How do you place decals on main sails? #172939
03/26/09 12:06 PM
03/26/09 12:06 PM
andrewscott
andrewscott
i am just curious what are the methods of adding decals to sails?
Re: How do you place decals on main sails? [Re: ] #172942
03/26/09 12:18 PM
03/26/09 12:18 PM
dacron or mylar (pentex)?
Re: How do you place decals on main sails? [Re: ] #172946
03/26/09 12:28 PM
03/26/09 12:28 PM
France
pepin Offline
pepin  Offline
France
Felt tip pen. Big fat one. I love the smell of those...
Re: How do you place decals on main sails? [Re: pepin] #172951
03/26/09 12:37 PM
03/26/09 12:37 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
That explains alot. grin
Isak Dinesen
E. B. White
Re: How do you place decals on main sails? [Re: Team_Cat_Fever] #172953
03/26/09 12:44 PM
03/26/09 12:44 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
At least he doesn't eat them like you do Todd.
Re: How do you place decals on main sails? [Re: Jake] #172956
03/26/09 12:52 PM
03/26/09 12:52 PM
if pentex, put them on dry...lining them up is tricky.
With the backing paper and full mask tape on the graphic, place it where you want it on the sail. Using some 1" masking tape, tape the top of the graphic to the sail with several pieces of masking tape. You've just made a hinge. Flip the graphic upside down hinging on the tape, remove the backing paper, and then carefully swing back into place and start rubbing it down from the center out. Once you've rubbed it into place, a rubber roller on a stick is very useful to fully press the graphic into the texture of the pentex.
If you are aligning a second graphic to the first with some overlap, remove the backing paper from the graphic and reapply it leaving a .25" reveal of the adhesive of the piece you are applying. The backing paper will keep the rest from sticking while you line it up with the graphic already on the sail. Carefully line up the graphic looking through the mask tape and stick the .25" you exposed. Then use THAT as the hinge, flip the graphic over, remove the backing paper, and squeegie/press into place.
Don't use application fluid when putting them on the sails. It will take 10 hours to dry before you can remove the mask tape and move onto another graphic.
Lastly, it REALLY helps to have one or two people help to hold up the ends of long graphics and keep the sail flat while you start to press them down. However, those people need to understand how to feed slack to the areas that are being pressed down while keeping the graphic taught. They can be either a huge help or a big wrinkle maker.
Re: How do you place decals on main sails? [Re: Jake] #172959
03/26/09 01:07 PM
03/26/09 01:07 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Anyone know where pre-cut sail numbers & lettering can be obtained? I've got a deal underway for some new flapping things and will want to swap out the numbering.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: How do you place decals on main sails? [Re: Tornado] #172970
03/26/09 02:32 PM
03/26/09 02:32 PM
andrewscott
andrewscott
by these answers i guess all (or most) decals have an adhesive backing.
i wasn't sure if some were stitched on, or under a uv layer that is part of the cloth.
thanks all...
Re: How do you place decals on main sails? [Re: ] #172971
03/26/09 02:38 PM
03/26/09 02:38 PM
thanks all...
Almost always sticky-backed...they don't work for spinnakers though.
Re: How do you place decals on main sails? [Re: ] #172977
03/26/09 03:22 PM
03/26/09 03:22 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Verrr rr rr rrr rrr rr y carefully.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: How do you place decals on main sails? [Re: Tornado] #172989
03/26/09 04:14 PM
03/26/09 04:14 PM
Scarecrow
Scarecrow
numbers can be supplied by your local sail maker, they get apprentices to cut out batches when the floor doesn't need sweeping.
Other stuff your local sign writer.
If its for a kite you need an overhead projector and a big wall. Project the image onto the kite and trace with the above mentioned nice smelling, edible pen and then paint by numbers.
Re: How do you place decals on main sails? [Re: ] #172994
03/26/09 04:43 PM
03/26/09 04:43 PM
andrewscott
andrewscott
YOu eat those pens?
Re: How do you place decals on main sails? [Re: ] #172999
03/26/09 05:04 PM
03/26/09 05:04 PM
Scarecrow
Scarecrow
Read the whole thread, particularly Undecided's post.
Re: How do you place decals on main sails? [Re: ] #173001
03/26/09 05:25 PM
03/26/09 05:25 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Some one-design classes require certain sized sail numbers, so watch it. Don't ask me how I know. Oh...wrong thread.
Also if you hit the sticky-back with a little heat it will stick forever. Hair dryer, heat gun (carefully) etc. You're really just warming it up.
Re: How do you place decals on main sails? [Re: SurfCityRacing] #173019
03/26/09 07:46 PM
03/26/09 07:46 PM
Petaluma, CA
David_Melcon Offline
Petaluma, CA
Re: How do you place decals on main sails? [Re: David_Melcon] #173043
03/27/09 07:56 AM
03/27/09 07:56 AM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
The first time I put numbers on a sail, I used the 7-segment numbers from LayLine. I didn't much like how those looked, so since then I've cut out numbers (et. al.) with shears. Next time, I'm planning to laser-cut them.
Eric
Re: How do you place decals on main sails? [Re: Isotope235] #173044
03/27/09 08:07 AM
03/27/09 08:07 AM
Eric
Any sign shop (mine included) can make numbers for sails quite easily and in any color.
Re: How do you place decals on main sails? [Re: Jake] #173106
03/27/09 08:15 PM
03/27/09 08:15 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Here is my 2 cents worth since I have the large graphic. Per Dave Posey, of Posey Sails, man I miss him but you can't work forever. The best material is what they call insignia or number cloth. It is sailcloth with a sticky backing. I’ve never had it come off. I’ve also used the Mylar or plastic and have it come off. The Palm Tree on my sail is insignia cloth (not sure what I used as a pattern for the leafs). The sun is plastic and had it peel once. My sail is monofilament so I’m guessing plastic sticks better to it then it would to regular type sails. I used a little water under it to slide the sun around some then a squeegee and that worked all right. I was sailing several hours after applying it, just the time to drive to the beach and rig the boat.
If you have access to a sail maker try to get the insignia cloth. I made the pattern out of construction paper. All you have to do is flip it for the other side. If you look on my website you can how large the graphic is and how it looks.
Mike Shappell
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: How do you place decals on main sails? [Re: Jake] #173141
03/28/09 07:43 PM
03/28/09 07:43 PM
I
Isotope235 Offline
Isotope235  Offline
I
Well, since Joleen (my wife) sews sails, I have access to the materials, and since I have a laser cutter, I'll make the logos and numbers myself. It won't cut pvc, but dacron should be fine.
Eric
Re: How do you place decals on main sails? [Re: TheManShed] #173176
03/29/09 07:05 PM
03/29/09 07:05 PM
Mike Shappell
If applying vinyl graphics to a mylar sail, try not to use application fluid - rather apply them dry. If you have to use application fluid, give them at least 48 hours to dry and rub them down again after that period before using them.
I own a vinyl graphics business and I've used a LOT of vinyl graphics on sails. Only once did I have any come off....but that one was "sanded" off the sail as it was beached on it's side and I'm not sure much of anything would prevent that!
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
