Jib installation - raising? #182921
06/24/09 08:32 PM
06/24/09 08:32 PM
Grand Rapids, MI
Ron in MI Offline OP
Grand Rapids, MI
The manual I found online says.
"Raise the jib the remaining distance, then tension the line until there is 4" to 5" of slack in the forestay."
Can someone explain what this means? I've been raising the jib as high as it will go. then I tie it off.
the forestay is the front cable that holds the mast up right?
So how does the jib raising... give 4-6" of slack in the forestay? doesn't make sense to me - please help.
thanks
Re: Jib installation - raising? [Re: Ron in MI] #182927
06/24/09 09:35 PM
06/24/09 09:35 PM
K
Ken Weir Offline
Ken Weir  Offline
K
When you raise the jib it is meant to carry all the strain.
Re: Jib installation - raising? [Re: Ken Weir] #183058
06/25/09 01:43 PM
06/25/09 01:43 PM
California
mmiller Offline
mmiller  Offline
California
The jib has a wire (luff wire) that becomes the forestay when properly rigged. It must take the full load of the rig to perform properly. The H16 "forestay" only holds the mast up when the jib is not hoisted. So, yes... tension the rig with the jib halyard and the forestay goes slack. It just hangs in a shallow arch of about 3-4 inches or more. Some sailors tie a small bungee to the forestay to pull some tension forward and keep it from flopping around.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Jib installation - raising? [Re: mmiller] #186100
07/24/09 04:12 PM
07/24/09 04:12 PM
Grand Rapids, MI
Grand Rapids, MI
THANKS - yes I finally noticed what was happening and I'm getting the slack in the forestay. Was confusing at first.
0 registered members (), 510 guests, and 40 spiders.
