its leech tension higher than I normally do (had a lighter crew than usual).
While double trapping before start at in first weather leg of race one, I heard a whistling sound from the front of the boat/jib. Definitely NOT rudder or board hum...my blades are extremely fine and never hum (which is slow). The sound I immediately recognized as what I had heard a few years ago in Miami at the Olympic Class Regatta when being overtaken by a pro/coached team from France. At MidWinters, our boat performs well upwind against the I20's in that kind of breeze, so it's hard to know if the whistling was a good thing. Sure felt fast as ever...and since the Pro teams were tuning to that point, can it be a bad thing?
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Is a whistling sail a fast sail? [Re: Tornado] #171633
03/13/09 12:07 PM
03/13/09 12:07 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Depends on the tune.
Re: Is a whistling sail a fast sail? [Re: ksurfer2] #171634
03/13/09 12:19 PM
03/13/09 12:19 PM
Lakewood, Colorado
MUST429 Offline
MUST429  Offline
Lakewood, Colorado
It whistles for the same reason some people humm...... they don't know the words.
Life is not about waiting for the storms to pass...
It's about learning to dance in the rain
Re: Is a whistling sail a fast sail? [Re: MUST429] #171643
03/13/09 01:23 PM
03/13/09 01:23 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Was it in 3/4 or 4/4 time?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Is a whistling sail a fast sail? [Re: hobie1616] #171650
03/13/09 02:03 PM
03/13/09 02:03 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
If it whistles upwind make sure the pitch is in the Key of A. B is for a reach and C is for the down wind.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Is a whistling sail a fast sail? [Re: F-18 5150] #171654
03/13/09 03:03 PM
03/13/09 03:03 PM
RickWhite Offline
RickWhite  Offline
As a retired musician, I must say you really got some highly technical answers here. What a group, eh? grin
Rick White
www.onlinemarinestore.com
Re: Is a whistling sail a fast sail? [Re: RickWhite] #171659
03/13/09 03:29 PM
03/13/09 03:29 PM
I've had the downhaul tight enough upwind to get a little "zerbert" sound off the leach of the upper batten when we're cranking double trapped upwind... Is that the same type of noise?
I've also gone fast enough on a broad reach to get a little whistling through the rigging... is it like that?
Re: Is a whistling sail a fast sail? [Re: Tornado] #171704
03/14/09 12:03 AM
03/14/09 12:03 AM
Minnesota
Jeff Peterson Offline
Minnesota
My guess is that you own a male sailboat. Usually you can tell this by the drab colored sails. Were you in the vicinity of a sailboat with brightly colored sails? This would be a female boat. I think your male boat was whistling at the female boat.
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Is a whistling sail a fast sail? [Re: Tornado] #171743
03/14/09 03:39 PM
03/14/09 03:39 PM
Seattle,Wa
Don_Atchley Offline
Don_Atchley  Offline
Seattle,Wa
Whistling is something vibrating.
Vibration is bad.
Ergo, whistling is probably bad.
Hobie Tiger 2003
Re: Is a whistling sail a fast sail? [Re: Don_Atchley] #171744
03/14/09 03:44 PM
03/14/09 03:44 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
I always heard the rudder/board hum was not good also.
In your original post, you mentioned rudder hum being good. Please explain. (no need to cite links)
F-18 Infusion
#626- SOLD it!
Re: Is a whistling sail a fast sail? [Re: Todd_Sails] #171766
03/15/09 04:11 AM
03/15/09 04:11 AM
Vancouver, BC
Tornado Offline OP
Tornado  Offline OP
Vancouver, BC
My OP: "my blades are extremely fine and never hum (which is slow). "...meaning that humming blades are slow/bad. Tornado blades are extremely fine on the trailing edges (typically <1/16th") and do not hum.
My thought on the sail whistle is that I may be jamming up the jib slot to the point where wind is generating a vortex as it moves through or past the slot. Getting more air acceleration between main & jib is a good thing...might a vortex/swirl have a benefit?
Typically you want the slot open more in winder conditions...but knowing how much is key and maybe I've always gone too open too soon.
Mike Dobbs
Re: Is a whistling sail a fast sail? [Re: Tornado] #171853
03/16/09 08:52 AM
03/16/09 08:52 AM
Houston
carlbohannon Offline
Houston
I have had the whistling sound on a couple of boats. I was able to track the sound to the control lines for jib tension. After a while I decided that on one boat I was too tight and on the other boat I was not tight enough. The sound went away, when I replaced the sails.
Re: Is a whistling sail a fast sail? [Re: carlbohannon] #171920
03/16/09 02:52 PM
03/16/09 02:52 PM
Scarecrow
Scarecrow
When tuning the rudders I always go for an augmented chord and for the rig I go for a diminished chord. The problem is if they both sing at the same time you end up with a demented chord.
Re: Is a whistling sail a fast sail? [Re: ] #171922
03/16/09 03:06 PM
03/16/09 03:06 PM
train whistle!
Re: Is a whistling sail a fast sail? [Re: Todd_Sails] #171962
03/16/09 09:17 PM
03/16/09 09:17 PM
Tampa, Fl
deepsees Offline
deepsees  Offline
Tampa, Fl
I used to sail a Sol Cat that got to humming at around 15 mph. It has to be the wires... nothing else can set up such a fine vibration that it is heard and not felt. Rudders would certainly be felt in the tiller. Rudder flutter would also be subject to specific loading... so if the whistle is at same speed be it what ever reach... rudder loading would be different in different reaches.
Additionally... vibrating could be the air stream uniting at the back of the stays. Like a flute.
Deepsees
Re: Is a whistling sail a fast sail? [Re: Tornado] #171973
03/17/09 04:48 AM
03/17/09 04:48 AM
catman Offline
catman  Offline
Possibly the air moving past the luff track?
Re: Is a whistling sail a fast sail? [Re: catman] #171987
03/17/09 08:15 AM
03/17/09 08:15 AM
andrewscott
andrewscott
Your not wearing a ball cap with a propeller on top are you?
0 registered members (), 2,533 guests, and 195 spiders.
