Re: Sail Numbers [Re: Team_Cat_Fever] #183664
06/30/09 11:27 AM
06/30/09 11:27 AM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Todd,
To answer your question, while I was not upset upon hearing Micheal Jackson passed on .... I do miss Jerry Garcia!!! ... one of my Top Ten Songs is "Mexicali Blues" .... I also believe I read somewhere that according to "Official" government surveys that 91% of the younger population had tried "MaryJane" at that time ....
When you are on a fast reach on a P19 as the bows carve through the water, let the bows drive down until you have 4-6" of freeboard ... the spray coming off the leeward hull will make a rainbow in the spray if the sun's angle is just right .....
Of course those big square hulls of the I/N20 skip over the water ..... splash, splash, splash ... no rainbows ... boo hoo, boo hoo ......
Hey, maybe you can buy your ol' P19 back CHEAP
Harry
Re: Sail Numbers [Re: HMurphey] #183670
06/30/09 12:12 PM
06/30/09 12:12 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
hey Harry,
Try looking for the next puff instead of tripping out on bow spray.
I wouldn't mind having a P-19 again to fool around with, but I'm up to my eyeballs in boatwork as it is, no time for anymore.
Tawd
Isak Dinesen
E. B. White
Re: Sail Numbers [Re: ] #183688
06/30/09 02:09 PM
06/30/09 02:09 PM
Central Texas
Derrick Offline OP
Derrick  Offline OP
Central Texas
Harry,
Thanks for all the great info. I crewed on my brother-in-law's P19 in the early 90's all over northern California, including a few races in San Francisco Bay. I also owned and raced a TheMightyHobie18 and H16 before that. Although my time at the helm of P19 is limited, I remember now the sensation you have described. Scary at that speed! I want home and checked the front crossbar and all appears fine. I don't think this boat ws ssailed too hard. The bottoms look great for the age as well as other items. Teh bows also look and feel straight ahead of the crossbar. I couldn't find the post about the crossbar reinforcement after looking through your past posts and searching, but I am new here and may not be searching it correctly.
Also, as you can see form early in this thread, my boat is also a '86 as indicated by the last two numbers in the hull number like yours. I have been told the last two numbers in all hull numbers (powerboats and sail) indicate the year built. Yet your sail numberis 86. My bother-in-law's was an 85 and his sail number was 71. Who knows?
Please send my a clue on how to find the post on reinforcing the crossbar and I could really use the tuning guide with mast rake, rudder rake and diamond wire numbers.
Thanks,
Derrick
Re: Sail Numbers [Re: Timbo] #183689
06/30/09 02:14 PM
06/30/09 02:14 PM
rexdenton Offline
rexdenton  Offline
Originally Posted by Timbo
30 years ago I flew for a charter company out of Boston. The owner wanted to buy a Lear Jet.
Well, nobody puts "names" on their Lear Jet, (this ain't WW2) so instead he put their wedding anniversary date on the tail as the official FAA Registered Tail Number: 856JB, which stood for Aug. 1956, John and Bernice.
Nacra F18 #856 Where's my matching Lear Jet? It was not delivered with my F18. (I could use it this weekend at the Statue of Liberty Race; it is the only way we will ever go fast enough to win!
Nacra F18 #856
Re: Sail Numbers [Re: rexdenton] #183690
06/30/09 02:17 PM
06/30/09 02:17 PM
ere 'tis from another thread. Unless you go with the mx rig then it's different.
Todd
Isak Dinesen
E. B. White
Re: Sail Numbers [Re: rexdenton] #183692
06/30/09 02:26 PM
06/30/09 02:26 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Who made your jib?
F18 USA 242
http://www.solarwind.solar
Re: Sail Numbers [Re: David Ingram] #183694
06/30/09 02:28 PM
06/30/09 02:28 PM
rexdenton Offline
rexdenton  Offline
Performance. Why do you ask?
Nacra F18 #856
Re: Sail Numbers [Re: rexdenton] #183695
06/30/09 02:39 PM
06/30/09 02:39 PM
Clermont, FL, USA
Clermont, FL, USA
I didn't see the patch and it's not fully battened, so I assumed it wasn't a Vink sail. I was just curious.
F18 USA 242
Re: Sail Numbers [Re: Team_Cat_Fever] #183710
06/30/09 04:18 PM
06/30/09 04:18 PM
Central Texas
Derrick Offline OP
Derrick  Offline OP
Central Texas
Todd,
If you meant to send me a link to the info requested earlier, it is not showing up. I am running the original rig, no MX ...yet.
Derrick
Re: Sail Numbers [Re: Derrick] #183713
06/30/09 04:38 PM
06/30/09 04:38 PM
Dallas, TX
L
lonestarcat Offline
lonestarcat  Offline
L
Dallas, TX
Prindle 19MX
Re: Sail Numbers [Re: lonestarcat] #183717
06/30/09 04:48 PM
06/30/09 04:48 PM
Central Texas
Derrick Offline OP
Derrick  Offline OP
Central Texas
Great info Bob and thanks.
I think there is also a guide to set info like mast, rudder, and spreader rake, shroud hole location and diamond wire tension. Any ideas?
Thanks,
Derrick
Re: Sail Numbers [Re: Derrick] #183718
06/30/09 05:02 PM
06/30/09 05:02 PM
Dallas, TX
L
lonestarcat Offline
lonestarcat  Offline
L
Dallas, TX
I will copy the e-mail Skip Elliot sent me when I asked for this info. But it relates to the MX sailplan.
In Rick's book there is a whole chapter on the original sail plan by Randy Smyth. I think he said he put the rake at 8" in front of the rear beam using the trapeze wire to measure. Then the rudder rake is set to provide desired weather helm.
As I said before I sailed it for years with original equipment using only the guidance in the owner's manual which is still available on the performance cat web site. With all due respect to Mr. Murphey, I would buy a different boat if it were necessary to do all he has done with his. I have been too lazy to reinforce my main beam or my rudders.
Hi Robert,
The way I set up The Prindle 19 mainsail with the mast.
Start by setting the spreader back behind the mast 2"
This is with a straight edge set from wire to wire and measuring the distance to the mast groove.
The next is to set the tension on the wire so the mast has a perbend of 1" measure at the spreader with the mast set side way so the line from the top of the mast to the gooseneck will sag only to the ground and not to the mast. The line need to be tie to the groove at the top and bottom.
This is where I would start and from. If you are sailing light and need to flatting the sail start first by putting on more tension or the wire. so that you have more prebend
Now if you are sailing with more weight you may take out some prebend with looser wire tension. or you could take out some spreader down to 1.5"
When it come to the spreader rake be carefully of putting in too much in
This will make the mast bend too much in the middle and make the upper part fall off and the boat will not point up wind very well. This will start start to happen when you get past 3"
Keep a record of what you set the mast too and only change on think at a time. In this way you will know if the change was good or not and will be able to go back and try another setting.
Good sailing.
Skip
Prindle 19MX
Re: Sail Numbers [Re: lonestarcat] #183746
06/30/09 11:14 PM
06/30/09 11:14 PM
HMurphey Offline
HMurphey  Offline
Hi Derrick,
The fixes/improvements I done haven't cost much in $$$$s but have just taken a little thought and some time. It gives me something to do after dinner in the evenings, also I was using the P19(MX) for doing point-to-point distance races here on the Chesapeake Bay .... no safety boats ... rough conditions sometime ... so when something important broke I fixed it and tried to strengthen/improve it. I had heard of previously of front crossbars failures on NACRA's and some Prindles ... when mine failed after I had up-graded to a MX rig and 25sqM spin I thought ... you've increased the loading from increasing the sailplan ... what did you do to increase the strenght of the platform itself to handle the increased loads???? Hence the reinforcing of the front crossbar and actually it was easy to do requiring the old broken crossbar for material, a Bosch Jigsaw, a 13lb sledgehammer, couple blocks of wood and a solid backstop (concrete curb).
And I did most of these, one improvement at a time ... over the years as I fixed what broke.
As for the rudder blades my first "elipitical" set split in approximently 40hrs of sailing ... the replacement set (of the replacement set) followed suit after the same amount of sailing. So I wasn't going to buy a third set and I couldn't locate a set of P18 Blades .... into the garage after dinner I went ... again not much $$$$, just some 3/8" dowel stock, a 3/8" drill bit, a little Epoxy&cloth, sandpaper and elbow greese(cold beer?).
I'll try and locate that thread where I reviewed how I strengthened the front crossbar.
Enjoy the process of rebuilding your P19 .... it makes sailing her all that much sweeter .....
HarryMurphey
TheMightyHobie18(Mag)/P19MX
Re: Sail Numbers [Re: HMurphey] #183747
06/30/09 11:19 PM
06/30/09 11:19 PM
HMurphey Offline
HMurphey  Offline
Oh, I forgot or am I mixing threads ... the mast rake for my origonal Smythe "pinhead" sailplan was 12-14" in FRONT of the rear crossbar .... Smythes MX Sailplan; 12" behind the transom.
Harry
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
