Nacra 20 inspection ports? #177619
05/09/09 12:06 AM
05/09/09 12:06 AM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
Today I pulled my boat form winter storage. It was taken a part and each hull was stored up side down. When I was rotating each hull to set it on the trailer I could hear something bang inside each hull. Next I checked two holes where bungee cable goes through hull for trapeze. I could not see all the way through. I’m suspecting that they broke and loose pieces make that noise while I was rotateing hulls.
Where is the best spot to cut inspection ports to see what is wrong ?
How can I fix broken tubes inside hulls for bungee cords?
Thanx
Kris
I20
Re: Nacra 20 inspection ports? [Re: Krisu13] #177630
05/09/09 04:44 AM
05/09/09 04:44 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
You can never see through these holes, don't cut hatches.
the hulls have blocks of foam stuck inside for bouyancy, i bet that its a bit of this that is loose. My 20 had stuff rattling around inside it!
Re: Nacra 20 inspection ports? [Re: TEAMVMG] #177639
05/09/09 07:29 AM
05/09/09 07:29 AM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
I’m positive that Nacra 20 has no foam inside hulls. I remember my old Tornado (early 70’s) had foam.
I20
Re: Nacra 20 inspection ports? [Re: Krisu13] #177642
05/09/09 07:47 AM
05/09/09 07:47 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Kris,
I have the large inspection ports on the N20 and I love them. They are just aft of the daggerboard trunks. There is a bulkhead behind the inspection port and the trunk in front which makes a fantastic storage area for quick and easy access while racing or under sail, plus there is ALOT of volume in this area. We store spare lines on the bungee tubes and also use the tube as a place to tie off the leash for the cover. There is enough room in this area to put a small soft side cooler, or drybags for fowl weather gear, which is very nice for distance racing. I'll see if I can find a picture to post.
Philip
USA #1006
Re: Nacra 20 inspection ports? [Re: P.M.] #177651
05/09/09 11:21 AM
05/09/09 11:21 AM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
Philip,
Did you step on one while sailing? I did once and I broke one. That is why I’m hesitating to put one in. But I guess it is the only way I can get inside the hull and see what is going on and make necessary repair. I would appreciate any pictures you can post.
Kris
I20
Re: Nacra 20 inspection ports? [Re: Krisu13] #177655
05/09/09 11:58 AM
05/09/09 11:58 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Originally Posted by Krisu13
Philip,
Yes, regularly, and at 225# it's not an issue. These things are solid. As stated before these ports are LARGE and considerably beefier than what you normally see. I must also add that they are the easiest to remove and screw back on. I don't know why they are so easy, they just are. The 5" and 6" are always a PITA. Next time I'm near the boat I will check and see what brand and size. Still looking for the pictures . . .
Philip
USA #1006
Re: Nacra 20 inspection ports? [Re: P.M.] #177664
05/09/09 12:29 PM
05/09/09 12:29 PM
I can't get the 4 big ones on my -really old- Prindle to spin open, any ideas on what to squirt in there to loosen them up? It's nearly impossible to get any type of wrench on them to get some leverage, I'm affraid I'll break one if I hit it with a hammer or something else jammed in the finger holes.
Re: Nacra 20 inspection ports? [Re: Timbo] #177665
05/09/09 12:33 PM
05/09/09 12:33 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
try some liquid dish soap all around the joint.
Philip
USA #1006
Re: Nacra 20 inspection ports? [Re: Timbo] #177671
05/09/09 01:07 PM
05/09/09 01:07 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
It does not take much to open them what you need is WD40 and Channel lock pliers.
I20
Re: Nacra 20 inspection ports? [Re: Krisu13] #177674
05/09/09 01:40 PM
05/09/09 01:40 PM
Thanks, I will give that a try.
Re: Nacra 20 inspection ports? [Re: Krisu13] #177684
05/09/09 05:25 PM
05/09/09 05:25 PM
Kris,
There is a large soft polyethylene air "tank" inside each hull just in front of the daggerboard well - they make noise when the boat rolls around. I wouldn't worry too much about it.
Re: Nacra 20 inspection ports? [Re: Krisu13] #177690
05/09/09 07:07 PM
05/09/09 07:07 PM
DougSnell
DougSnell
Once I got mine open on my H-17, I put a rope handle in he lid. Never had that problem again.
Doug
Re: Nacra 20 inspection ports? [Re: ] #177694
05/09/09 07:30 PM
05/09/09 07:30 PM
japan
erice Offline
erice  Offline
japan
before using tools to force the lids open make sure the drain plugs are open to equalize any internal hull pressure, any positive or negative internal hull pressure can make the ports hard to remove
once off a little dry lube might be a good idea, a wet grease like vaseline would tend to hold sand in the threads which is probably what the problem is now
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Nacra 20 inspection ports? [Re: erice] #177707
05/10/09 06:43 AM
05/10/09 06:43 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
There should be a breather hole in the hatch anyhow
Re: Nacra 20 inspection ports? [Re: TEAMVMG] #177844
05/11/09 12:40 PM
05/11/09 12:40 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
How about those inspection ports? And methods how to fix bungee cord tubes?
Anyone, Anyone, Anyone??? Going once, Going twice Anyone, Anyone, Anyone???
I would appreciate any pictures you have to share.
Kris
I20
Re: Nacra 20 inspection ports? [Re: Krisu13] #177848
05/11/09 01:34 PM
05/11/09 01:34 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
are the tubes actually busted/gone?
Re: Nacra 20 inspection ports? [Re: TEAMVMG] #177873
05/11/09 08:13 PM
05/11/09 08:13 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
I can not see through. When I push bungee into tube it goes through but is not smooth. I guess I can not tell until I will cut inspection ports. But I do not know where is the best spot to do it so I have good access to both tubes.
Kris
I20
Re: Nacra 20 inspection ports? [Re: Krisu13] #177878
05/11/09 09:29 PM
05/11/09 09:29 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Kris,
I found a few pics that might help. This position is between the bulkhead and the daggerboard trunk. I can take more pictures this weekend if you like. Let me know. . .
Philip
USA #1006
Re: Nacra 20 inspection ports? [Re: Krisu13] #177892
05/12/09 04:48 AM
05/12/09 04:48 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
The holes are never smooth. I still don't think that you have a problem. they are always a bit choked up with bits of sealant.
gently pump some air in the bung hole and see if it leaks out the bungee hole by spraying on soapy water.
0 registered members (), 655 guests, and 139 spiders.
Posts267,056
