| h17 rear cross bar traveler? #17224 03/12/03 08:26 AM 03/12/03 08:26 AM |
Joined: Aug 2002 Posts: 148 Charleston SC h17windbtch6333 OP
Posts: 148 Charleston SC | after my rear cross bar developed a crack originating from the bolt hole on the bottom, i have found a used one for sale. this one i have found has a harken traveler rail and car mounted on it. see photo. does this system work well? has anybody had experience with this set up?
| | | Re: early H17
[Re: samevans]
#17228 03/13/03 02:59 AM 03/13/03 02:59 AM |
Posts: 917 Issaquah, WA, USA | Sam, since 1995 the H-17 has had the deep profile traveler track. The first H-17's had a lower profile track. The Harken track system was provided for a couple of years, I think 1993 and 1994, check with Hobie. It was my understanding if your boat was furnished with the Harken system, it was class legal. It could not be added to another boat, also it was shorter, and some felt they could not sheet out as far.
Caleb | | | Re: early H17
[Re: CMerrell]
#17234 03/14/03 12:12 PM 03/14/03 12:12 PM |
Posts: 917 Issaquah, WA, USA | We found early on, in 1986, that keeping the crossbar bolts tight was critical. They must be tighten EVERY day. The other critical point is the end cap, screwed to the hull. If the end cap is not secure, damage will occur. Easy check, while on the water, put you hand on the end of the cross bar where it is attached to the hull. If there is any movement between the two, fix right away. With proper maintenance, the cross bar should not fail.
Caleb Tarleton | | | Re: h17 rear cross bar traveler?
[Re: h17windbtch6333]
#17235 04/01/03 01:24 PM 04/01/03 01:24 PM |
Posts: 38 | I "Had" the Harken system fitted, but after a capsize the wind shook the main and the Harken track was promptly removed  ....the reason being the Harken track is screwed to the Crossbeam....then corrosion set in...you can guess the rest....now i've got the Deep Profile that is riveted....much more secure  . Happy Sailing Nige | | |
1,986
guests, and 437
