| Re: jib traveler on hobie 17 question
[Re: PSAILOR]
#17167 03/15/03 02:16 PM 03/15/03 02:16 PM |
Joined: Mar 2003 Posts: 736 Westport, Ma. U.S.A. Brian_Mc
Posts: 736 Westport, Ma. U.S.A. | I tried to post this a few days ago, sorry I must've screwed up! I have a 17 I put the Murrays' Super Jib, and hardware on. I believe the "Super Jib" is an 18 jib. You have to mount the traveller tracks on the tramp rails, due to the sail overlap with the main. If you do this,USE STAAINLESS BOLTS WITH NYLOCK NUTS, and WASHERS, NOT RIVETS! I've done it both ways on seperate boats, and the bolts are easier, and are less likely to crack the fiberglass even if you back up the rivets with washers so they don't pull through. I find the jib is great downwind, and increases the capacity of the boat. In good wind I can take two adult passengers. I would like to get a mesh tramp for my current boat, as the "canvas" is in the water with almost any crew weight at all on it down wind, and you feel like your in a shallow jacusi. Had one great ride with a beatiful blonde last year, we were sailing downwind, and the jib got a gust just right. It felt like we had a chute up! What a blast! Feel free to contact me via e-mail with any questions. Good luck! Brian | | | Re: jib traveler on hobie 17 question
[Re: PSAILOR]
#17170 03/16/03 02:06 AM 03/16/03 02:06 AM |
Posts: 736 Westport, Ma. U.S.A. | Mike, I did drill through the metal, and the glass lip. I don't think it has caused any structural problems. I also sealed the holes with West System epoxy as I went so water wouldn't seep into the glass. The two jibs, and seperate mountings sound OK, though since the "Super" is roller furling, I don't see the need for the smaller one. I don't recommend taking two adults, since the hulls aren't boyant enough to keep the tramp out of the water unless you are flying a hull, but I have done it several times, and as long as the wind was over 12 knots it was still fun. I still like to sail it solo, as the tramp dragging can really slow you down, but the added power of the jib makes taking a date along a really fun option. I have the Calvert Boomless Square Top on mine, and love it! I am going to add the Hawaiian Righting System so my crew will have a "sissy line" and make righting easier, and I am going in for the Wave Mast Float. I think the dangers of turtling, or having crew stuck under the sail during a capsize more than make up for any flack my friends give me.The one drawback to the Kit and sails was very limited instructions, and that Calvert and Murrays both forgot parts on mine. Calvert forgot the jib halyard cleat, and Murrays forgot the jib blocks. Also I had expected the Square Top to come with a window, and had to send it back at considerable expence. Be sure to order it with the window from the begining! They were both quick to rectify the minor problems, and I find them both great companies to do business with. The one thing I haven't figured out is mast rotation control without the boom. I got the Murrays kit for that too, but it doesn't provide any way to keep the mast from over-rotating. | | | Re: jib traveler on hobie 17 question
[Re: MauganN20]
#17172 03/16/03 12:36 PM 03/16/03 12:36 PM |
Posts: 117 | This is a picture of my old H17 I had when I lived on Guam a few years abo. The sails are H16 sails, the main was re-cut and I had a zipper added to the jib. The H16 jib seems like a performance booster over the stock H17 jib, slightly larger. I had considered using the H16 jib on the one I am building now. I did not use the battens so I could furl it, so it fluttered a little along the edge. I used the stock jib cleat locations with this jib. I also installed a mast float (baby bob) ith modified mounting bracket. I can provide details if you were interested, Brian.
473
guests, and 38
