| How to build a boom? #173380 03/31/09 01:31 PM 03/31/09 01:31 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit OP
Posts: 531 Lake Murray SC | I have a 2" carbon tube that can be a nice boom. F17 main and mast (once repaired).
What do I need to build it right?
I have an TheMightyHobie18 boom janging in the garage for parts.
gooseneck, some kind of outhaul setup, fitting/loop for mainsheet. Anything else?
details appreciated. thanks.
E-Scow 24' ULDB
| | | Re: How to build a boom?
[Re: FasterDamnit]
#173388 03/31/09 02:57 PM 03/31/09 02:57 PM | Scarecrow
| Scarecrow
Unregistered | Gooseneck.
Try and find a fitting that has a male part attached to the mast and then a socket in the boom. Lay up a composite socket (wrap the gooseneck fitting in tape and use it as the mould and then bond it into the end of the boom.
Outhaul.
Cut a "V" groove in the back end off the boom. depending on thewall thickness of the tube you might want to build it up a bit. Tie a line onto the clue and put a couple of knots in the rpoe to put in the groove.
As you said a webbing loop for the clew.
Job done. | | | Re: How to build a boom?
[Re: FasterDamnit]
#173398 03/31/09 07:00 PM 03/31/09 07:00 PM |
Posts: 1,200 Vancouver, BC | So, depending on how you rig the clew attachment, you might need a beefier gooseneck than have been suggested here so far. If you've got the clew attached to the boom, with the mainsheet attached at a different location, say near the boom end, then boom will experience a lot of compression loading when the main is sheeted hard. You'll need a sturdy gooseneck to handle it. Might be wise to adapt an exisitng gooseneck to work on your boom section. Here is an example of this setup: As the main attachment is placed further aft, compression loading increases as the blocks/sheet angle to the rear beam goes well past vertical. You need some angle to get reasonable mast rotation. If you use a webbing strap around the boom, with the clew attached above and the main blocks attached below to the same strap you can minimize the compression loading, but might loose mast rotation stability, esp. in lighter air. Here's an example:
[Re: FasterDamnit]
#173544 04/01/09 06:27 PM 04/01/09 06:27 PM |
Posts: 1,200 Vancouver, BC | If the clew and main are on the same strap, the outhaul then pulls both back? Is that any benefit? If on the same strap, then you will increase the sheeting angle as you apply more outhaul...which is loosely tied to how much wind you have...more wind more outhaul. So, having more sheet angle in more wind is not a problem and can help with mast rotation in certain conditions (choppy in light to moderate winds are where you get lots of rotator slap). But when you are inlight stuff, and you apply less outhaul, your sheet angle will also be less or nearly vertical, so you're mast flopping will not be prevented. On the photos I showed above with the outhaul's external to the boom, there are no methods for actually pulling the clew forward when the outhaul is eased. Nearly all boats I've sailed have the outhaul control lines internal to the boom with a small traveller car or plate the the clew attaches to. There is also a line or cable attached to a large diameter bungie (all in side the boom) that provides in-haul when the outhaul line is eased. Not sure how much the webbing or lashing straps shown in the picture will actually move when the outhaul is eased.
[Re: pepin]
#173564 04/01/09 09:44 PM 04/01/09 09:44 PM |
Posts: 1,911 South Florida & the Keys | When flying a chute down wind, is there a need to use outhaul at all? The main is acting as the stay, traveler near center, can we minimize the importance of outhaul except in the lightest air?
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: How to build a boom?
[Re: arbo06]
#173567 04/01/09 09:53 PM 04/01/09 09:53 PM | Scarecrow
| Scarecrow
Unregistered | Definately, particularly because as mentioned above the cuningham effects the foot tension anyway, so dumping cunno at the top mark also softens the foot. Thats why I suggested a simple knot and groove outhaul system. | | |
477
guests, and 37
