| Re: Don't Ask Me How I Know
[Re: ]
#174110 04/07/09 11:12 AM 04/07/09 11:12 AM | DougSnell
| DougSnell
Unregistered | I had a ring ding break on shroud pin JUST as I was turn 4.3 around on the beach. It did a slow drop and crew caught it. MAN has I glad we where on the beach. Would have been a mess the snuffer and all to get back on boat for tow.
Doug | | | Re: Don't Ask Me How I Know
[Re: Clayton]
#174209 04/07/09 10:49 PM 04/07/09 10:49 PM |
Posts: 12,310 South Carolina | When you loan your RV to a workmate, be sure they understand that the water pressure regulator should be left on the hose when connecting to a street water supply - especially in a location known for problematically high water pressure. Don't ask my how I know.
OH! and if you loan an RV to a workmate, make sure they're honest enough to tell you when a problem arises so you don't figure it out the night before you are supposed to leave for a regatta....don't ask me how I know.
Jake Kohl | | | Re: Don't Ask Me How I Know
#174255 04/08/09 08:25 AM 04/08/09 08:25 AM | andrewscott
| andrewscott
Unregistered | When you loan your RV to a workmate, be sure they understand that the water pressure regulator should be left on the hose when connecting to a street water supply - especially in a location known for problematically high water pressure. Don't ask my how I know.
OH! and if you loan an RV to a workmate, make sure they're honest enough to tell you when a problem arises so you don't figure it out the night before you are supposed to leave for a regatta....don't ask me how I know. Jake you should know better! never loan your stuff to a workmate.. that can cause hard feelings and a lack of productivity at work... but since we dont work together... can i use your RV? (dont ask me....) | | | Re: Don't Ask Me How I Know
[Re: ]
#174271 04/08/09 09:53 AM 04/08/09 09:53 AM |
OH! and if you loan an RV to a workmate, make sure they're honest enough to tell you when a problem arises so you don't figure it out the night before you are supposed to leave for a regatta....don't ask me how I know. Jake you should know better! never loan your stuff to a workmate.. that can cause hard feelings and a lack of productivity at work... but since we dont work together... can i use your RV? (dont ask me....) It did spur a "duh" idea for me though...I've always hated having to deal with a hose-mounted external water pressure regulator anyway - the exterior hose kind leak, they choke down the water flow way too much (the shower dribbles), and I have to replace them about every year...I'm now installing a $20 fixed regulator just inside the exterior water inlet. duh.
[Re: Robi]
#174365 04/09/09 09:00 AM 04/09/09 09:00 AM |
Posts: 3 | what's the coolest sheets available for the boat. have been searching and it all said was materials used but i want to get the advice from pros like you guys.. any suggestions. | | | Re: Don't Ask Me How I Know
[Re: kyle82]
#174367 04/09/09 09:04 AM 04/09/09 09:04 AM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | what's the coolest sheets available for the boat. have been searching and it all said was materials used but i want to get the advice from pros like you guys.. any suggestions. Fitted or non-fitted? Don't ask me how I know the difference....
[Re: waterbug_wpb]
#174371 04/09/09 10:07 AM 04/09/09 10:07 AM |
Posts: 39 Dallas, TX | If you see your bows suddenly rise up in your rear view mirror while driving forward on a rural road it is probably not good. While you might hope you simply forgot to lock the hitch on the receiver ball, it is also possible that the mast's forward progress was suddenly halted by a power line. You may find that the trailer tie-downs are so strong that instead of breaking, your trailer bent in half. Your neighbors may be looking at you for all sorts of reasons, losing power in their homes among them.
Don't ask me how I know.
Prindle 19MX
[Re: kyle82]
#174374 04/09/09 10:25 AM 04/09/09 10:25 AM | andrewscott
| andrewscott
Unregistered | what's the coolest sheets available for the boat. have been searching and it all said was materials used but i want to get the advice from pros like you guys.. any suggestions. This seems a little "off the topic" ... you would get a better responce as a new thread (or use the serach feature) I love the robline dingy racing sheets.... go ahead.. ask me... !!! | | |
482
guests, and 531
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 Sep 13th, 2025 | | | |
