| How to check hulls... #185839 07/22/09 02:28 PM 07/22/09 02:28 PM |
Posts: 171 Cary, NC | Rare, and awesome opportunity to get into a free boat has come up and I am heaading out tomorrow to pick it up barring any thing massivly wrong with it. How do I check the hulls for soft spots etc?
Ryan 1983 Isotope
| | | Re: How to check hulls...
[Re: Storz]
#185843 07/22/09 03:25 PM 07/22/09 03:25 PM |
Posts: 1,200 Vancouver, BC | Push/press your fingers on them! A mushy deck will compress easily with finger loads. Can be repaired if not extensive (using thickened epoxy injected by syringe into small holes drilled in outer skin).
Try tapping along the decks/freeboard...a good well made hull will make a sharp tap sound, not a dull thud.
[Re: Tornado]
#185844 07/22/09 03:27 PM 07/22/09 03:27 PM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac
Posts: 267 Ocean Springs, MS | i wouldn't look a gift boat in the hulls...
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | | Re: How to check hulls...
[Re: Capt_Cardiac]
#185849 07/22/09 03:45 PM 07/22/09 03:45 PM | andrewscott
| andrewscott
Unregistered | i wouldn't look a gift boat in the hulls... But i would leave a crap cat out for trash! A Gift can be much more work than its worth... | | | Re: How to check hulls...
[Re: Storz]
#185850 07/22/09 03:47 PM 07/22/09 03:47 PM |
Posts: 1,200 Vancouver, BC | More important than soft decks/hulls on older T's...check for structural cracks radiating from the centerboard trunk opening at the deck. This is a highly stressed area of the hull and cracks do develop. Can be fixed with grinding out and layers of glass epoxy.
Also look for beam dimples where the beam bolts go through (sign that owner over torqued them). Problematic if this can be fixed without beam replacement. Stripped bolt threads in the hulls can be repaired eitehr with helicoil inserts or replacement of the aluminum block glassed inside the hull (difficult to reach but doable).
[Re: Tornado]
#185886 07/22/09 08:51 PM 07/22/09 08:51 PM |
Posts: 171 Cary, NC | Thanks for the tips. I'll try to post some pics of it tomorrow when I get home!!
Ryan 1983 Isotope
19,133
guests, and 1,208
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online22,490 13 hours ago | | | |
