N20 Mid-Pole Snuffer Question... #175458
04/20/09 07:12 PM
04/20/09 07:12 PM
Annapolis,MD
Keith Offline OP
Keith  Offline OP
Annapolis,MD
Is there a preferred location (distance from bridles, or measurement from either end) of the snuffer hoop on the pole? We're finally mounting our mid-pole setup...
Re: N20 Mid-Pole Snuffer Question... [Re: Keith] #175463
04/20/09 07:44 PM
04/20/09 07:44 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Put the bag on see how far you want it under the tramp, that'll tell ya. I put mine pretty close to the bridles and let the bag run under the tramp.
Todd
Isak Dinesen
E. B. White
Re: N20 Mid-Pole Snuffer Question... [Re: Team_Cat_Fever] #175474
04/20/09 09:32 PM
04/20/09 09:32 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
word on the street is if you put it further away from the bridles then it makes it easier to snuff. I forewarn you however that I don't have any firsthand confirmation of this.
Re: N20 Mid-Pole Snuffer Question... [Re: ThunderMuffin] #175477
04/20/09 10:06 PM
04/20/09 10:06 PM
Annapolis,MD
Keith Offline OP
Keith  Offline OP
Annapolis,MD
The one boat we have to compare with right now has it about 21" from the bridle. It makes it so the hull tangs for the whisker stays line up just aft of the middle of the hoop (if that makes any sense). That makes it so the end of the bag just reaches the main beam. It would seem to make sense that having it further out would help snuffing. Pictures of other boats seem to have the hoop closer to the bridle, though. That would seem to help with windage and waves.
Re: N20 Mid-Pole Snuffer Question... [Re: Keith] #175523
04/21/09 07:20 AM
04/21/09 07:20 AM
When I swapped mine, the reason I was getting rid of the endpole was windage,so I put it back as far as I could to cut down on windage. I have seen some pretty far forward too. I have no problem snuffing mine with it back, tiller feels the same either way.
Todd
Isak Dinesen
E. B. White
Re: N20 Mid-Pole Snuffer Question... [Re: Keith] #175531
04/21/09 07:27 AM
04/21/09 07:27 AM
I had one tight to the bridle and a second one further out. If I had it to do again, I would stick with the "further out" position as I believe it does snuff a little easier with the spinnaker further away from the bridle. Mount it far enough out on the pole so you can still tie off the sock to the mast post under the beam with a little tension...21" sounds about right.
Re: N20 Mid-Pole Snuffer Question... [Re: Jake] #175535
04/21/09 07:35 AM
04/21/09 07:35 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
If the end of the sock is just at the front beam, you have the option of bringing the retrieval line over the front beam which stops the [full] sock dragging in the drink.
Re: N20 Mid-Pole Snuffer Question... [Re: TEAMVMG] #175540
04/21/09 07:53 AM
04/21/09 07:53 AM
andrewscott
andrewscott
I have an mid pole snuffer.
i had real issues with the spin halyard getting wrapped up in my jib when i furled or unfurled my jib when the hoop was about 6" in front of the furler.
I moved my hoop about 1.5' in front and it greatly reduced this. My bag ends under the front beam (tornado sized bag)
Pic is from before i moved it... [Linked Image]
Re: N20 Mid-Pole Snuffer Question... [Re: ] #175583
04/21/09 12:32 PM
04/21/09 12:32 PM
we used to have that problem with the F18 all the time...spin halyard had to be tight when furling the jib or it would twist with it.
Re: N20 Mid-Pole Snuffer Question... [Re: Jake] #175601
04/21/09 03:31 PM
04/21/09 03:31 PM
andrewscott
andrewscott
Nothing worse than having a successful douce only to get your jib fouled with the spin halyard. Even with moving it forward.. it still happens if i forget to tell crew to snug up the spin halyard.
Re: N20 Mid-Pole Snuffer Question... [Re: Jake] #175602
04/21/09 03:33 PM
04/21/09 03:33 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
The reasoning for putting it a bit further out is just to help prevent everything from bunching up on top of the forestay when snuffing. If I remember right this was started by the Tornado guys.
Re: N20 Mid-Pole Snuffer Question... [Re: BLR_0719] #175618
04/21/09 06:03 PM
04/21/09 06:03 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
When I was new to snuffing I had a Guck all carbon snuffer scoop on a homemade pole. We put the scoop as close to the bridle as possible. Sailed it for a season with all kinds of trouble durng douses. Tried all the usual tricks (adding sections to the sail loops to spread out the douse line patches; tons of sail lube, etc etc). We finally solved it by moving the scoop 1-1.5 ft forward along the pole. It all came down to the distance from the tack to the first patch. Sail should be entering the snuffer BEFORE the tack is pulled towards the snuffer. This makes for a smoother entry without a big blob of cloth forming before entry. With the scoop at the bridles, the blob of cloth would form before anything had started into the scoop. Big difference in effort need to snuff.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
0 registered members (), 355 guests, and 44 spiders.
