| Re: News
[Re: grob]
#176397 04/29/09 04:21 AM 04/29/09 04:21 AM |
Posts: 9,582 North-West Europe | Do you know what the diameter and wall thickness of the tubes are that go to make up those two masts?
Yes. And a bunch of other specs as well. Wouter
| | | Re: News
[Re: Wouter]
#176401 04/29/09 06:32 AM 04/29/09 06:32 AM |
Posts: 88 | I also think the unstayed, self supporting rig is an excellent idea. Great suggestions Wouter!
Matthew
Currently between boats Previously … Cobra 570 Cobra 581 Mosquito 126 Arafura Cadet 738 | | | Re: News
[Re: Ross]
#176419 04/29/09 08:38 AM 04/29/09 08:38 AM |
Posts: 1,383 Kingston SE South Australia | Ross I ordered a kit so that Scarecrow could organise his suppliers for kits. While the kits heaps easier and each piece is cut out perfect, you dont really need a kit you can build the DS12 from the plans that Scarecrow supplies. I would be suprised if you cant get all the things you need to build the cat there, but you probably need the technical name for the resins so you can web search it. If you could organise freight the kit package wasn't heavy and is approx 3900mm x 450mm x 200mm. Now all I need is time to assemble it. Your questions are not stupid anyone on the forum will happily answer you. Have you seen Gato's blog on building his DS12 in this forum, he shows how to build this cat and how it will look. Simon I'll probably see you on Sunday for the Rum Race, I can't believe how fast you were at the Earthmovers race hopefully we'll find the marks this time. regards
| | | Re: News
[Re: ]
#176481 04/29/09 04:28 PM 04/29/09 04:28 PM | Scarecrow
| Scarecrow
Unregistered | Not particularly relevant to Ross but for those building any F12 design in Aus I'm happy to supply the metal kit components. They are directly compatible with Tabby and I'm sure the Vudu could be tweeked to suit.
Ross I'm sure you can get everything locally if you look around you can find everything you need locally and save the cost of shipping. | | | Re: News
[Re: Ross]
#176529 04/30/09 01:21 AM 04/30/09 01:21 AM | Scarecrow
| Scarecrow
Unregistered | Ross check your PMs I've just sent you a link to the plans.
basically cloth is specified (its all e-glass in the plans). When working with marine plys (we recommend gaboon) you have to use Epoxy, talk to your local supplier as to their best product for the job but I have used Gurit (SP systems) for the last 10 years without any issues.
Carbon is only required if you choose to build a mast. | | | Re: News
[Re: Ross]
#176655 04/30/09 10:36 PM 04/30/09 10:36 PM | Scarecrow
| Scarecrow
Unregistered | Ross carbon mast details already exist. Carbon beams can be generated on request. | | | Re: News
[Re: Ross]
#176718 05/01/09 12:04 PM 05/01/09 12:04 PM |
Posts: 1,307 Asuncion, Paraguay | The unstayed, self supporting rig does appear to be a neat way to go.
JeffS, you are talking about a kit you are about to pick up. I admit I have not read every F12 thread, so I guess I have missed something, but who is supplying the kits, what is included, and based on what design? Is it the Vudu? Also, is the kit available for purchase, and if so, who do I contact?
RG is trying to gather enough people to produce a batch of rotomolded Vudus. You might want to contact him too. I like the self standing rig with sleeved sail either, but will take the production boat anyway it comes because I believe in serial production to boost numbers. All the best,
Luiz
| | | Re: News
[Re: Luiz]
#176732 05/01/09 12:50 PM 05/01/09 12:50 PM |
How much for the rotomolded platform ?
And is RG still using the curved beams for the Vudu ?
Will it carry a 85 kg male ?
If so then I maybe interested just the platform. I'm not looking forward in building that myself with the resources that I have. I have no issues with the foils or rig.
| | | Re: News
[Re: Wouter]
#176757 05/01/09 06:14 PM 05/01/09 06:14 PM |
Posts: 1,307 Asuncion, Paraguay | How much for the rotomolded platform ? And is RG still using the curved beams for the Vudu ? Will it carry a 85 kg male ? If so then I maybe interested just the platform. I'm not looking forward in building that myself with the resources that I have. I have no issues with the foils or rig.
Wouter, The complete boat will cost USD 4.000,00 if 20 are ordered. That´s all I know. Luiz
Luiz
| | | Re: News
[Re: Wouter]
#176910 05/04/09 02:03 AM 05/04/09 02:03 AM |
Posts: 255 NZ |
Hi Wouter, will have a platform only price after the first ones are out of the moulds and the round bilge one will have straight beams. It will however struggle a bit at 85kg as it was only designed around a max 50 kg kid. cheers RG | | | Re: News
[Re: RetiredGeek]
#176913 05/04/09 03:12 AM 05/04/09 03:12 AM | Scarecrow
| Scarecrow
Unregistered | RG sent an email to your xtra.co.nz email address. I don't know if you check it often. | | | Re: News
[Re: RetiredGeek]
#176917 05/04/09 03:57 AM 05/04/09 03:57 AM |
Posts: 9,582 North-West Europe | Hi Wouter, will have a platform only price after the first ones are out of the moulds and the round bilge one will have straight beams. It will however struggle a bit at 85kg as it was only designed around a max 50 kg kid.
Thanks for the info. Wouter
3,175
guests, and 228
