Page 3 of 5 1 2 3 4 5
Re: Delta Ditch Run. [Re: F-18 5150] #180532
06/01/09 09:07 PM
06/01/09 09:07 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
We now have an F18 trailer that will be able to act as shore support in the event of a catastrophic failure. Hobie Tiger Frank will be following along.
Daisy is going to follow with Frank. 2 trailers , mine has triple rollers in the back with cradlesthat fit the tiger, and cradles up front.
That is all fantastic! Thank you Frank and Daisy!!!
I know the rest of you are thinking what the heck to these guys need with so much support? The Tybee teams should have so much.
We are not really a long distance group so let us ease into this thing. 75 mile here, 80 miles there...maybe we can get to the 500 mile races and not be too overwhelmed.
We are really lucky to get so many of the same boat (Formula 18) out for this race. Pease and Jay said that if we could get a group of 5 boats they would sail their Capricorn. If not they would be on a Tornado. Since we need 8 to make a class that is what we had to do and here we are. Nothing but Fun!
Later,
Dan
Re: Delta Ditch Run. [Re: Dan_Delave] #180545
06/02/09 12:50 AM
06/02/09 12:50 AM
california
F-18 5150 Offline OP
california
Just a thought.
Chris was looking for a ride from So Cal. Has anyone been able to hook him up yet? I know he was going to try Dennis and John , but if they don't make it can someone else? He was going to crew for me since Daisy can't sail this weekend.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Delta Ditch Run. [Re: F-18 5150] #180581
06/02/09 10:36 AM
06/02/09 10:36 AM
Dan_Delave Offline
Dan_Delave  Offline
I talked with Chris yesterday. He is all set. If we double stack with Mike Kramer he will be in the truck with the three of us. If we do not he will be coming with Mike Friday morning. I mentioned that the Mustang would be tight for three of us and he chose the roomy truck.
Later,
Dan
Re: Delta Ditch Run. [Re: Dan_Delave] #180591
06/02/09 11:35 AM
06/02/09 11:35 AM
Reno NV
Rhino1302 Offline
Rhino1302  Offline
Reno NV
You guys watching the weather? The delta is the central valley's AC system - usually the hotter it gets around Sacramento, the harder it blows through the delta.
Re: Delta Ditch Run. [Re: Rhino1302] #180610
06/02/09 01:30 PM
06/02/09 01:30 PM
Dan_Delave Offline
Dan_Delave  Offline
weather underground (wunderground.com) shows that Richmond will be a high of 58 and Stockton will be a high of 79. Is a 21 degree differential significant?
Re: Delta Ditch Run. [Re: Dan_Delave] #180632
06/02/09 02:37 PM
06/02/09 02:37 PM
Reno NV
Rhino1302 Offline
Rhino1302  Offline
Reno NV
That's a relatively low temperature for Stockton, would indicate lighter than normal wind.
Re: Delta Ditch Run. [Re: Dan_Delave] #180650
06/02/09 05:08 PM
06/02/09 05:08 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
There has been a 40 degree difference in temp between the bay and the central valley until the last couple days, with strong breezes. The forecast is for fairly mild temps (ie under 80 degrees) this weekend, so wind may be much lighter. But as long as there is some gradient, you'll be fine. One thing to watch, though, is that if a weather system is superimposed the flow can actually reverse. I haven't done the ditch "run" but it wouldn't be as much fun as the delta ditch "beat."
Have fun!
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Delta Ditch Run. [Re: ejpoulsen] #180805
06/03/09 02:59 PM
06/03/09 02:59 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
All,
I will be monitoring channel 72 not 6-8 as previously stated. That's channel 72
Re: Delta Ditch Run. [Re: SurfCityRacing] #180806
06/03/09 03:03 PM
06/03/09 03:03 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
72!!!
Isak Dinesen
E. B. White
Re: Delta Ditch Run. [Re: Team_Cat_Fever] #180826
06/03/09 04:52 PM
06/03/09 04:52 PM
M
mitch Offline
mitch  Offline
M
why don't you blokes stop by ventura and do the frenchie's rum run on the 27th? great race to anacapa and back...
Re: Delta Ditch Run. [Re: mitch] #180834
06/03/09 05:52 PM
06/03/09 05:52 PM
california
california
Daisy will also be on channel 72 with a chase truck and trailer. following with Frank and his chase trailer. Thanks to Dan and everyone involved in this good turn out. Daisy and Frank our Ground crew, and Jeremy and Johnny O our on the water support.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Delta Ditch Run. [Re: F-18 5150] #181292
06/08/09 02:21 AM
06/08/09 02:21 AM
Santa Cruz, CA
Santa Cruz, CA
With all of the gybing and hot angles, several of our F18 teams logged over 110 miles during this years Delta Ditch Run. Thank you to all of the volunteers, SSC the RYC and everyone else that helped out. Pretty much everyone except maybe 2 boats went swimming at some point during the race. No major injuries that I'm aware of in the F18 fleet except self inflicted damage at the party. A Hobie 20 had a bit of gear failure and ended up stuck against some pilings and had to get towed off, but other than that everything was outstanding!
Every time I'm on the water with this group of West Coast F18 sailors, I am reminded about what great people are attracted to catamaran sailing. I like watching sailboat racing, and a big thanks to all for the great entertainment!
Pease and Jay hooking up!
Phillip and Jake getting their tactics game on.
Mark and Tiffany going straight up the middle.
Re: Delta Ditch Run. [Re: SurfCityRacing] #181295
06/08/09 02:51 AM
06/08/09 02:51 AM
Only 9 minutes difference between the first F18 and the Formula 40 cat? That is pretty cool.
http://www.stocktonsc.org/ditch/Ditch2009Multi.pdf
Looking at the monohull results, I guess the multi sailors where home with their feet up before the first one finished grin.
Re: Delta Ditch Run. [Re: Tony_F18] #181301
06/08/09 04:03 AM
06/08/09 04:03 AM
Santa Cruz, CA
Santa Cruz, CA
This boat capsized later down the course due to an override on one of their spin sheet winches. We took the injured crew back to the Club. Our only real 'rescue'.
Thomas and Froeb lit up!
Re: Delta Ditch Run. [Re: SurfCityRacing] #181374
06/08/09 01:49 PM
06/08/09 01:49 PM
california
california
My gps showed 119 nauticle miles. 118 of those were upright.
What an experience , Thanks to Christopher for putting up with my lousy driving for 7 hours.
Thanks to Jeremy for the on the water support.
Thanks to Daisy, Frank, Patty and the other support trailer. (glad they weren't needed)
Next year is the 20 th Annual June 12th 2010. Who's in?
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Delta Ditch Run. [Re: SurfCityRacing] #181375
06/08/09 01:50 PM
06/08/09 01:50 PM
Santa Cruz, CA
Santa Cruz, CA
Yep, some dude sailed over 100 miles on a Wave!
Re: Delta Ditch Run. [Re: SurfCityRacing] #181378
06/08/09 02:07 PM
06/08/09 02:07 PM
In. Dan and I talked this morning about a coordinated package to attract cat sailors and make the logistics easy.
Re: Delta Ditch Run. [Re: F-18 5150] #181381
06/08/09 02:19 PM
06/08/09 02:19 PM
California
Skipshot Offline
Skipshot  Offline
California
You went nearly twice as far as the course estimate and you still beat me on an overloaded Olson 30 by 1 hour 20 minutes. I think I saw you cross San Pablo bay three times.
My first DDR, had a great time, the winds weren't nuking, but no more leaners for me; even reports of beach cat wreckage strewn about the course won't get me back on a slow boat.
Re: Delta Ditch Run. [Re: SurfCityRacing] #181382
06/08/09 02:20 PM
06/08/09 02:20 PM
I saw the wave in the results and was astonished - VERY impressive!
Re: Delta Ditch Run. [Re: SurfCityRacing] #181384
06/08/09 02:24 PM
06/08/09 02:24 PM
Alright, respect !
The two of them sailed for 11 hours and 8 minutes !
Where the fastest F18 cat did it in 5 hours and 30 minutes (3rd over the line behind F40 and a D-class catamaran.
Even the slowest leaners did it in about 9 hours 30 min except one who spend 11 hours and 3 min on the course.
That is was a long sit for the Wave crew and quite possibly also a lonely trip !
I admire their spirit !
Next stop ? The crossing to Cuba !
0 registered members (), 22,585 guests, and 498 spiders.
Yesterday at 04:54 AM
