Hobie 16 mast base change #182037
06/15/09 06:48 PM
06/15/09 06:48 PM
Gainesville, FL 32607 USA
dacarls Offline OP
dacarls  Offline OP
My new/old Hobie 16 hs a beat-up mast socket. I contemplated taking it off & getting it welded to restore its ears (on each side of the socket). However, how do you get it off the front crossbar? Is there an aluminum insert inside the crossbar that holds the dolphin striker rod?
Remove the dolphin striker rod- ain't working.
Drilled out the pop rivets- base ain't loose.
Now what-- please help.
Dacarls:
Re: Hobie 16 mast base change [Re: dacarls] #182045
06/15/09 07:55 PM
06/15/09 07:55 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Go to Hobie 16 Forum. There's been many discussions about your problem.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Hobie 16 mast base change [Re: hobie1616] #182046
06/15/09 07:57 PM
06/15/09 07:57 PM
X
xanderwess
xanderwess
X
I have a couple of them extra if you need one. [email protected]
Re: Hobie 16 mast base change [Re: ] #182134
06/16/09 02:31 PM
06/16/09 02:31 PM
California
mmiller Offline
mmiller  Offline
California
That would be the mast "step" casting.
http://www.hobiecat.com/support/pdfs/h16-step-replace.pdf
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 606 guests, and 636 spiders.
