How to check hulls... #185839
07/22/09 02:28 PM
07/22/09 02:28 PM
Cary, NC
Storz Offline OP
Happy Birthday Storz  Offline OP
Cary, NC
Rare, and awesome opportunity to get into a free boat has come up and I am heaading out tomorrow to pick it up barring any thing massivly wrong with it. How do I check the hulls for soft spots etc?
Ryan
1983 Isotope
Re: How to check hulls... [Re: Storz] #185843
07/22/09 03:25 PM
07/22/09 03:25 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Push/press your fingers on them! A mushy deck will compress easily with finger loads. Can be repaired if not extensive (using thickened epoxy injected by syringe into small holes drilled in outer skin).
Try tapping along the decks/freeboard...a good well made hull will make a sharp tap sound, not a dull thud.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: How to check hulls... [Re: Tornado] #185844
07/22/09 03:27 PM
07/22/09 03:27 PM
Ocean Springs, MS
Capt_Cardiac Offline
Ocean Springs, MS
i wouldn't look a gift boat in the hulls...
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: How to check hulls... [Re: Capt_Cardiac] #185849
07/22/09 03:45 PM
07/22/09 03:45 PM
andrewscott
andrewscott
But i would leave a crap cat out for trash!
A Gift can be much more work than its worth...
Re: How to check hulls... [Re: Storz] #185850
07/22/09 03:47 PM
07/22/09 03:47 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
More important than soft decks/hulls on older T's...check for structural cracks radiating from the centerboard trunk opening at the deck. This is a highly stressed area of the hull and cracks do develop. Can be fixed with grinding out and layers of glass epoxy.
Also look for beam dimples where the beam bolts go through (sign that owner over torqued them). Problematic if this can be fixed without beam replacement. Stripped bolt threads in the hulls can be repaired eitehr with helicoil inserts or replacement of the aluminum block glassed inside the hull (difficult to reach but doable).
Mike Dobbs
Re: How to check hulls... [Re: Tornado] #185886
07/22/09 08:51 PM
07/22/09 08:51 PM
Cary, NC
Storz Offline OP
Cary, NC
Thanks for the tips. I'll try to post some pics of it tomorrow when I get home!!
Ryan
1983 Isotope
Re: How to check hulls... [Re: Storz] #185967
07/23/09 12:35 PM
07/23/09 12:35 PM
Cary, NC
Storz Offline OP
Cary, NC
Well no tornado for me. The hulls were totally soaked, soft and rotting. Oh well I had to at least check it out. On with the isotope plan smile
Ryan
1983 Isotope
Re: How to check hulls... [Re: Storz] #185982
07/23/09 02:44 PM
07/23/09 02:44 PM
Graham, NC
WindyHillF20 Offline
Graham, NC
Is the boat you looked at in the Raleigh area? I'm looking for an impossible project for when I'm layed off.
Re: How to check hulls... [Re: WindyHillF20] #185985
07/23/09 02:50 PM
07/23/09 02:50 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
Bummer. That would have been an awesome.
0 registered members (), 2,533 guests, and 195 spiders.
