| Re: Tacking and right of way
[Re: Gilo]
#176115 04/26/09 10:00 AM 04/26/09 10:00 AM |
Posts: 2,718 St Petersburg FL | As long as you could complete your tack; you can tack.
[Re: Robi]
#176116 04/26/09 10:17 AM 04/26/09 10:17 AM |
Posts: 3,293 Long Beach, California | Wilder! I'm sure you meant that he could tack as long as he didn't break RRS 15: When a boat acquires right of way, she shall initially give the other boat room to keep clear, unless she acquires right of way because of the other boat’s actions.
Go for your layline and sail your proper course. It is good to announce your tack - they're expecting you to do it. They will take all the room you give them, but they almost certainly recognize it as a gift.
[Re: John Williams]
#176127 04/26/09 11:33 AM 04/26/09 11:33 AM |
Posts: 3,528 Looking for a Job, I got credi... | If as per above you can tack and the other boat(s) have time and room as per above then you can do it.
YOu can aslo make it clear you are going to tack; as they are close, you can also pinch for a few seconds and they will then get the picture too.
With F16's they tack so quickly, you should be aiming for 10 seconds or below for wire to wire, so unless they are real close, it should not be a problem.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Tacking and right of way
[Re: Mary]
#176130 04/26/09 11:56 AM 04/26/09 11:56 AM |
Posts: 3,293 Long Beach, California | 15 knots = 25 feet per second. Five boatlengths = 90 feet.
About four seconds.
HOWEVER - I'd bet that F18 was anticipating the tack. They had no rights as the clear-astern boat on port. A hail from the F16 gives the F18 plenty of opportunity to keep clear as the F16 sails her proper course by tacking for the mark. The fact that the F16 made it to the mark first indicates to me that all is right with the universe - good job, Gill.
[Re: John Williams]
#176132 04/26/09 12:35 PM 04/26/09 12:35 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I came up with 4 seconds, too. So in that 4 seconds the F16 is only going to be halfway through its tack. If I were on the smaller, more fragile boat, I don't know if I would have the courage to "bet" that:
No. 1, the F18 knows the rules No. 2, that the F18 is anticipating that you are going to tack. No. 3, the F18 has the time, room or crew reactions to make and execute the decision to avoid me (and how) in that period of time.
I wouldn't put my boat, and maybe my life, on the line based on assumptions.
Didn't this situation used to be called tacking too close?
Also, what if the boat behind and to windward was a Hobie 16 instead of an F18? The Hobie 16 would not even be thinking about tacking yet because he has not yet reached his layline. It might not occur to him that the F16 needs to tack.
I know, I know -- I am probably overthinking this. | | | Re: Tacking and right of way
[Re: Gilo]
#176139 04/26/09 02:20 PM 04/26/09 02:20 PM |
Posts: 807 Hillsborough, NC USA | Let's call your boat A (ahead), and the other boat B (behind) and analyze the situation in steps (which is how I like to walk through the rules during a protest hearing).
Step 1: A is clear ahead and to leeward of B. B is obligated to keep clear of A under RRS 12 (on the same tack, not overlapped).
Step 2: A tacks. From the moment A passes head-to-wind, until she is on a close-hauled course, A is obligated to keep clear of B under RRS 13 (while tacking).
Step 3: A completes her tack. A is now on starbaord tack and B on port tack. B is obligated to keep clear of A under RRS 10 (on opposite tacks). A is obligated to initially give B room to keep clear under RRS 15 (acquiring right-of-way).
At all times, both A and B are required to avoid contact under RRS 14 (avoiding contact).
Now, if B has to take avoiding action during step 2, then A breaks rule 13. If B does not have enough time keep clear in a seamanlike way after A completes her tack (e.g., she crash-tacks or makes contact), then A breaks rule 15.
Note that B does not have to anticipate A's actions at any time. A may hail that she's tacking, but it's her actions that count. After A completes her tack, she must give B enough time to assess the situation, choose a course of action, and execute it in a seamanlike way.
It may seem counter-intuitive, but this is one of those situations where the give-way boat contols the right-of-way boat's action. Given the situation you were in, you did the right thing under the rules and let the F18 drive you past the layline.
As Rick pointed out, this is a tactical situation you want to anticipate and avoid. Some of the options you could have employed earlier are: 1) pinch up in front of the astern boat, so you are able to tack when you want, 2) foot away, so there is enough space between boats for the other to keep clear after you tack, 3) come in to the mark on the port-tack layline and scrape the astern boat off around the mark.
Of course, there are potential difficulties with each option. If you pinch up, the astern boat is likely to pinch up as well. If you foot off, the astern boat may foot too. If you approach the windward mark on the port layline, you may run afoul of other boats rounding the mark.
Regards, Eric
[Re: John Williams]
#176143 04/26/09 02:40 PM 04/26/09 02:40 PM |
Posts: 3,528 Looking for a Job, I got credi... | 15 knots = 25 feet per second. Five boatlengths = 90 feet.
About four seconds.
HOWEVER - I'd bet that F18 was anticipating the tack. They had no rights as the clear-astern boat on port. A hail from the F16 gives the F18 plenty of opportunity to keep clear as the F16 sails her proper course by tacking for the mark. The fact that the F16 made it to the mark first indicates to me that all is right with the universe - good job, Gill. John, Proper course plays NO part in this situation. F16 needs to COMPLETE the tack before the F18 needs to take avoiding action in order to "tack at will". As stated by others, best bet is to either pinch up to drive the other boat away - it will not take much to force them away, or drive them low (by backwind of YOUR sail) more to make the "tack and gain rights" a sure thing; OR drive a little to leeward by footing a little to create more time to make sure the tack is complete and so rights are gained with time to FORCE the F18 to duck or tack. It is best to anticipate this happening and try and make the other boat tack away before YOU want to tack.
[Re: Gilo]
#176151 04/26/09 03:41 PM 04/26/09 03:41 PM |
Posts: 1,203 uk | Got myself in this fix a few times;
Also got the knack of sitting up in the trapeze, both hands on hips [Jam the tiller with your back foot] and glare at the trailing skipper until he really gets the message that you don't want him pushing you about!
[Re: scooby_simon]
#176155 04/26/09 04:03 PM 04/26/09 04:03 PM |
Posts: 3,293 Long Beach, California | Hi Simon -
Agree that the proper course rule doesn't apply - only meant to imply that the F18 should be expecting the F16 to tack, as her course is to the mark. I would hate to be the F18 in that situation, actually, knowing that in the breeze the F16 can probably sail a higher line and I'd need to get past their layline to get to my own, depending upon the distance to the mark. I'm not a short-tacker.
Hmm... wisecracks, anyone?
[Re: scooby_simon]
#176156 04/26/09 04:05 PM 04/26/09 04:05 PM |
Posts: 976 France | Funny, I was in the exact opposite situation last Wednesday: A 29er was in front of me, I was a couple of boat length behind and to windward. But my layline is further than their layline as a 29er points better than my Stealth.
I saw the skipper looking at me, looking at the mark, finally realizing he was screwed and that he would have to go further, to my layline.
I took pity of him, shouted "You tack, I'll avoid you". He said thank you then tacked, I ducked his stern, tacked 10 boat length further and beat them to the mark. It is a far better way of proceeding IMHO.
BTW, they used their huge masthead spi to pass me again on the way to the side mark, but on the hotter reach to the finish line I regained on them, cut their wind and beat them by a mere second. I'm nice, but not that nice. | | | Re: Tacking and right of way
[Re: John Williams]
#176166 04/26/09 05:39 PM 04/26/09 05:39 PM |
Posts: 3,906 Clermont, FL, USA | I'm not a short-tacker.
Hmm... wisecracks, anyone? I don't get it. ???
[Re: John Williams]
#176168 04/26/09 05:47 PM 04/26/09 05:47 PM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | HOWEVER - I'd bet that F18 was anticipating the tack. They had no rights as the clear-astern boat on port. A hail from the F16 gives the F18 plenty of opportunity to keep clear as the F16 sails her proper course by tacking for the mark. The fact that the F16 made it to the mark first indicates to me that all is right with the universe - good job, Gill.
no, no , no. Once you start tacking you must keep clear and give other boats room to keep clear. You have started tacking once you go past head to wind. In this situation the F18 only has to "start" taking avoiding action once the F16 tack is complete, which is when the boat is pointing in the direction of a close-hauled course on the new tack. 1 boat length to windward and 5 astern isn't enough room in my opinion to complete a tack without the F18 having to start avoiding before you have completed the tack. In this situation, the best thing to do tactically is to pinch early and climb above the F18 to make room for yourself to tack. Hopefully the F18 doesn't follow you up maintaining their tactical hold over you. Rules wise though, if you don't want to continue too far past the layline, you are allowed to luff, due to proper course limitations, but tacking in this situation is asking for trouble.
[Re: pepin]
#176171 04/26/09 05:58 PM 04/26/09 05:58 PM |
Posts: 3,528 Looking for a Job, I got credi... | Funny, I was in the exact opposite situation last Wednesday: A 29er was in front of me, I was a couple of boat length behind and to windward. But my layline is further than their layline as a 29er points better than my Stealth.
BTW, they used their huge masthead spi to pass me again on the way to the side mark, but on the hotter reach to the finish line I regained on them, cut their wind and beat them by a mere second. I'm nice, but not that nice. I hope you mean 49er!!!
400
guests, and 274
