Stealth jib setup #179602
05/25/09 02:18 PM
05/25/09 02:18 PM
scooby_simon Offline OP
Anyone got a picture?
I think I did it right today and it works, but I have a nagging feeling I should have more than 2:1 on the Halyard.
Re: Stealth jib setup [Re: scooby_simon] #179609
05/25/09 04:59 PM
05/25/09 04:59 PM
France
pepin Offline
pepin  Offline
France
On mine the jib halyard is a 1:1, along the luff, but the jib downhaul is a 2:1 back to the front beam. However I don't have a 3.7m2 F16 jib on a self tacker, I have the monster 4.9m2 'R' jib. It's going all the way down to the pole.
Re: Stealth jib setup [Re: pepin] #179615
05/25/09 07:15 PM
05/25/09 07:15 PM
My jib also goes all the way down to the pole.
I'm taking some mates out for a play over the next couple of weeks. I'm also thinking about sailing with all 2 sails for a bit of a giggle. Handicap drops mind... 0.913 (T is 0.935).
I guess I'll be flat wiring in about 4 kts laugh
Re: Stealth jib setup [Re: scooby_simon] #179698
05/26/09 11:55 AM
05/26/09 11:55 AM
Simon, some are rigged with 2:1, some 3:1. On my old boat (GBR527) it's a cascaded 4:1!
2:1 at the tack and the line from this comes back along the 'sprit, terminates in a Harken mini ball bearing block which is part of a 2:1 arrangement with a clamcleat. This makes adjustment really easy for the crew in all conditions.
Re: Stealth jib setup [Re: Jalani] #179714
05/26/09 01:09 PM
05/26/09 01:09 PM
I wondered what the extra cam cleat was for!!!
Does this mean you can move the jib up and down the forestay (to an extent) as both the tack and head are on a 2:1?
I just tied off the tack clew to the hoop that the Spi pole goes theu and put a 2:1 on the Halyard. I'd consider puting some sort of hook up top as you want to strech the sail and not the halyard (as per the T's) - Thanks to Phill for reminding me about this.
Not planning to sail much like this, might do the Piers with 3 sails if it looks like all day (but the handicap drops to 0.913!!!! - T is 0.935!!!!)
Re: Stealth jib setup [Re: scooby_simon] #179720
05/26/09 02:04 PM
05/26/09 02:04 PM
No the tack is fixed - what I meant was the halyard comes down the luff of the jib to a 2:1 at the tack. This 2:1 tail comes back along the bowsprit onto another 2:1 giving a total purchase of 4:1.............
Re: Stealth jib setup [Re: Jalani] #179745
05/26/09 03:28 PM
05/26/09 03:28 PM
Ahh, ok John.
Where does the tail of the first one go?
I'm lost as to where the following attach....
1, the top 1/2 of the cascade; one end attached somewhere, goes around a block on the halyard and then attaches to the 2nd 2:1 cascade
2, The second cascade (the only one I have) is attached to the cleat that is on the pole (so Pole clkam cleat top, block, thru clam cleat and cleat).
Re: Stealth jib setup [Re: scooby_simon] #179761
05/26/09 04:10 PM
05/26/09 04:10 PM
I don't know if this pic is clear enough to help?
The tail of this 2:1 purchase terminates in a single Harken mini block the same as the ones in the pic. This block is then subject to a second 2:1 purchase via a Racing Clamcleat mounted on the bowsprit just in front of the mast.
Jib Downhaul
Re: Stealth jib setup [Re: Jalani] #179784
05/26/09 06:37 PM
05/26/09 06:37 PM
Thanks John - just what I wanted
0 registered members (), 221 guests, and 21 spiders.
