pre-bend hobie 18 #17687
03/24/03 09:14 PM
03/24/03 09:14 PM
Bridge City, Texas
pirate_tx Offline OP
Bridge City, Texas
I have a early 80's hobie 18. I just purchased a set of Smyth pentex sails. Square top main. I do not have a comp tip. I was wondering if I should try putting pre-bend in my mast. What pondage I should apply? Anyone have any info. on this?
Just trying to teach a old boat A new trick.
Doug Ramsey
hobie 18
#4383
Re: pre-bend hobie 18 [Re: pirate_tx] #17688
03/24/03 10:05 PM
03/24/03 10:05 PM
Mike Fahle Offline
Mike Fahle  Offline
Hi Doug, I had a Hobie 18 for about twenty years and I have raced with Smythe sails on an F-28R. Smythe sails are normally cut relatively flat so I think that prebend would be a poor set-up decision unless it is always very windy where you sail. A better decision is to have at least an 8 to 1 downhaul to bend the mast when you want and to keep it straight when you want full power. Since you have specialty sails from Smythe (not class legal) you should get rig and trim advice for using those sail from Smythe also.
Have fun!
Re: pre-bend hobie 18 [Re: Mike Fahle] #17689
03/24/03 10:31 PM
03/24/03 10:31 PM
Bridge City, Texas
Bridge City, Texas
Thanks!! for the input.
Re: pre-bend hobie 18 [Re: pirate_tx] #17690
03/25/03 12:17 AM
03/25/03 12:17 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
As Mike said, definitely check with Smythe. One way to go on the 18 is to rig the diamonds just tight enough to keep the mast from bending side-to-side, but not tight enough to cause pre-bend. Then use the downhaul to apply bend and depower as needed. This technique is in Catamaran Sailing for the 90's (one of Rick's books).
0 registered members (), 2,546 guests, and 300 spiders.
