Carbon Fiber Mast repair #184101
07/03/09 09:45 PM
07/03/09 09:45 PM
Gainesville, FL 32607 USA
dacarls Offline OP
dacarls  Offline OP
I am supposed to help a fellow sailor repair his carbon mast -A-cat. I have done this very successfully before. But-
Suggestions for finding carbon mast sections would be welcome.
Thanks.
Dacarls:
Re: Carbon Fiber Mast repair [Re: dacarls] #185875
07/22/09 07:46 PM
07/22/09 07:46 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
I will be attempting to make one good F17 mast out of 2. Once clean break and one crushed for about 18". Cut a piece out of the crushed one, trim off the sail track and squeeze it down for an inner sleeve- say 18" long. West system epoxy it in place.
I would appreciate any advice and/or details.
E-Scow
24' ULDB
Re: Carbon Fiber Mast repair [Re: FasterDamnit] #185902
07/22/09 10:17 PM
07/22/09 10:17 PM
Scarecrow
Scarecrow
better yet use a section of the crushed one as a mould for a sleeve.
1. Cut a 2 foot "good section" of mast
2. cut it down the centre line.
3. Lay one half of the mast on a flat surface and laminate on some flanges.
4. Introduce the other half and make some matching flanges.
5. drill bolt holes though flanges.
6. cleanup and wax inside of "mould"
7. using a vac bag lay up sleeve in mould.
8. fix "clean broken mast" with sleeve
9. grind and tape over joint.
10. that was a much bigger job than you planned but the result will be better.
Re: Carbon Fiber Mast repair [Re: ] #185964
07/23/09 11:20 AM
07/23/09 11:20 AM
Lake Murray SC
Lake Murray SC
No equipment for vacuum bagging- just basic hand tools. I have repaired aluminum masts w/ inner sleeves and rivets or outer sleeves (depending on available spare sections) up 46' with good results.
E-Scow
24' ULDB
0 registered members (), 2,376 guests, and 222 spiders.
