| Carbon Fiber Mast repair #184101 07/03/09 09:45 PM 07/03/09 09:45 PM |
Joined: Apr 2002 Posts: 805 Gainesville, FL 32607 USA dacarls OP
Posts: 805 Gainesville, FL 32607 USA | I am supposed to help a fellow sailor repair his carbon mast -A-cat. I have done this very successfully before. But- Suggestions for finding carbon mast sections would be welcome. Thanks.
| | | Re: Carbon Fiber Mast repair
[Re: dacarls]
#185875 07/22/09 07:46 PM 07/22/09 07:46 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | I will be attempting to make one good F17 mast out of 2. Once clean break and one crushed for about 18". Cut a piece out of the crushed one, trim off the sail track and squeeze it down for an inner sleeve- say 18" long. West system epoxy it in place.
I would appreciate any advice and/or details.
E-Scow 24' ULDB
[Re: FasterDamnit]
#185902 07/22/09 10:17 PM 07/22/09 10:17 PM | Scarecrow
| Scarecrow
Unregistered | better yet use a section of the crushed one as a mould for a sleeve.
1. Cut a 2 foot "good section" of mast 2. cut it down the centre line. 3. Lay one half of the mast on a flat surface and laminate on some flanges. 4. Introduce the other half and make some matching flanges. 5. drill bolt holes though flanges. 6. cleanup and wax inside of "mould" 7. using a vac bag lay up sleeve in mould. 8. fix "clean broken mast" with sleeve 9. grind and tape over joint. 10. that was a much bigger job than you planned but the result will be better. | | | Re: Carbon Fiber Mast repair
[Re: ]
#185964 07/23/09 11:20 AM 07/23/09 11:20 AM |
Posts: 531 Lake Murray SC | No equipment for vacuum bagging- just basic hand tools. I have repaired aluminum masts w/ inner sleeves and rivets or outer sleeves (depending on available spare sections) up 46' with good results.
E-Scow 24' ULDB
2,424
guests, and 182
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
