| Re: alternate brummel
[Re: tami]
#173978 04/06/09 11:31 AM 04/06/09 11:31 AM |
Posts: 5,525 | Cool! I'll give it a try. Thanks.
Pete Pollard Blade 702
[Re: davefarmer]
#175993 04/24/09 11:12 AM 04/24/09 11:12 AM | andrewscott
| andrewscott
Unregistered | That was pretty easy! MUCH easier than pulling line through itself .
Thanks Tami~! | | | Re: alternate brummel
[Re: ]
#176032 04/24/09 04:47 PM 04/24/09 04:47 PM |
Posts: 2,921 Michigan | I use a bastardized brummel (aka tuck splice?) where I just pull the line through itself twice then bury it. I don't use them for "structural" stuff though I have made 12 trap lines with them and they have never slipped at all... and those are conditions wherein they would slip. of course I am lazy though....
[Re: tami]
#176035 04/24/09 05:12 PM 04/24/09 05:12 PM |
Posts: 1,203 uk | The idea of these splices is not to reduce the strength in the line by adding a knot. I reckon that one of these,mid way along a line, may weaken the line significantly.
Anyone got any authority on this?
[Re: TEAMVMG]
#176038 04/24/09 05:28 PM 04/24/09 05:28 PM |
Posts: 12,310 South Carolina | Mike - has the punisher eaten a brummel vs. a simple tuck splice?
Jake Kohl | | | Re: alternate brummel
[Re: TEAMVMG]
#176204 04/27/09 08:02 AM 04/27/09 08:02 AM | andrewscott
| andrewscott
Unregistered | Anyone got any authority on this? I got NO Authority! but that is my understanding as well... HM line (dyneema, specta, vectran, etc) don't like knots and can reduce up to 70% of its breaking strength. | | | Re: alternate brummel
[Re: ]
#176208 04/27/09 08:31 AM 04/27/09 08:31 AM |
Posts: 712 | Oh yeah. Splices retain the most strength vs a knot. Bowlines cut themselves apart at about 60% of the ropes working load - sometimes less.
A brummel splice is our preferred 12-strand splice - however tapering the bury is critical to integrity of the splice. The line will typically break at the end point of the bury. If you think about it, the outer strands are taking the load, and the inner strands have less tension because of the transition. If you do not taper the bury, I've seen them fail at 50% of the working load because of the abrupt transition.
[Re: mikekrantz]
#176211 04/27/09 08:59 AM 04/27/09 08:59 AM |
Posts: 6,049 Sebring, Florida. | What is the difference between this brummel splice and a regular eye splice? Seems in both you pass each through the other and form an eye, then bury the tail? Are they the same just called different names?
Blade F16 #777
[Re: Timbo]
#176213 04/27/09 09:11 AM 04/27/09 09:11 AM | andrewscott
| andrewscott
Unregistered | What is the difference between this brummel splice and a regular eye splice? Seems in both you pass each through the other and form an eye, then bury the tail? Are they the same just called different names? No there is a difference... the regular eye splice the bitter end passes through the line a few times. The brummel is different... try Tami's example.. .it is much easier than the second link (its hard to pull the knots through the hole and then open them up again as in the second example) and will show the differece very well....
[Re: PTP]
#176214 04/27/09 09:14 AM 04/27/09 09:14 AM | andrewscott
| andrewscott
Unregistered | I use a bastardized brummel (aka tuck splice?) where I just pull the line through itself twice then bury it. I think thats called a Single Braid Eye Splice Lock Stitch | | | Re: alternate brummel
[Re: ]
#176244 04/27/09 01:27 PM 04/27/09 01:27 PM |
Posts: 2,921 Michigan | but is a regular easy buried splice weaker than a brummel? Or vice versa. I haven't ever had even a simple straight up (like on the samson page) eye splice come undone if the tail is long enough (which makes for a very long taper and smooth transition)
444
guests, and 33
