| Re: Dart18 - HC16 comparision needed
[Re: Pacific]
#18621 04/14/03 03:12 PM 04/14/03 03:12 PM |
Joined: Aug 2002 Posts: 164 The Netherlands (North West Eu... RobLammerts
Posts: 164 The Netherlands (North West Eu... | First of all where do you sail ? at a lake or at Sea. The Dart 18.
+ Easy to handle. Single handed or light crew. No Daggerboards. Easy to repair. You can sail it till the frontbeam almost goes unther water and stil get it back into position. Very Strong.
- Expensive spare parts (at least in Europe). Some have lamination problems after 16-17 years.
I hope this helps.
Rob
Nacra 6.0 European version
Nr 090 + Spi
[Re: RobLammerts]
#18622 04/14/03 04:15 PM 04/14/03 04:15 PM |
Posts: 3,116 Annapolis, MD | If racing is a possiblity.. the Hobie 16 has active sailors around the USA and strong one design fleets in several areas. The Dart 18 was never actively raced in the US. Now you would be the slow boat in an open fleet.
crac.sailregattas.com
[Re: Pacific]
#18623 04/16/03 07:57 AM 04/16/03 07:57 AM |
Posts: 915 Dublin, Ireland | The Dart 18 is a British cat and is raced more in Canada than the US. If racing is not important, the Dart 18 is as fast, lighter, more forgiving,especially if you normaly have strong winds, less likely to pitchpole. The standard battens can break if you are not careful. Check that the sides of the hulls are firm from the bows back to the mainbeam. There is a foam block in there and the bond to the hull sides must be sound. The rudders have specialised parts which may be hard to come by. You can always buy parts from www.lasersailing.com Check out www.dart18.com or www.catamaran.ie
Dermot Catapult 265
[Re: Pacific]
#18624 04/16/03 11:00 AM 04/16/03 11:00 AM |
Posts: 46 Long Island,NY | I have had both boats, Tornado's and other boats.
If you are not racing in the hobie circuit, and you have moderate winds, the dart is the best boat in the world. I say this for the following reasons: 1) It is real light and you will be shocked how one persson can handle it on the beach. 2) It has totally linear handling, no surprises with pitchpoles, etc. Stuff it up to the rear cross bar and it will slam on the brakes and pop back up. 3) It is kind of a cross btwn an A cat and a 2 person boat, and works pretty well for both. 4) Ain't nothing on that tramp, no adjustments 5) No boom 6) Quiet!!! No swirly water noises, no humming boards, dead silent. 7) It is 8 feet wide, so trailers a bit less obtrusively. 8) You can sail it in 40 knots of wind, 2 up, and sail past all sort of pitchpoled boats laughing
And the drawbacks: 1) A bit underpowered if you are in a low wind area (actually this is its advantage as the winds pick up) 2) Limited dealers, but everything is mail order these days anyway. 3) Not much of a class
And just a warning, DO NOT confuse this with the Dart 20. It is a hulking lug, and this is one of the boats that I truely hated owning. If you want a 20 of related design, get a tornado or prindle 19. | | |
490
guests, and 38
