blade main halyard #175236
04/19/09 10:20 AM
04/19/09 10:20 AM
blade713 Offline OP
blade713  Offline OP
i need to replace my main halyard due to fraying. anyone know the replacement specs?type of line, diameter, length etc?thanks
Re: blade main halyard [Re: blade713] #175239
04/19/09 11:17 AM
04/19/09 11:17 AM
of all the line on the boat, this line means the least. use the cheapest (although light would be good) line you can find. 1/8 if your hands can tolerate it. no bigger than 5/32. go with a few feet over twice the length of the mast. I guess it would be good to have a line that doesn't absorb water too.
something like this would work...
https://store.catsailor.com/pc/viewPrd.asp?idcategory=550&idproduct=30426
or
https://store.catsailor.com/pc/viewPrd.asp?idcategory=562&idproduct=8245
Re: blade main halyard [Re: PTP] #175245
04/19/09 11:54 AM
04/19/09 11:54 AM
I tried using a nylon pre-stretch line as main halyard once, never again. Static line like dyneema/spectra is my choice. 3-4mm.
Re: blade main halyard [Re: Rolf_Nilsen] #175333
04/20/09 08:27 AM
04/20/09 08:27 AM
blade713 Offline OP
blade713  Offline OP
thanks!
0 registered members (), 426 guests, and 47 spiders.
