| Anyone know how to mount a portopotty on a hobie #17935 03/29/03 08:52 PM 03/29/03 08:52 PM |
Posts: 7 | Hi, I am trying to find a way to mount a portopotty on my hobie 16. I have already cut down a cooler carrier, but the unit I purchased from west marine is too big. I have decided to carry a potty because I go on long trips with women, and they refuse to go without a potty. Does anyone have any ideas? | | | Re: Anyone know how to mount a portopotty on a hobie
[Re: Pointer]
#17939 03/30/03 07:31 AM 03/30/03 07:31 AM |
Posts: 43 Austin, TX | This thread is one of the last topics I ever expected to see here!
Be sure to post pictures after you do it, ought to be good for laughs and a few discussions down the road.
-Brandon
N5.5u #424
Austin, TX
[Re: Pointer]
#17945 03/30/03 04:02 PM 03/30/03 04:02 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Okay, here's how to do it. This is one of the best kept secrets in all the catsailing world. In fact, I'm surprised this how-to info is not more readily available. Best place to mount it on the H16 is on the tramp just aft of the mast (**with the portopotty user facing aft**). This works for most commercially available portopotty units. You'll need some 1.5" long nuts/bolts (SS recommended), galvanized water heater mounting straps (bolts should just fit through the holes), rubber washers, epoxy, 4 2x4s, 8" lag bolts, tie down straps, heavy bailing wire, and an opaque shower curtain. The portopotty should be empty for the installation process--it's lighter that way. First, you need a firm platform for the portopotty. Mount the 2x4s across the tramp just aft of the front crossbar and back about 18-20"; this give the portapotty a good foothold. Use two 2x4s above the crossbars and two below; "sandwich" the crossbars with the 2x4s and attach boards with the lag bolts. Next, place the unit on the boards and center it. Epoxy the head of two bolts onto the front facing side of the unit. Bend the water heater strap around the base of the mast to form a U-shaped bracket. Then bend the ends out so you can bolt the strap to the epoxied bolts,using the rubber washers to act as bushings. Make and bolt another strap around the mast about 5-6' up. Make a loop with the heavy wire, feed the opaque shower curtain on it and fasten this to the strap on the mast. This is the privacy curtain. Use the tie down straps to hold the unit in place (and keep the lid down) when not in use. Good luck with this noble project.
[Re: Pointer]
#17946 03/30/03 06:53 PM 03/30/03 06:53 PM |
Posts: 364 | Attach two 2x4's to the underside of the crossbars, extending 18" in front of the beam. Attach seat to the top of the two planks, and let 'er rip. Or get different crew, that will 1. Go over the side, or 2. Get in the water and go. Have fun, and DEFINITELY post pictures! sail fast
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
#17948 03/31/03 06:43 AM 03/31/03 06:43 AM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | I was on a trip recently with a woman who had adapted to outdoor potty needs by learning to pee while standing. Don't know if there was anything unique about the plumbing, but she'd just stand up, move here bathing suit out of the way, and pee over the side. (Granted, there was a bit of spray, but, given the alternatives, she didn't seem to mind.) Maybe she can teach a "How to Pee at Sea" clinic someday.
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: Kevin Rose]
#17949 03/31/03 07:43 AM 03/31/03 07:43 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Actually, a long time ago I saw advertised a little, plastic device called a Urinator, which kind of rerouted things and did indeed make it possible for a woman to pee standing up. I had thought about getting one, but then I stopped seeing it advertised. Anybody know if the thing still exists? | | | Re: Anyone know how to mount a portopotty on a hobie
[Re: Pointer]
#17950 03/31/03 10:12 AM 03/31/03 10:12 AM |
Joined: Jun 2001 Posts: 975 South Louisiana, USA Clayton
Posts: 975 South Louisiana, USA | Simple, get a Hobie on Steroids like a Stiletto 27  . A little harder to trailer though. On the porta potty thing. You would only need the top half of the unit. You are sitting in water if you need for flushing. Mount it in front of the beam like the Kat Kooler brackets, a big beach towel will work for the privacy curtain. Or she can sit on the tramp and pee thru the lacing. Bathing suit aside, pee, then the built in bidet (?sp) does the rest. Beach towel works here too. JMO Clayton S27, H16 | | | Re: Anyone know how to mount a portopotty on a hobie
[Re: Mary]
#17952 03/31/03 01:54 PM 03/31/03 01:54 PM |
Posts: 397 Burlington, Vermont USA | Actually, a long time ago I saw advertised a little, plastic device called a Urinator, which kind of rerouted things and did indeed make it possible for a woman to pee standing up. I had thought about getting one, but then I stopped seeing it advertised. Anybody know if the thing still exists? Yup. It even comes in a disposable version. ![[Linked Image]](http://www.magellans.com/images/product/detail/tw567.jpg) Uri-mate urination funnel Or, for a full discussion of the topic, visit the web site The Female Urinal. You'll see a page listed called, "Upright Urination". It is, however, still under construction.
Kevin Rose
N6.0na #215
Burlington, Vermont
2,758
guests, and 388
