Page 3 of 3 1 2 3
Re: Bow design – Theory or Looks? [Re: David Parker] #186511
07/29/09 10:42 PM
07/29/09 10:42 PM
Originally Posted by David Parker
Robi, you'd be a good choice. You know the F16s, F18s, the local waters, and you need a chance to rebuild your karma with the GCat. Good or bad, Hans is staking his money on his design. Find some big air and rip it up!
I sent an email. I proposed to Hans to bring one down to GYC to compare against the F16 fleet there.
Re: Bow design – Theory or Looks? [Re: bvining] #186514
07/29/09 11:21 PM
07/29/09 11:21 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Originally Posted by bvining
Mike,
The wave piercing bow is the end result of moving more volume down to the waterline while keeping surface area constant (or reducing it.) The Acat designs did this because once you've moved the volume down to the waterline you need to remove surface area or you will end up with a boat that is too heavy for the box rule. Other designs moved volume down to the waterline in an effort to reduce wetted surface area that generally results from loading up traditional multihull shapes. Traditional multihull shapes have always suffered from adding weight as the surface area increases quickly as compared to a traditional mononhull shape.
So the net effect of moving volume down to the waterline is a pear shape with the topsides being thinner than the waterline. Once you take this shape to the bow, your classic bow shape is upside down and becomes what is being referred to as a wave piercing bow. That description is a bit misleading because even though the bows may seem to pierce a wave, the rest of the boat doesnt actually pierce the wave and the boat if affected by the wave at some point in a way thats pretty much the same as a boat with regular bows. The designers were/are more concerned with the waterline shape/volume than the bows and the bows are really just the end result of moving the volume down to the waterline.
The side benefit (and I own a wave piercing Acat) is that you can submerge the bows and the boat wont pitchpole as easily. See the recent BMWO trimaran shots for illustration. Sailing around with submerged bows like BMWO probably isnt fast, but if this happens in a gust, or during a bear away its a nice feature to have the bows keep moving underwater with little or less drag than traditional flat top bows. The boat doesnt really pierce a wave, the wave affects the boat in basically the same way. Think about a H16 and how the bows slow dramatically when they are submerged, this is what the wave piercing bows resist/avoid.
The downside of a bow with a pointy topsides is that you lose a bunch of utility, you cant walk on it, you cant attach hardware to it easily, etc.
So when you ask the question, you really need to talk to the designer and see what he thinks, and look at how he has the volume in the ama's and what the whole picture looks like. Having ama's that dont pitchpole as easily is a good idea for a 20 ft tri and something that I would consider having.
Deciding on the bow shape should be done in concert with the rest of the hull shape and boat design and not as a separate design decision.
Bill
Excellent description of the theory involved Bill! Thank you!
Dave
Re: Bow design – Theory or Looks? [Re: davefarmer] #186518
07/30/09 03:02 AM
07/30/09 03:02 AM
Yeah, what Bill said !
All the other talk about the "wave-piercer" bows is just BS.
Re: Bow design – Theory or Looks? [Re: Wouter] #186540
07/30/09 09:34 AM
07/30/09 09:34 AM
Palm Beach County
TheManShed Offline OP
Palm Beach County
Looks like Hans is on the move again. Great news it will be interesting to see an new era for G-Cat.
You sail the old G-Cats a little different in good wind it does not need the dagger board with the full knife-edge of the keel you may loose a few degrees - maybe but on a reach, off wind, chop, waves and the rest of the points of sail it's fast and cuts though the water. No bouncing, slapping, and pounding. You sail speed not the rhumb line.
So with an updated model that will be competitive with current market boats it will make for great chat on the web.
Just a thought I wonder how many of the current State of the Art cats will be around still sailin' in 28 years like the G-Cat 5.7?
Harem Haul 08
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Page 3 of 3 1 2 3
0 registered members (), 3,236 guests, and 277 spiders.
