Page 1 of 3 1 2 3
flaking the spinnaker #172268
03/19/09 07:24 AM
03/19/09 07:24 AM
pgp Offline OP
pgp  Offline OP
Anyone know an easy way?
Pete Pollard
Blade 702
Re: flaking the spinnaker [Re: pgp] #172273
03/19/09 08:11 AM
03/19/09 08:11 AM
andrewscott
andrewscott
I am sure i will get grief for posting here since yesterday i said i don't often flake my spin... but i have, and i do flake my jib... so here goes...
Get a helper....(it is possible solo, but easier with help)
lay the sail out as flat as you can.
start at the foot... and fold in 2.5' - 3' sections on top of each other (accordion style) till you get in to the head of the sail.
Thats about all there is to it...
Re: flaking the spinnaker [Re: ] #172283
03/19/09 08:46 AM
03/19/09 08:46 AM
pgp Offline OP
pgp  Offline OP
Mine came flaked in a nice bag. Of course I didn't bother to take notes when first ripping into it! I've tried several different approaches, none fit the original, which I assume is the best way.
Pete Pollard
Blade 702
Re: flaking the spinnaker [Re: pgp] #172307
03/19/09 12:01 PM
03/19/09 12:01 PM
Until somebody tells me just why flaking the spi is going to extend its life, I'll not bother smile
Re: flaking the spinnaker [Re: Rolf_Nilsen] #172308
03/19/09 12:09 PM
03/19/09 12:09 PM
andrewscott
andrewscott
I can only guess that if its flaked well (and tight) there are less "bends" in the fabric, and leads to less wear (and less creases) over the life of the spin.. but that is just a guess...
Re: flaking the spinnaker [Re: ] #172311
03/19/09 12:35 PM
03/19/09 12:35 PM
mikekrantz Offline
mikekrantz  Offline
Take 3 sheets of paper.
Wad one up in a ball.
Fold one up, just like you would flake a spin.
Leave one sheet alone.
Now smooth the ball out and lay it on the unfolded paper.
Now smooth the flaked paper out on the unfolded paper.
Which piece smooths out closest to it's original size...
Do this 100 times, which piece falls apart first...
Re: flaking the spinnaker [Re: mikekrantz] #172312
03/19/09 12:39 PM
03/19/09 12:39 PM
Memphis, TN
M
mikeborden Offline
mikeborden  Offline
M
Memphis, TN
Man, that is a perfect example!!
Viper USA 132
1984 Hobie 18
Re: flaking the spinnaker [Re: Rolf_Nilsen] #172313
03/19/09 12:44 PM
03/19/09 12:44 PM
That's kinda where I'm at. I stuff mine in a bag, its gotta be easier on it than pulling it into the snuffer when its being used. It does get stored hanging up in my basement though, but thats more to make sure its dry than anything.
Re: flaking the spinnaker [Re: mikekrantz] #172316
03/19/09 12:48 PM
03/19/09 12:48 PM
I snuff my spi into a bundle about 10 times a racing day; why would not doing it once more at the end of the day into a very roomy bag make any difference ?
Typically, it goes into its bag as it sat in the snuffer. I use a small replacer line for the retrieval line and tie the corners together. This also allows me to hook it back on the boat much faster.
Re: flaking the spinnaker [Re: Karl_Brogger] #172317
03/19/09 01:02 PM
03/19/09 01:02 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
This subject really isn't debate worthy. Either you think flaking has value or you don't. At the end of day it's your spin, time and checkbook.
F18 USA 242
http://www.solarwind.solar
Re: flaking the spinnaker [Re: David Ingram] #172324
03/19/09 01:37 PM
03/19/09 01:37 PM
Is this you trying to stop a debate?
Re: flaking the spinnaker [Re: Jake] #172326
03/19/09 01:40 PM
03/19/09 01:40 PM
Clermont, FL, USA
Clermont, FL, USA
Do we really need another Dill Baby Drill thread?
F18 USA 242
Re: flaking the spinnaker [Re: David Ingram] #172327
03/19/09 01:45 PM
03/19/09 01:45 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Well, FWIW, mine was always stored in the homebrew snuffer I had made for the low bow foil on a Nacra 6.0na.
When rigged, the end of the pole had a spectra line to each hull tip, which ended in a hole drilled thru the front of the bow.
I would undo one side of this bridle, so the whole pole with snuffer attached would get past the upright mast support on the front on the trailer near the tongue.
So my spin was stored, in the snuffer, with all lines except the halyard attached.
Which made for some great rigging and breaking down times!
It wasn't stuffed in, and it really wasn't folded either. It was out of the sunlight as my snuffer was a black plastic tube.
It was so nice just to attach the halyard to the head, and that's all there was to rigging the spin!
F-18 Infusion
#626- SOLD it!
Re: flaking the spinnaker [Re: David Ingram] #172328
03/19/09 01:45 PM
03/19/09 01:45 PM
andrewscott
andrewscott
Flake Baby Flake - Tony the tiger says "There Greaaaaat"
Re: flaking the spinnaker [Re: mikekrantz] #172335
03/19/09 02:29 PM
03/19/09 02:29 PM
I was told this example, but it went further than that...
Hold the 4 corners of the paper (you'll need a mate to help) and then drop a heavy ballbearing into the middle.
Does the crumpled one tear? Nope; does the folded one? Yes
IF you fold in the same place, you make certain points very weak because they are folded in the same (or similar) place many times. Stuffing it in the bag creates more folds, but they are smaller and more distributed and so the weakness is more spreadout.
Re: flaking the spinnaker [Re: scooby_simon] #172345
03/19/09 03:11 PM
03/19/09 03:11 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
Unless you have a problem with things flying into the middle of your spin I'm not sure how this is relevant. I think the point is to make a simple effort to keep the spin as crisp as possible.
Re: flaking the spinnaker [Re: BLR_0719] #172352
03/19/09 03:58 PM
03/19/09 03:58 PM
But is it worth the 10 minutes extra packaging time, and the extra rigging time if flaked compared to the method Wouter described? Seems like the jury is still out on this one. I know what I will continue to do smile
Pete, I always just folded the spi along the foot first, then working up the length of it. Easy if there is no wind and two persons. Takes a bit longer if alone. Impossible without substantial effort if there is lots of wind.. Usually, I just stuff it in a large bag if it is dry. If it is wet, we hang it to dry in the boathouse THEN stuff it into the bag smile
Re: flaking the spinnaker [Re: BLR_0719] #172353
03/19/09 04:01 PM
03/19/09 04:01 PM
The point is that flaking the sail makes less areas that are damaged/weak. But the areas that are damaged/wear are more damaged and so failure change is greater.
Re: flaking the spinnaker [Re: scooby_simon] #172354
03/19/09 04:04 PM
03/19/09 04:04 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Hey Anyone need to buy a Spin. I know someone who makes a nice one at a good price. From the sound of this thread alot of people need one.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: flaking the spinnaker [Re: F-18 5150] #172358
03/19/09 04:12 PM
03/19/09 04:12 PM
andrewscott
andrewscott
Apparently thats me! How much? what is it made from? Brand new? details, pics, etc smile
(PS i fly a Tornado sized spin)
Page 1 of 3 1 2 3
0 registered members (), 2,657 guests, and 440 spiders.
Yesterday at 10:10 AM
