Snuffer for Stealth #175380
04/20/09 11:59 AM
04/20/09 11:59 AM
WA, ID, MT
davefarmer Offline OP
WA, ID, MT
Just fired up the Stealth F16 I got from Gary, and I love it. But the thru/under tramp snuffer system has to go, way to much friction. I'd like to do a mid pole set up, and I'm happy with the SNU on the HT, but are there other options I should consider for this boat? The spin pole is a very small dia, maybe 1.25", and pretty lightly constructed(carbon).
Thanks guys!
Dave
Re: Snuffer for Steath [Re: davefarmer] #175383
04/20/09 12:14 PM
04/20/09 12:14 PM
pgp Offline
pgp  Offline
Wouldn't the snuffer from the other boats work?
Pete Pollard
Blade 702
Re: Snuffer for Steath [Re: davefarmer] #175387
04/20/09 12:21 PM
04/20/09 12:21 PM
get a hoop from Matt M at falcon marine. sturdy, aluminum, no nonsense. not sure how much $ though. a hoop and bag from performance is 400$ +
Re: Snuffer for Steath [Re: PTP] #175388
04/20/09 12:26 PM
04/20/09 12:26 PM
andrewscott
andrewscott
i purchased my hoop and bag from Jill at [email protected] (robbie danials wife) for much less than $400
Re: Snuffer for Steath [Re: davefarmer] #175401
04/20/09 01:44 PM
04/20/09 01:44 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I've settled on the alu hoop and dacron tapered bag snuffer. Simple, light and reliable. Mine came from Landenberger Sail in Germany...back when they were pretty new to the market so no US sources. Paid ~$250 USD shipped. This one has a milled slot around the alu hoop for a bolt-rope to hold the dacron. Makes for a very clean transition. Select dacron over mylar since a wet sail will adhere to mylar with more drag than to dacron.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Snuffer for Steath [Re: Tornado] #175403
04/20/09 01:47 PM
04/20/09 01:47 PM
pgp Offline
pgp  Offline
Sounds like the standard Blade hoop.
Pete Pollard
Blade 702
Re: Snuffer for Steath [Re: Tornado] #175414
04/20/09 02:13 PM
04/20/09 02:13 PM
andrewscott
andrewscott
My mylar snuffer is just about spent.. i have had it for less than a year.
i will need a new one within a few months...
Re: Snuffer for Steath [Re: davefarmer] #175435
04/20/09 03:51 PM
04/20/09 03:51 PM
UK
Cheshirecatman Offline
UK
The Stealth snuffer changed to mid-pole shortly after your boat was built. As did the Spitfire. JP sells snuffers direct. Why not contact him?
http://www.stealthmarine.co.uk/
Cheshirecatman
Re: Snuffer for Steath [Re: Cheshirecatman] #175453
04/20/09 06:07 PM
04/20/09 06:07 PM
WA, ID, MT
WA, ID, MT
All great responses guys! Am following all leads!
Dave
Re: Snuffer for Steath [Re: davefarmer] #175467
04/20/09 08:40 PM
04/20/09 08:40 PM
France
pepin Offline
pepin  Offline
France
FYI The current Stealth snuffer is a nice aluminum hoop. The bag is a tapered mylar bag which slides into a groove on the hoop.
Re: Snuffer for Steatlh [Re: pepin] #175482
04/20/09 11:24 PM
04/20/09 11:24 PM
WA, ID, MT
WA, ID, MT
pepin,
what's a Stealth R?
Re: Snuffer for Steath [Re: pepin] #175484
04/20/09 11:39 PM
04/20/09 11:39 PM
WA, ID, MT
WA, ID, MT
I've emailed Jill and Matt and JP, anyone got Dennis' # at SNU? Are any of these folks offering a dacron sock?
Dave
Re: Snuffer for Stealth [Re: davefarmer] #175488
04/21/09 12:47 AM
04/21/09 12:47 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
The pole is plenty strong with the way it is supported on your Stealth. Get the Snu--best design for the price you'll find right now.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Snuffer for Steatlh [Re: davefarmer] #175500
04/21/09 02:34 AM
04/21/09 02:34 AM
Originally Posted by davefarmer
pepin,
what's a Stealth R?
It's the Stealth as was BEFORE is was midified to be a F16.
Slightly thinner beam and had a smaller mainsail and bigger Jib.
Re: Snuffer for Steatlh [Re: davefarmer] #175513
04/21/09 05:26 AM
04/21/09 05:26 AM
France
pepin Offline
pepin  Offline
France
pepin, what's a Stealth R?
As Simon said, that's the boat JP originally designed before the F16 rules. Actually there were 3 major versions, the original Stealth, the Stealth 'R' and the Stealth F16.
From memory, the original had the following characteristics:
- Smallish not square top main (Ullman)
- Small jib (Ullman)
- Spi (Ullman)
- Rudder and daggerboard where identical (in fact 49er rudder foils)
- 2.4m wide
- canoe bows
The 'R' had the following changes, using the exact same platform:
- Huge overlapping jib (Ullman)
- Longer daggerboard
A lot of original Stealth were upgraded to the 'R' version. Mine is one of those: I have two jibs and two sets of rudder foils.
The F16 version was then optimized for the F16 rules with some other changes thrown in for good measures:
- Larger beam (2.50)
- beefier front beam
- Straight bow
- All sails made by Landenberger, and more recently by Grant Piggot.
- F16 compliant main (square top, larger than the 'R')
- F16 compliant jib (smaller than the 'R') with an optional self-tacker
- Longer spi pole
- Anti-pitchpole rudder foils
- Thinner daggerboard
- Different trampoline lacing smile
- Mast rotation at mast base
A lot of upgrades have been applied to older Stealths, anything from canting the hulls, changing the sails to F16 sails, adding foils, widening beams, you name it...
Re: Snuffer for Steatlh [Re: pepin] #175561
04/21/09 10:25 AM
04/21/09 10:25 AM
WA, ID, MT
WA, ID, MT
Thanks pepin, mine has the canoe bows, grooves for the tramp, Landenberger sails, jib self tacker, foiled rudders, and it's a 2002, according to the title.
Dave
Re: Snuffer for Steatlh [Re: davefarmer] #175578
04/21/09 11:51 AM
04/21/09 11:51 AM
France
pepin Offline
pepin  Offline
France
What's your sail number? The number is also available part of the CE marking stamped on the inside of the hull at the rear beam. It should be between 500 and 600.
Re: Snuffer for Steatlh [Re: pepin] #175605
04/21/09 04:12 PM
04/21/09 04:12 PM
WA, ID, MT
WA, ID, MT
The boat's on Flathead Lake in MT, hopefully I'll get over there this weekend. Although I'd like to have made a decision on the snuffer, and bring that along.
Thanks for all the input guys! This almost as much fun as sailin' her!
Dave
0 registered members (), 639 guests, and 38 spiders.
