| Re: My boat seems to drag? help
[Re: Ron in MI]
#186093 07/24/09 03:56 PM 07/24/09 03:56 PM |
Posts: 160 North Carolina | The more you rake your mast back, the more you have to rake your rudders under the boat. Drag is a problem I have right now with my set up in high winds. My rudders aren't raked under my boat enough and when the wind picks up it is like putting on the breaks. There is a way to measure both, but I can't remember where I saw them last. I've bought some new rudders (EPO's) and have found adjustable upper rudder castings so hopefully I will soon take care of this problem.
But someone with more experience than me may think that it is something totally different.
James 1983 Hobie 16'
[Re: abbman]
#186105 07/24/09 04:41 PM 07/24/09 04:41 PM |
Posts: 5,582 “an island in the Pacifi... | Set both boats up the same. Mast rake, rudder rake and toe in, etc. Use one set of sails on both boats so you've got a base line to work from. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: My boat seems to drag? help
[Re: Ron in MI]
#186129 07/25/09 02:08 AM 07/25/09 02:08 AM |
Posts: 160 North Carolina | Yes. The adjustable upper castings have the screw and it is so you can adjust rudder rake without having to re-drill your rudders. As far as answering your other questions about proper rake, I'll have to leave them to someone with more technical knowledge that I have. For instance, many racers carry a certain measurement of mast rake and there is a way to get that measurement. But then again, it may not be your rudders or your mast rake. Sailing too close to the wind (or pinching) will slow you down, and create a lot of lift. Over-sheeting can also cause you to slow down on certain points of sail. If possible, I would try to find someone local that has been sailing a 16 for a while and let them give your boat a good look over. Maybe even sail with them and see how they set up their boat. In addition, this is a wonderful site for catamaran sailors, but if you also post your questions on the hobie 16 forums you will likely get many more responses. http://www.hobiecat.com/community/index.php?c=N
[Re: Ron in MI]
#186260 07/27/09 11:08 AM 07/27/09 11:08 AM |
Posts: 1,884 Detroit, MI | What is common place for water to get in? Hull / Deck join Pylons where they go through the deck All fittings screwed in the transom (gudgeons, drain plug housing) Lightly pressurize the hull using a shop vac set to blow. I've done this in the past by using the crevice tool and just hanging the tip of it in the drain plug opening while the hose is loosely taped below the rudder. Allow excess air to blow out of the hull past the vaccuum hose. DO NOT DIRECTLY CONNECT THE VACCUUM TO THE DRAIN PLUG! DO NOT USE AN AIR COMPRESSOR! It's suprisingly easy to explode a hull. I've seen the aftermath - which is non-repairaple. Once you've got your pressure system going, use soapy water on all the suspect areas. If it leaks, you'll see bubbles or you'll hear and/or smell the leak. | | |
2,758
guests, and 388
