| Re: Fiberglass repair
[Re: CBrown]
#17194 03/11/03 11:01 AM 03/11/03 11:01 AM |
Posts: 215 Ohio | Chris, I would not use epoxy if you are going to gelcoat over it. Gelcoat is just polyester or vinylester resin with pigment added... Epoxy will stick well to poly and vinyl but not the reverse. I would stick to a poly or vinyl repair. It is also cheaper.
Mike, Ohio Former H16, H18, N20, N17, M4.3
[Re: TeamTeets]
#17195 03/11/03 01:04 PM 03/11/03 01:04 PM |
Posts: 85 | I'm always happy to chime in with a contrary opinion, so here goes....
vinylester/polyester is cheaper to be sure, but in my experience it's temperamental with regard to mix ratio and curing conditions (temperature, humidity, etc).
Epoxy on the other hand is tough to screw up. the mix ratios are 1:1 or 2:1 or 5:1 instead of 40:1 for polyester, so you can be off by a little and still be OK. System Three epoxy in particular has given me good results in some really crappy weather conditions, and they sell small-repair kits so you don't need to invest in the full $80 gallon of resin. Of course, you can't apply gelcoat over the repair, but that's a non-factor to me since I hate gelcoat anyway. i can never seem to get the color right.
If you have white hulls, I'd suggest an epoxy repair with a painted finish. the beauty of paint (particularly spraypaint) is that you can feather out the edges to blur the boundary of the repair, which makes color matching less critical.
Either method, it's important to work with a smile on your face. If you're all cranky and frustrated while performing the work, it will show in the final product. cum ba yaaaaaaa.... | | | Re: Fiberglass repair
[Re: Sailortect]
#17197 03/11/03 01:52 PM 03/11/03 01:52 PM |
Posts: 12,310 South Carolina | Has anyone thought about, or tried to, add tint to epoxy? If you have white hulls and could just tint the epoxy white...viola! No gelcoat necessary. It's certainly possible to achieve a nice smooth finish with epoxy (although it does take some doing).
Jake Kohl | | | Re: Fiberglass repair
[Re: Sailortect]
#17202 03/11/03 05:18 PM 03/11/03 05:18 PM |
Posts: 215 Ohio | A tip on mixing poly and vinyl resins: add the hardner and begin mixing ... when you think it is thoroughly mixed you are exactly half way done.
[Re: CBrown]
#17203 03/11/03 06:09 PM 03/11/03 06:09 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Use the vinylester. Buy the red tinted MEK so you can see it's mixed. It is not hard to kick properly. Make sure the ambient air temp. is within whats called for and have at it. Vinylester is a good product.
967
guests, and 42
