Page 1 of 3 1 2 3
request picture of spin halyard cleat #177726
05/10/09 10:12 AM
05/10/09 10:12 AM
Atlanta
GeoffS Offline OP
GeoffS  Offline OP
Atlanta
I am moving the spin halyard cleat from the side of the mast to the front beam on a VWM Blade. I am planning to use a stand-up block and a standard swivel cleat on the front beam. I do not want to use a Spinlock.
If anybody has a similar setup on their Blade and could take a picture, that would be super cool. I'm particularly interested in how far away you placed the cleat from the mast and what cool things you used for a riser.
Thanks,
Blade 729
Re: request picture of spin halyard cleat [Re: GeoffS] #177756
05/10/09 05:25 PM
05/10/09 05:25 PM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
I made the change about a year ago. I think the block placement depends on if you will sail 2 up or not. If you will not you can put the cleat fairly close to the mast and the block can go on the spin pole. If you will be using the jib, the cleat is placed just outside the jib traveler and the block goes on the beam under the jib traveler. I used a new spinlock and it has worked flawlessly mounted directly to the beam. I have a picture but have no idea how to attach it to this post.
Chris
Trident F16
Re: request picture of spin halyard cleat [Re: Cab] #177760
05/10/09 07:35 PM
05/10/09 07:35 PM
Scarecrow
Scarecrow
Are you runnig a seperate tack line or does this halyard go out to the tack as well? If you're not running a seperate tack line then reverse the system that is rigged at present so the halyard goes from the cleat to the tack line then back to the beam and up the mast.
Re: request picture of spin halyard cleat [Re: Cab] #177780
05/11/09 06:25 AM
05/11/09 06:25 AM
Atlanta
GeoffS Offline OP
GeoffS  Offline OP
Atlanta
Thanks for the info. I would love to see that picture! I think you can attach by clicking the "File Manager" link at the bottom of the posting form.
Re: request picture of spin halyard cleat [Re: ] #177781
05/11/09 06:45 AM
05/11/09 06:45 AM
Atlanta
GeoffS Offline OP
GeoffS  Offline OP
Atlanta
Good idea. I am running a separate tack line. I'd like to go with a single line system like you describe, but I don't think I have enough halyard length to do it right now.
Re: request picture of spin halyard cleat [Re: GeoffS] #177787
05/11/09 07:31 AM
05/11/09 07:31 AM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
Picture attempt.
Spin setup.jpg (661 downloads)
Chris
Trident F16
Re: request picture of spin halyard cleat [Re: Cab] #177789
05/11/09 07:38 AM
05/11/09 07:38 AM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
A little bigger.
Chris
Trident F16
Re: request picture of spin halyard cleat [Re: Cab] #177795
05/11/09 08:45 AM
05/11/09 08:45 AM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
Maybe a zoom in.
Chris
Trident F16
Re: request picture of spin halyard cleat [Re: Cab] #177810
05/11/09 09:34 AM
05/11/09 09:34 AM
Chicago, Illinois USA
TEH Offline
TEH  Offline
Chris, I am running basically the same rig, except I do not have the grommet further up the tramp as you have. My spin line runs through the rear tramp grommet. What's the benefit of running through the grommet closer to the cross-beam?
Blade F16 USA 725
Re: request picture of spin halyard cleat [Re: TEH] #177813
05/11/09 09:40 AM
05/11/09 09:40 AM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Teh benefit is that you are always facing forward and pulling from in front whenever hoisting/dousing teh spin.
Re: request picture of spin halyard cleat [Re: bobcat] #177815
05/11/09 09:43 AM
05/11/09 09:43 AM
pgp Offline
pgp  Offline
Also, abrasion may damage your tramp (on the under side). It is possible to run the halyard over (aft)of the rod that supports the tramp, resulting in abrasion damage. Don't ask me how I know.
Pete Pollard
Blade 702
Re: request picture of spin halyard cleat [Re: GeoffS] #177818
05/11/09 09:47 AM
05/11/09 09:47 AM
Personally, I have just a (non-swiveling) cleat on my mainbeam. Used only two large stainless screws to secure it to the beam and it has never failed on me. Using just Parker screws is also what AHPC did for years when fitting a spi halyard cleat. Seems to be sufficient.
I actaully have the cleat on the beam where the traveller rail is as well. The two don't not seem to interfere on my boat.
Re: request picture of spin halyard cleat [Re: Wouter] #177824
05/11/09 10:04 AM
05/11/09 10:04 AM
Atlanta
GeoffS Offline OP
GeoffS  Offline OP
Atlanta
Originally Posted by Wouter
Personally, I have just a (non-swiveling) cleat on my mainbeam....I actaully have the cleat on the beam where the traveller rail is as well.
Sounds interesting. But I don't completely understand. Would you elaborate on what you mean by "traveler rail" in this context (or draw me a picture)?
Re: request picture of spin halyard cleat [Re: bobcat] #177836
05/11/09 11:33 AM
05/11/09 11:33 AM
TEH Offline
TEH  Offline
Is this benefit when sailing two-up? I'm typically pretty far aft hoisting the spin sailing uni.
Blade F16 USA 725
Re: request picture of spin halyard cleat [Re: TEH] #177837
05/11/09 11:35 AM
05/11/09 11:35 AM
TEH Offline
TEH  Offline
I mean dousing, not hoisting.
Blade F16 USA 725
Re: request picture of spin halyard cleat [Re: TEH] #177843
05/11/09 12:10 PM
05/11/09 12:10 PM
bobcat Offline
bobcat  Offline
I personally still have teh line running to teh back beam also so I can't speak from experience. My mark roundings are relatively traffic free as I am Portsmouth racing against mostly monohulls. With teh douse line running to the back beam you would probably still end up with your body axis oriented slightly aft. Not having your head in a position to be watching forward could lead to issues at mark roundings. At teh least, you probably drop early, in recognition of all teh high-speed traffic and how you need your head up.
If you can be kneeling on teh tramp, hauling line like crazy and still have your peripheral vision watching port and starboard, would both be safer and allow you to drive closer to teh mark.
Re: request picture of spin halyard cleat [Re: bobcat] #177994
05/12/09 06:53 PM
05/12/09 06:53 PM
Santa Fe, New Mexico, USA
WillLints Offline
WillLints  Offline
GeoffS,
Having been out of the loop, so to speak, for a while would you mind telling me if your boat came with the spin cleat mounted on the mast. If so, what was the reasoning and why are you moving away from that? I am doing a little revamping on my Blade and planning on adding an additional cleat on the mast and replacing the spinlock on the main beam with something I can operate in light air.
Thanks,
Will Lints
Will_Lints
one-up, Blade 706, epoxy bottoms
Re: request picture of spin halyard cleat [Re: WillLints] #178001
05/12/09 07:33 PM
05/12/09 07:33 PM
Atlanta
GeoffS Offline OP
GeoffS  Offline OP
Atlanta
The boat - a 2007ish VWM Blade - came with the cleat on the mast and neither I or my co-owner like it there. The cleat on the mast is frequently rotated away from you (i.e., on the wrong side of the mast) when you need to get to it. I think if we had been given the choice at the time we bought the boat, we would have asked for the cleat on the beam, but we didn't think about it. Additionally, this boat is almost always sailed single-handed and I always thought the cleat-on-the-mast thing was more for double-handed sailing.
Re: request picture of spin halyard cleat [Re: GeoffS] #178003
05/12/09 08:42 PM
05/12/09 08:42 PM
WillLints Offline
WillLints  Offline
Oh, I hadn’t thought about the cleat sometimes being on the wrong side. I sail single handed as well, my thinking is that sometimes I like to let out a little extra halyard and prefer it being pulled up instead of letting the spin hang down on the spin pole. This I use in light air and flattening it as much as possible so I can ‘reach’ a little higher. The other idea is that in strong wind the boat wants to nose dive and I think if I could have the sail pulled up high on the mast and let the bottom part (tack I think) run out significantly I think the sail might lift the bows up and let me push it harder.
Will_Lints
mission accomplished [Re: GeoffS] #181253
06/07/09 01:45 PM
06/07/09 01:45 PM
Atlanta
GeoffS Offline OP
GeoffS  Offline OP
Atlanta
Mission accomplished. See photos. I found the riser for the elliptical beam in the Catsailor store. I am sure Wouter will detect some geometrical issue with this installation that I have failed to consider. I haven't yet sailed the boat with the relocated spinnaker halyard cleat, but I think it is going to make single-handing much more enjoyable. Now... if I could just keep the thing from pitching so easily...
Page 1 of 3 1 2 3
0 registered members (), 16,267 guests, and 1,099 spiders.
Most Online22,490
Yesterday at 08:14 AM
