| Bow design – Theory or Looks? #186211 07/26/09 04:30 PM 07/26/09 04:30 PM |
Joined: Feb 2009 Posts: 678 Palm Beach County TheManShed OP
Posts: 678 Palm Beach County | Here is topic for all sailors: Bow design – Theory or Looks?
Ok I’m baffled! What is the real skinny on this? What is your though and is fact or Personal Preference?
Basically I see three schools on this:
The Classic Look – Bow at the deck level longer then the waterline with graceful curve to the water line.
Straight or slight taper – From the deck slightly longer then the waterline or straight.
Wave Piercing – I’ll call this A-Cat look the deck length is shorter the water line. So the there is a “reverse angle” from the classic look. Usually almost a straight line or a slight taper from the waterline back to the deck.
I can design the bows of the TMS-20 to any of these looks. Currently the design calls for a straight line on the main hull and a classic look on the ama’s.
Your thoughts?
Mike Shappell www.themanshed.comTMS-20 Builder G-Cat 5.7 - Current Boat NACRA 5.2 - early 70's | | | Re: Bow design – Theory or Looks?
[Re: simonp]
#186215 07/26/09 05:17 PM 07/26/09 05:17 PM |
Joined: Mar 2008 Posts: 201 Adelaide, South Australia simonp
Posts: 201 Adelaide, South Australia | Maybe look to the dollars spent on research and design for the America's Cup boats and leverage your design on that(without spending the same dollars).
Simon BLADE F16 AUS405
[Re: simonp]
#186216 07/26/09 05:50 PM 07/26/09 05:50 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | If you really want to dig into this- http://www.boatdesign.net/forums/sailboats/wave-piercing-pitching-damping-marketing-18037.htmlBows with volume at the water line and finer at the top recover easier from submersion as the drag is lower as it rises vs. diving. Stick a conventional bow in that is wider at top, drag goes up faster, the bow slows down vs. the rig and over you go. The Bimare Javelin 2, 18Ht hulls are plumb, but have this configuration, volume low and skinny at the top. The N20 has tall bows for extra volume but are quite fine- different approach. 18HT Ben Hall on his winged A cat- bow shot of HT
E-Scow 24' ULDB
[Re: ncik]
#186223 07/26/09 07:57 PM 07/26/09 07:57 PM |
Posts: 678 Palm Beach County | My main hull bow come to a fine point at the tip then grows wider. The bow height is the highest point of the hull. Also it has a bowsprit on the starboard side of the bow for the screacher and spin. I have a flair that starts just past the bows very slight at first then significant to the stern. The family will be back from vacation, they took the camera, I hope to pull the foam out of the mold again and get some shots of the half hull foamed out to show the shape of the hull and posted it on the web site.
Today I laminated a foam strip to form the bow stem and started to bog the inside of the hull to fair it out. What a job there are compound curves and the foam strips lay worse on the inside. The outside will not be as bad to fair out. I also have a drawing of the ama lines to post I update the website next.
[Re: TheManShed]
#186230 07/26/09 09:58 PM 07/26/09 09:58 PM |
Posts: 4,119 Northfield Mn | Your effectively making the water line longer as well. If the longest point is always in the air, its not doing anything usefull.
[Re: Tony_F18]
#186278 07/27/09 03:57 PM 07/27/09 03:57 PM |
Posts: 5,590 Naples, FL | I thought AC boats were designed to a box or formula, which may influence their design. Maybe something like Open type boats, but those are monohulls designed with heel in mind.
Is there a class of trimarans not limited by some formula? ORMA 60's?
[Re: waterbug_wpb]
#186286 07/27/09 05:38 PM 07/27/09 05:38 PM | Scarecrow
| Scarecrow
Unregistered | Only a self imposed box. BMWO's challenge document said their boat had LWL of 90' and a beam of 90' . The only constraints on the swiss is lwl<90' if a sloop or LWL<115' if its a schooner or ketch. | | | Re: Bow design – Theory or Looks?
[Re: waterbug_wpb]
#186289 07/27/09 06:10 PM 07/27/09 06:10 PM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | I thought AC boats were designed to a box or formula, which may influence their design. Maybe something like Open type boats, but those are monohulls designed with heel in mind.
Is there a class of trimarans not limited by some formula? ORMA 60's? "The Race" boats weren't restricted. | | | Re: Bow design – Theory or Looks?
[Re: Tony_F18]
#186290 07/27/09 06:14 PM 07/27/09 06:14 PM |
Posts: 951 Brisbane, Queensland, Australi... | Don't take too much technical stuff out of the SA discussion, it's more of a pissing contest between pro-Alinghi and pro-BMWO posters. For the record, I don't like the look of those submerged hulls and Alinghi doesn't have a trim problem! hahahaha!!!! | | | Re: Bow design – Theory or Looks?
[Re: Tornado_ALIVE]
#186336 07/28/09 10:02 AM 07/28/09 10:02 AM |
Posts: 1,307 Asuncion, Paraguay | Nothing beats the sheet of spray that comes of a Tornadoes bow at pace.
Lots of spray = lots of energy wasted.
Luiz
[Re: Luiz]
#186381 07/28/09 05:12 PM 07/28/09 05:12 PM |
Posts: 334 Seattle,Wa | Sailing Math
Lots of energy wasted < Looking Cool
Therefore:
Looking Cool > lots of energy wasted
And so furthermore:
Lots of spray = Looking Cool, and cancels out any concern for energy wasted Hobie Tiger 2003 | | | Re: Bow design – Theory or Looks?
[Re: Don_Atchley]
#186382 07/28/09 05:26 PM 07/28/09 05:26 PM | Scarecrow
| Scarecrow
Unregistered | I don't care what everyone says about you Don, you're a Genius. | | | Re: Bow design – Theory or Looks?
[Re: ]
#186383 07/28/09 06:47 PM 07/28/09 06:47 PM |
Posts: 678 Palm Beach County | Wettest ride has to be a Supercat 20 I wear goggles and a snorkel
1 registered members (vasil),
289
guests, and 39
