Welcome Shark Catamaraners #181653
06/10/09 01:24 PM
06/10/09 01:24 PM
RickWhite Offline OP
This forum is for you! Enjoy
Rick
Rick White
www.onlinemarinestore.com
Re: Welcome Shark Catamaraners [Re: RickWhite] #181691
06/10/09 10:04 PM
06/10/09 10:04 PM
Penfield NY
rturbett Offline
rturbett  Offline
Penfield NY
Thanks Rick,
I will spread the word to the others
Rob
Re: Welcome Shark Catamaraners [Re: rturbett] #184683
07/09/09 08:05 PM
07/09/09 08:05 PM
H
hoeks Offline
hoeks  Offline
H
I am looking at a 70's vintage fiberglass hull Shark in real good condition. Hoping for a drier sailing experience than my Hobie 18 and possibly some camping with it in the islands of northern lake Michigan. Would this be a good boat for me? What's a fair price for one? How fast and how much breeze can this thing handle? Thanks much, Marc
Re: Welcome Shark Catamaraners [Re: hoeks] #185034
07/13/09 05:01 PM
07/13/09 05:01 PM
H
hoeks Offline
hoeks  Offline
H
I bought the Shark I mentioned above. Could someone send me info on nationals at Put in Bay? I'd like to check it out. thanks, Marc
Re: Welcome Shark Catamaraners [Re: hoeks] #185099
07/14/09 09:40 AM
07/14/09 09:40 AM
Check with Christina Perrin
<shark609 at bluefrog.com>
Rick White
Re: Welcome Shark Catamaraners [Re: hoeks] #185237
07/15/09 03:18 PM
07/15/09 03:18 PM
C
cperrin Offline
cperrin  Offline
C
Hi Marc,
Here is the link for information regarding nationals: http://sharkcatamaranclass.org/2009%20invite%20to%20nationals.htm
Hope to meet you there!
Christina
Re: Welcome Shark Catamaraners [Re: rturbett] #185260
07/15/09 09:07 PM
07/15/09 09:07 PM
Canandaigua, NY
bryan Offline
bryan  Offline
Canandaigua, NY
I know a lot about the old sharks and I have parts. Is it an old Gibbs?
Re: Welcome Shark Catamaraners [Re: bryan] #186325
07/28/09 09:03 AM
07/28/09 09:03 AM
H
hoeks Offline
hoeks  Offline
H
Yes it is an old Gibbs. I hope to go to Put in Bay to see how everyone else makes theirs go. Any info on tuning or improvements would be appreciated! thanks
Re: Welcome Shark Catamaraners [Re: hoeks] #186528
07/30/09 07:43 AM
07/30/09 07:43 AM
H
hoeks Offline
hoeks  Offline
H
One thing I am having trouble with as a new Shark owner is my mast doesn't rotate well and the base is wanting to spread apart. Does anyone bolt these two halves together? Do you grease it too?
Re: Welcome Shark Catamaraners [Re: hoeks] #186592
07/30/09 05:26 PM
07/30/09 05:26 PM
Penfield NY
rturbett Offline
rturbett  Offline
Penfield NY
I think you may see that the sharks are using a different base than what you have. Grease will help(an appropriate silicone spray). I know the one shark that i saw that had a split base had a half dollar on it- part for superstitious good luck, and part to help the mast rotate.
The biggest thing to make a shark go fast is new sails. It puts even the older boats up close to the new ones.
Second, check your boards and make sure they are smooth, as well as the rudders. Measure the rudders on the leading edge and trailing edge to be sure they are parallel.
The gaskets underneath need to be in good shape. If they are loose or sloppy, that means drag
Do anything to get excess weight off the boat. The class weight is 450lbs. Fiberglass boats are going to be heavier, but can still be competitive. The flotation foam put in some sharks is notorious for absorbing water over time.
Have fun in Put-in Bay!
Rob
