| Re: Whats the preferred method to taper a mainsheet?
[Re: ]
#179374 05/22/09 09:37 AM 05/22/09 09:37 AM |
Posts: 586 Hobart, Tasmania, Oz. | It's a liros magic pro sheet that comes with a spectra core. originally its only a 6mm rope but i removed the core and added another 4mm core inside the core. the extra core fattens up the sheet just nicely.
24x4mm = 96mm or 4 inches there abouts. but the splice has no structural value as the core runs the entire length of the sheet without joins and carries the load.
Pepin, your right about the taper, havnt finished this sheet yet, just happened to be making a new one tonight.
[Re: Dazz]
#179382 05/22/09 10:38 AM 05/22/09 10:38 AM | andrewscott
| andrewscott
Unregistered | so you have a 6mm outerbraid with a 4mm core ...
shouldn't it be 24x6mm? (144mm /5.7inches)
[Re: NacraKid]
#179431 05/22/09 09:35 PM 05/22/09 09:35 PM |
Posts: 12,310 South Carolina | New wildcats have a 11:1 main sheet. Bit overkill i think, thinks it o just try and outdo the infusion, but 11:1 is too much on a f18, 10;1 is plenty. Bundy had cut his down to a 9;1 I still like 8:1 - it takes a lot of muscle, but you can actually trim from the skipper position with an arm movement.
Jake Kohl | | | Re: Whats the preferred method to taper a mainsheet?
#179433 05/22/09 09:46 PM 05/22/09 09:46 PM |
Posts: 586 Hobart, Tasmania, Oz. | Andrew, the 6mm outer becomes a 4mm line without a core in it. have a 6 inch splice if you want, not going to hurt either way.
Jake, when you move onto a sail with 1 meter square top you need less travel to have the same effect. I agree 11:1 is too much, I find 10:1 is over the top sometimes.
#179441 05/23/09 12:41 AM 05/23/09 12:41 AM |
Posts: 606 League City, TX | New wildcats have a 11:1 main sheet. Bit overkill i think, thinks it o just try and outdo the infusion, but 11:1 is too much on a f18, 10;1 is plenty. Bundy had cut his down to a 9;1 I still like 8:1 - it takes a lot of muscle, but you can actually trim from the skipper position with an arm movement. We use an 8:1 with the Harken 75mm block at the bottom. This seems to reduce the sheeting effort vs. the 57mm and you avoid the extra rope of the 9:1 | | | Re: Whats the preferred method to taper a mainsheet?
[Re: Dazz]
#179451 05/23/09 06:52 AM 05/23/09 06:52 AM |
Posts: 12,310 South Carolina | Andrew, the 6mm outer becomes a 4mm line without a core in it. have a 6 inch splice if you want, not going to hurt either way.
Jake, when you move onto a sail with 1 meter square top you need less travel to have the same effect. I agree 11:1 is too much, I find 10:1 is over the top sometimes. I agree if you are sailing around a buoy course with refined upwind sailing. However, we often find ourselves (in distance racing) on a gonzo reach and the 10:1 is just too slow to get back in after a gonzo blast.
#179674 05/26/09 09:28 AM 05/26/09 09:28 AM | andrewscott
| andrewscott
Unregistered | Thanks to all that helped with data | | | Re: Whats the preferred method to taper a mainsheet?
[Re: flumpmaster]
#179680 05/26/09 10:01 AM 05/26/09 10:01 AM |
Posts: 3,906 Clermont, FL, USA | I love my 10:1 and you'd have to pry it out of my cold dead hands before I go back to 8:1. Real skippers trim their own main :-)
468
guests, and 62
