| Towing #184165 07/05/09 01:53 PM 07/05/09 01:53 PM |
Joined: Jun 2006 Posts: 110 Northern California, USA RyanMcHale OP
Posts: 110 Northern California, USA | As a staff member at our local club, I've had to 'rescue' Sunfish a couple times using my Hobie 14 Turbo as a 'Tow Truck', tacking with another boat in tow is a Pain!!! Does anybody have suggestions to make it easier in the future?
Ryan McHale Hobie 14 (battened jib)
| | | Re: Towing
[Re: RyanMcHale]
#184187 07/05/09 10:36 PM 07/05/09 10:36 PM |
Posts: 805 Gainesville, FL 32607 USA | Use 2 tow boats. H14 turbos are not the best fit this- too small. I have towed a dead 16 foot powerboat sucessfully in the ocean with 2 Hobie 18s-- 6 miles to weather. We used a long tow line and a shorter tow line. When tacking, the inside boat had to pull up its boards and rudders, but it worked great. We even beat one of our Hobie 14 sailors back to the Cedar Key, Florida Beach.
| | | Re: Towing
[Re: dacarls]
#184213 07/06/09 09:27 AM 07/06/09 09:27 AM | andrewscott
| andrewscott
Unregistered | its a good idea to make a bridal for the tow line so the other boat doesn't pull you backwards in a tack...
also its a good idea to rig the tow line with a quick release knot if you can so you can "dump" the other boat if you need to | | | Re: Towing
[Re: RyanMcHale]
#184227 07/06/09 10:54 AM 07/06/09 10:54 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | It would make a difference in towing technique depending on whether the towed boat has a person aboard who is able to steer his boat.
If that is the case, when the tow boat wants to tack, let's say from port tack to starboard tack, the boat in tow could steer to the right, which would help pull the stern of the tow boat to the right and actually help the tack. Correct?
I DO know that a Laser can successfully tow a disabled Hobie skiff powerboat. Don't ask me how I know. | | | Re: Towing
[Re: RyanMcHale]
#184236 07/06/09 11:55 AM 07/06/09 11:55 AM |
Posts: 1,203 uk | Use a very very long towline
477
guests, and 38
