Hobie 17 rear crossbar #177908
05/12/09 07:37 AM
05/12/09 07:37 AM
H
Hullflyer1 Offline OP
H
I noticed that my rear crossbar cracked just inboard of the hull on both sides, yes both sides. Can this be welded? I would just replace it but I am having a hard time finding a used one in Florida any one out there have a used one. Thanks
Dave 561-632-0210
Re: Hobie 17 rear crossbar [Re: Hullflyer1] #177943
05/12/09 11:27 AM
05/12/09 11:27 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Got one here in the UK if you are desperate
paul
Re: Hobie 17 rear crossbar [Re: TEAMVMG] #177955
05/12/09 01:39 PM
05/12/09 01:39 PM
andrewscott
andrewscott
Yes aluminum can be welded.
I hear it may actually weaken the surrounding aluminum though. It should definatly repair the problem for a while at least. Probably worth doing vs replaceing.... (a lot cheaper) and should last for years.
BUT FIND A GOOD WELDER! i had a bad welder "repair" my TheMightyHobie18 rear beam.... (cracks underside at the beam bolts)
i gave him spacific instructions and when i wasn't looking.. he grinded off the rivets that held internal part in place
I stupidly gave him another try and have him an upper casting to handle some small stress cracks.. and he ended up breaking the casting completely.. then added about 4lb of metal to it to "fix" it... and he didn't even get it back on straight... (nor did he even remove the hard edges... it was razor sharp).
$350 later i purchased new castings.
Where in FL are you?
I HIGHLY recommend Brian, the welder at JSI in st pete (he is a good friend and does stellar work)
