Pole end setup #181941
06/14/09 12:47 PM
06/14/09 12:47 PM
France
pepin Offline OP
pepin  Offline OP
France
To support my new spi I need to lenghten my spi pole. I'm sleeving a new part at the end but I was wondering what innovative setup you have to attach the tack block and the two bridles all the way out there.
I don't like the system I have so far on the F16, it has an eye on each side where the bridle connects and the block is attached via a small line between the eyes. This means that the block moves around and I had the line fouling more than once.
The "classic" system is to have an eye on top with a block on a spring and the bridles simply making a loop around the pole via the eye. Works, but raises the tack of the spi fairly high and the risk of fouling the tack line around the block or the pole end is not negligible.
I like the system I have on the 5.2, where the end of the pole is plugged by a plastic plug with a hole on it (Where can I source one of those in the UK?). There is no block, the line goes inside the pole and exits further down. But the bridle lines are attached via small holes in the pole and that doesn't inspire confidence.
What system do you use? Anything you'd like to recommend? Pics? The pole on my F16 is carbon if this makes a difference.
Re: Pole end setup [Re: pepin] #181945
06/14/09 01:35 PM
06/14/09 01:35 PM
Southampton UK
NacraKid Offline
NacraKid  Offline
Southampton UK
Just have a block on the end of the pole, it's simple, least fricton and to this point ive never had a problem with it.
If you really want an end plug you can get one from Rob White who makes the spitfire, shadow, shockwave.
Re: Pole end setup [Re: NacraKid] #181952
06/14/09 02:41 PM
06/14/09 02:41 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Dennis at Barefoot Studios makes a nice aluminum end pole tack guide. Works great.
http://www.gobarefootstudio.com/snu.html
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
R.Vilvens@yahoo.com
Fairfield, Ca
F-18 5150
Re: Pole end setup [Re: pepin] #181988
06/15/09 07:39 AM
06/15/09 07:39 AM
waynemarlow Offline
waynemarlow  Offline
Sort of sounds like the end plug on my F16, strange that, now how did I make that plug ? grin
0 registered members (), 687 guests, and 126 spiders.
Posts267,056
