Carbon spreaders #175718
04/22/09 11:48 AM
04/22/09 11:48 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Anybody interested in a set of carbon spreaders? I'm just finishing up a set and could pull a mold off them if anyone is interested in a pair.
They are made to bolt right onto the proctor brackets and adjuster parts. They are significantly lighter than the aluminum Proctor arms.
wjvining at yahoo
Re: Carbon spreaders [Re: bvining] #175771
04/22/09 10:45 PM
04/22/09 10:45 PM
Mesa, AZ
basketcase Offline
basketcase  Offline
Mesa, AZ
Got any pics? I am kind of curious.
Jonathan
Re: Carbon spreaders [Re: bvining] #175773
04/22/09 11:02 PM
04/22/09 11:02 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
How much $ Bill? How much are the other Proctor parts? Appropriate for which masts?
Dave
Re: Carbon spreaders [Re: bvining] #175817
04/23/09 08:41 AM
04/23/09 08:41 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
PICS?
Re: Carbon spreaders [Re: davefarmer] #175871
04/23/09 12:56 PM
04/23/09 12:56 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Dave,
I bought the whole setup 5 years ago and it was $225. You can see the set up here. The aluminum arms are really heavy, so a carbon replacement is a big upgrade.
http://www.apsltd.com/c-947-selden-proctordinghymastboomspreaderparts.aspx
What I am making is a carbon version of the arm - 450mm long and a bit wider, I took a mold off of a model helicopter blade that I modified, so it's wing shaped. You still need the barrell adjusters and the brackets.
I will get weights for you so you can compare the savings.
Bill
Re: Carbon spreaders [Re: davefarmer] #175872
04/23/09 12:57 PM
04/23/09 12:57 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Dave,
$200 for two 450mm arms. perfect for an acat.
Bill
Re: Carbon spreaders [Re: pitchpoledave] #175873
04/23/09 12:58 PM
04/23/09 12:58 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Pics are coming. Waiting for the mold to cure, the original part is inside.
Re: Carbon spreaders [Re: bvining] #175882
04/23/09 02:15 PM
04/23/09 02:15 PM
andrewscott
andrewscott
Watch out for down drafts and micro-birst durring landings!
Re: Carbon spreaders [Re: ] #175885
04/23/09 02:18 PM
04/23/09 02:18 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Be extremely carefull of funnel gunnels.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Carbon spreaders [Re: F-18 5150] #175932
04/23/09 08:47 PM
04/23/09 08:47 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
If you want the anti funnel gunnel mirco burst pitch dampeners, its going to be extra.
Re: Carbon spreaders [Re: basketcase] #175934
04/23/09 08:54 PM
04/23/09 08:54 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
the part is 500mm, not 450mm.
weight is .35kg, which is easily half the aluminum ones.
They will get painted white to reflect any UV and keep them cool and stiff and prevent any electron swapping with the aluminum bracket and adjuster.
Bill
Re: Carbon spreaders [Re: bvining] #175936
04/23/09 09:32 PM
04/23/09 09:32 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Bet you'll get some good lift from that sucker!
Very nice.
Re: Carbon spreaders [Re: bvining] #175955
04/24/09 06:21 AM
04/24/09 06:21 AM
Bling Bling!
Re: Carbon spreaders [Re: bvining] #175963
04/24/09 07:34 AM
04/24/09 07:34 AM
You are only going to paint the tops, right? Why add all that weight to the bottom where it won't see sunlight? grin
Re: Carbon spreaders [Re: Jake] #175964
04/24/09 07:34 AM
04/24/09 07:34 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Good idea Timbo, I was thinking the same thing this morning.
Re: Carbon spreaders [Re: bvining] #175970
04/24/09 07:50 AM
04/24/09 07:50 AM
OR... instead of paint, go to a Hobby Shop, pick up some thin mylar sticky back film, color of your choice, cut to size and stick it only on the top.
This might weigh even less than paint, and be easier to use, certainly cheaper, but I don't know about the UV blockage of the film but they use it for RC airplanes.
Re: Carbon spreaders [Re: Timbo] #175971
04/24/09 08:06 AM
04/24/09 08:06 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Or use your old Doritos bag and glue it shiny side up :-)
F18 USA 242
http://www.solarwind.solar
Re: Carbon spreaders [Re: David Ingram] #175972
04/24/09 08:07 AM
04/24/09 08:07 AM
andrewscott
andrewscott
Brilliant!
Re: Carbon spreaders [Re: Timbo] #175977
04/24/09 08:25 AM
04/24/09 08:25 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
If weight saving is the overiding issue then it would be best to go uncoated and replace them after every weekend. crazy
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Carbon spreaders [Re: Mugrace72] #175979
04/24/09 08:38 AM
04/24/09 08:38 AM
andrewscott
andrewscott
we are talking about the weight of the paint on the diamond wire spreaders correct? how much can that weigh? a few grams?
0 registered members (), 463 guests, and 41 spiders.
