creeky cat #183585
06/30/09 07:42 AM
06/30/09 07:42 AM
Monroe Mi, ( Breast Bay )
ddubb Offline OP
ddubb  Offline OP
the 79 h-16 i just bought creeks somthing feirce. would lubeing the post sockets with teflon, graphite or such help the matter?
Sailing regularly for 14 yr's, club raceing T-Ten for 8, but new to having and sailing a cat "79" H-16. Strongly want to excell at this with knowledge from people who know and love it.
Re: creeky cat [Re: ddubb] #183595
06/30/09 07:56 AM
06/30/09 07:56 AM
Probably a little bit, but for the most part not really. Shimming the pylons with pieces of aluminum cans and keeping the tramp tight helps a bit, but as a reference I bought a brand new H16 in 2006 and it squeaked only slightly less than the 85' H16 I had replaced.
If you aren't, you should be using a bearing on the mast cup. That'll squeak like crazy if you don't have one in there.
Re: creeky cat [Re: Karl_Brogger] #183600
06/30/09 08:14 AM
06/30/09 08:14 AM
ddubb Offline OP
ddubb  Offline OP
thanks karl, and i happen to have some real aluminum stock for shimming. thanks again smile
Re: creeky cat [Re: ddubb] #183610
06/30/09 09:20 AM
06/30/09 09:20 AM
andrewscott
andrewscott
If used "BUD" cans are good enough for the corner panels of my car.. they are good enough for your shims!!! (kidding)
Re: creeky cat [Re: ] #183617
06/30/09 09:32 AM
06/30/09 09:32 AM
France
pepin Offline
pepin  Offline
France
A drastic solution is to epoxy the corner castings in place. Makes the platform more rigid and stops the squeaks.
Re: creeky cat [Re: ddubb] #183640
06/30/09 10:24 AM
06/30/09 10:24 AM
hmmm...to me, that creaking was always the sign/sound of a new boat. After the pylons and corner castings got some wear, and loosened up, that creaking would slowly go away. "Sounds" like you got a keeper. grin
Re: creeky cat [Re: Karl_Brogger] #183657
06/30/09 11:10 AM
06/30/09 11:10 AM
DougSnell
DougSnell
Save a bunch of money from Hobie and find a piece of thin wall pipe the size of the pylon puck. Sharpen the edge on a grinder. Buy sheets of Teflon at hardware store and punch out and make your own pucks. That is what I did back in early 80's for mine.
Doug
0 registered members (), 255 guests, and 10 spiders.
