| Re: Vintage Hobies
[Re: _flatlander_]
#136640 08/18/08 09:03 AM 08/18/08 09:03 AM |
Posts: 321 Albuquerque NM | Sam, As far as the crew age goes, HCANA rules have master and grand master established. I was trying to be funnieeee, does the crew and or captain have to be Vintage? also Snoop, welcome aboard, hope you enjoy that new to you H16. Sam
[b] Sail Like you have a Pair
| | | Re: Vintage Hobies
[Re: Banzilla]
#136641 10/03/08 07:15 PM 10/03/08 07:15 PM |
Posts: 19 Mayport, FL | Mine has all the original hardware, no comp tip. Fairly well worn. If I see other hobies around, I hide. In fact, I'm down to one cleat left on the mast.
My Gcat is original also, and it was a rental. Makes the hobie look like a yacht. It might be ready for the water next spring.
1982 Hobie 16 modified | | | Re: Vintage Hobies
[Re: Cousin_Eddy]
#157550 10/18/08 05:11 PM 10/18/08 05:11 PM |
Posts: 5,582 “an island in the Pacifi... | I have a '75. It has white with blue top hulls, original sails in excellent condition, hulls are excellent. Original hardware mostly. I was told at a regatta last weekend that it is a collector Hobie. Is there such a thing? I was fixing to add all the latest stuff to it like comp tip, gudgeons, traps, stays...etc. Should I leave it orginal?
Depends. Do you want a Plastic Classic or do you want to race? If you want to race, will the investment in upgrades eventually be more than what the boat is worth? And, will the investment in upgrades boost the performance to be able to compete with newer boats? US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Vintage Hobies
[Re: Cousin_Eddy]
#157599 10/19/08 02:58 PM 10/19/08 02:58 PM |
Posts: 5,582 “an island in the Pacifi... | What is the disavantage of an older boat for racing besides dated hardware? Are they heavier or something? Manufacturing processes have changed over the years that resulted in lighter hulls. The red glue models were so light the factory was putting lead weights in the forward pylons. The few who discovered that little trick simply pulled the foam plug out and removed the lead. If you have an older boat that is close to minimum weight, go with it. Next step is make sure the crossbars are not flexing as the pop rivets will wear. Replace them as needed. Then it's time for new hardware. I'd do the following. New sails - They get blown out. Period. It's amazing how your boat speed will improve. There's a number of schools of thought on where to place tell tales. Once you decide on the best location for you, have windows installed. Harken low profile blocks for the main sheets. Aussie 3:1 jib halyard. Jib outhaul system. Double trap setup if you don't already have one. Don't use dogbone rings unless you like getting hit in the face. Forestay bridle fly. An excellent tool when reaching. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Vintage Hobies
[Re: jkkartz1]
#165140 01/16/09 12:02 PM 01/16/09 12:02 PM |
Posts: 1,187 38.912, -95.37 | I've got a piece of 16 mast from a Comp Tip install waiting for a project. Your's may be it.
Do you want it?
Jack I have been unable to locate a broken Hobie 14 mast to donate mast section for new pylons
| | | Re: Vintage Hobies
[Re: Skunky]
#167398 02/05/09 03:28 PM 02/05/09 03:28 PM |
Posts: 1,152 tampa, fl | Speaking of vintage hobies, when I was just a kid back in the 70's, my dad bought a brand new 16 #44726. Yellow hulls with a scripted name "Lollypop" painted boldly on each side. He sailed the boat extesively at the Hobie beach in Sandy Hook, NJ in the late 70's and early 80's. The boat was sold in the early 80's. I would love to find out what happened to it. Any one here ever seen, or know of the boat?
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Vintage Hobies
[Re: Skunky]
#167448 02/06/09 09:37 AM 02/06/09 09:37 AM |
Posts: 1,187 38.912, -95.37 | Anyone know how to age the hulls without resorting to cutting them in half and counting the rings?
Ben Ben, Don't be confused by the sail numbers. Many classes assign sail numbers that correspond with the boat and when new sails are purchased the original sail number is used. This is not the case with Hobies. Here's the link for hull identification
| | | Re: Vintage Hobies
[Re: Jeff Peterson]
#173168 03/29/09 03:12 PM 03/29/09 03:12 PM |
Joined: Jan 2009 Posts: 20 Pasadena, MD, USA Chesicat
Posts: 20 Pasadena, MD, USA | Anybody care to help me determine the age/vintage of my H16? I really do need some help with this.
The only thing I can find is the number 389 stamped into the forward pylons. The crossbar is also stamped infront of the ss tracks with the numbers 0 (nearest the mast) thru 8 (outermost point of the track) I imagine for setting jib travelers)
Scott
Oh Jeez! Now What!?!
| | | Re: Vintage Hobies
[Re: Chesicat]
#173352 03/31/09 09:47 AM 03/31/09 09:47 AM |
Posts: 921 Alachua, FL | Anybody care to help me determine the age/vintage of my H16? I really do need some help with this.
The only thing I can find is the number 389 stamped into the forward pylons. That is your hull number and it was built in 1971.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Vintage Hobies
[Re: Mugrace72]
#173418 03/31/09 08:51 PM 03/31/09 08:51 PM |
Posts: 20 Pasadena, MD, USA | Jeez! So, does that make me the winner/loser of the vintage cat? No wait I saw a lower three digit number...
Wow, a '71 and the hulls are rock solid. Jack, any ideas on the crossbar markings?
Scott
661
guests, and 1,366
