| 52 degrees? #17799 03/27/03 02:31 PM 03/27/03 02:31 PM |
Joined: Aug 2002 Posts: 215 Durham, North Carolina jwrobie OP
Posts: 215 Durham, North Carolina | OK, I still don't have a wetsuit, and the water has now reached 52 degrees at Jordan Lake. I found some hypothermia tables: http://canoeman.com/SWPaddler/hypothermia.htmlIf I fell in , it looks like I have an hour before I get totally exhausted, and if I think the rangers would get to me within a half hour, I'm reasonably safe? I just want to get some verification of my thinking before finding out I was wrong the hard way... Jonathan | | | Re: 52 degrees?
[Re: jwrobie]
#17800 03/27/03 02:39 PM 03/27/03 02:39 PM |
Joined: Aug 2001 Posts: 22 San Juan, Puerto Rico Guer_J
Posts: 22 San Juan, Puerto Rico | I think the rangers would get to me within a half hour,... I'm reasonably safe? Jonathan : I think the premise should be: the rangers never will find me. ...then go from there. | | | Re: 52 degrees?
[Re: jwrobie]
#17802 03/27/03 03:39 PM 03/27/03 03:39 PM |
Posts: 3,114 BANNED | Jonathan, Jordan is populated with enough powerboaters that someone would take notice if you were turtled or otherwise not right side up. 52 is chilly, but not unbearable. Besides, with the weather getting better, there will be an exponential rise in the number of boaters on the lake this weekend. I'd be out there, but I'll be up in Maryland sanding away primer coat on my hulls | | | Core body Temp 98.6
[Re: h17windbtch6333]
#17804 03/27/03 03:41 PM 03/27/03 03:41 PM |
Posts: 1,253 Columbia South Carolina, USA | Okay, you learned that in elemantary school. 98.6 - 52= 46.6 degrees difference. You think you want feel that? The normal body reacts to cold by shunting blood to the vital organs and away from the limbs and extremeties. Your extremeties become hypoxic(lack of o2) and lose strength. You wont be able to swim distances that in normal conditions would be a cinch for you. It makes righting your body a feat of greatness, and getting back on it any tougher. Keep in mind the fact that once your core temp stops dropping, unconciousness follows quickly. People live being submersed because respiratory and cardiac function are depressed, the body shuts down, and sometimes can be brought back without any deficits. Not any fun though. Do what you can to Prepare. Sail safe and warm, David Mosley www.seacats.org
| | | Re: 52 degrees?
[Re: jwrobie]
#17805 03/27/03 03:41 PM 03/27/03 03:41 PM |
Posts: 12,310 South Carolina | 52 degrees is very cold without a wetsuit. Although you might "survive" an hour, survival and being able to function are two different things. Wanna check and see? Go swimming from shore and see how long you can stand it - I bet it won't take long! From my experience, after a couple of minutes with just my legs exposed in this kind of temperature they hurt pretty bad.
Don't ever count on any kind of rescue. That, and dependency on electronics, will eventually put you in trouble.
Jake Kohl | | | Re: 52 degrees?
[Re: jwrobie]
#17807 03/27/03 03:56 PM 03/27/03 03:56 PM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | Jaime and Jake make good points. Don't ever count on a rescue. Always approach the situation as if you're on your own. The tables can be misleading. How long you can survive is a much different thing than how long you can function. You may lose the ability to help yourself well before the hypothermia tables suggest.
52 degree water is still cold. Wear the wetsuit.
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
| | | Re: 52 degrees?
[Re: jwrobie]
#17809 03/27/03 04:45 PM 03/27/03 04:45 PM |
Posts: 833 St. Louis, MO, | Good posts here. Always be prepared to save yourself.
I would say you have about 5 minutes tops to get back on your boat before you are unable to save yourself. The amount of time varies greatly according to body mass. After 10 minutes you would have to be pulled from the water which a typical powerboater probably won't be able to do without help.
I was on a lake in a race course one time when I went turtle. Nobody saw me for about an hour in good weather. If you go completely turtle nobody will see you.
Mike Hill H20 #791
Mike Hill N20 #1005
| | | Re: 52 degrees?
[Re: tbosch]
#17810 03/27/03 04:50 PM 03/27/03 04:50 PM |
Posts: 215 Durham, North Carolina | The "Rule of 50": An average adult person has a 50/50 chance of surviving a 50-yard swim in 50-degree F water.
OK, I'll accept that as true. And if it is, I need a wetsuit. And my problem with wetsuits is this: I'm a Luddite, and I have no idea what I need, there's so many kinds of wetsuits, I'd rather not pay more than makes sense, and I have no idea what I need to do to make sure it fits. Can I buy something like that mail order and know that I will get the right size? Jonathan | | | Re: 52 degrees?
[Re: MauganN20]
#17815 03/27/03 06:31 PM 03/27/03 06:31 PM |
Posts: 215 Durham, North Carolina | Jon,
Go to Overton's on Wake Forest Blvd here in Raleigh. They have some store brand spring suits for like $59.00 that will work. So I take it I don't really need a top-of-the-line wetsuit, any garden variety wetsuit will work, as long as it is 3 mm? Jonathan | | | Re: 52 degrees?
[Re: jwrobie]
#17816 03/27/03 08:30 PM 03/27/03 08:30 PM |
Posts: 1,911 South Florida & the Keys | I guess you have to weigh the considerations and decide which has priority.
$200.00 +/- for protection, or........possible death.
Minutes count.
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: 52 degrees?
[Re: jwrobie]
#17818 03/27/03 10:23 PM 03/27/03 10:23 PM |
Posts: 12,310 South Carolina | There was a great thread that Mary started about wetsuits. A couple of things to consider (that I learned from that post). - a shiny outer surface will not be as cold when you are wet but out of the water. The shiny surface will not let the water evaporate from within the wetsuit as quickly as a wetsuit with a rough outer layer. This is important because you will quickly be exposed to a lot of wind again if you do go in or get wet from splashing. - Wearing a spray suit (or $20 Wal-Mart variety rain suit) will help keep you warm out of the water by keeping the wind from evapo-cooling the suit. - I recommend trying on wetsuits at local stores but remembering brand and sizing - then look for deals on the net if you need to. It's tough to get the fit right especially the first time. You can even buy suits on THIS site or look for discontinued / discounted stuff at places like www.sierratradingpost.com. - A 3mil shorty (5mil wouldn't be a bad idea) and a decent rain suit will get you through early spring in the Carolinas. A farmer John is a great choice too (and it gives you knee protection).
Jake Kohl | | |
1 registered members (basket.case),
483
guests, and 25
